Question about InFocus ScreenPlay 61" Rear Projection HDTV
Replace the bulb and the tv has pitcure now, but after 1 minute turns itself off and then back on.
Freezes up then shuts off then turns itself back on then off
  • bob walker Mar 02, 2012
    I took the tv apart and cleaned the mother board and fan on it. Now it works fine. Put the old bulb in and it works great. Becareful doing this.
I've got the same problem.. I've got the original remote but there is no reset button.
Posted on Jun 01, 2012
I'm having the same problem, I called tech support and they told me to hold the reset button for a minute and then try again, I have a universal remote so it doesn't have a reset button, :( So frustrated, any solutions please?
Posted on Mar 01, 2012
  • Syeli Mar 01, 2012
Mitusbishi dlp tv shut off
hi when you replace the lamps, the lamp counter needs to be reset,thanks
shaun
Jun 28, 2017 | Mitsubishi WD-73737 73 in. HD-Ready TV
Can anyone point me in the right direction?I have had my samsung DLP (model SP50L6HD) for 4 years. This morning my children were watching TV and the tv started turning itself on and off. I switched it...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 24, 2011 | Samsung HLM507W 50" Rear Projection HDTV
Screen freezes and then shuts off. This cycles every 1-2 minutes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
May 14, 2010 | Toshiba 32HLV66 32 in. LCD TV/DVD Combo
Try the main board with the cpu chip. The cpu chip should have a heatsink attached to it, may be an overheating problem. It has the LCD panel connector plugged into it. You may be able to find the board on ebay for less than a repair shop.
Mar 23, 2010 | Toshiba 32HLV66 32 in. LCD TV/DVD Combo
T.v turns off about 3 times a day
Its problem of bulb that got weak in result and causing TV shut down.
Replace bulb in TV and I would recommend to buy Sony original bulb for TV safety.
Jul 23, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
50v710 turns off by itself then on
Have you check the power supply,that's what it seems to me.
Jun 29, 2009 | Hitachi 50V710 50" Rear Projection...
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
InFocus ScreenPlay 61" Rear Projection HDTV Logo
190 people viewed this question
Top InFocus Televison & Video Experts
Donni Steen
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
