Question about Intel Computers & Internet
Replacing BIOS-mounted Promise PDC 20319 RAID 0+1 with RAID 1 on Intel S875WP1LX board
I have an Intel S875WP1LX server board and MS Windows Server 2003. The board has Promise PDC20319 SATA RAID (FastTrak S150TX4) embedded in BIOS without a Promise controller board. Originally, a RAID 0+1 (striping+mirroring) was set up using two identical Seagate ST3160827AS 160GB drives. But one drive died, taking with it all the RAID-based data. I bought an identical replacement ST3160827AS. Now I want to install it, but replace the RAID 0+1 with a RAID 1 (mirroring only), without changing drivers or losing data from the surviving drive. But Intel provides no more tech support for the S875WP1LX board, and Promise Technologies offers no tech support for their products that were sold through the board manufacturer. So how to proceed?
4 Suggested Answers
SteveRand
  • 210 Answers
SOURCE: Conflict between Promise Ultra133 and SATA RAID controller
Check that your RAID controller and onboard SATA controller aren't in a compatibility mode. You can put them in this mode while you have no SATA driver installed in Windows.
This tricks Windows into seeing the SATA drives as regular IDE drives. Your BIOS then has a spasm when it see's another IDE controller there, and just uses the card instead.
Make sure the SATA drivers are installed first, otherwise anything SATA will stop showing up. (and your Windows just won't boot if it's on a SATA disk and you take compatibility mode off) =-]
Posted on Aug 20, 2008
  • 37 Answers
SOURCE: Promise FastTrak TX2300
You will need to download the drivers on to a floppy disk. When loading setup press F6 when it asks if you want to use third-party RAID controller.
You can get the drivers from the below link
http://www.promise.com/support/download/download2_eng.asp?productId=136&category=driver&os=0&go=GO
Posted on Mar 16, 2009
pctech1
  • 1940 Answers
SOURCE: I have installed the Intel
The drive labelled Intel MegaSR SCSI Disk Device must be the Raid drive, which would mean it is installed. It probably just needs a Drive Letter assigned to it.
  1. Open the Start Menu, and then click Run.
  2. Type in diskmgmt.msc and then hit enter or OK.
  3. In the Disk Management window look for your Virtual RAID Drive. If the Raid drive is listed in the Disk Management windows, it will need a drive letter assigned to it to show up in My Computer.
  4. Right click on the Raid Drive, and select Assign Drive Letter or Change Drive Letter.
Posted on Feb 16, 2011
Phoenix bios release
http://intel.driversdown.com/Intel-drivers/Intel-N440BX-Server-Board-BIOS-14.0_76208.shtml
Jun 08, 2013 | Intel Server Board N440BX Motherboard
System hangs / MS Server 2008 R2 SP1 x64
You need to identify what process is causing the high usage, and it has to be done in normal mode. Take your time and sort by usage in Task Manager.
Mar 27, 2013 | Intel Server Board S5520UR (BB5520UR)...
I am not able to load server42003 in intel dg41wv
F2 to get to BIOS. Change the Hard disk Controller to "IDE" from ACHI or RAID.
If necessary, use the Server software raid.
Sep 01, 2012 | INTEL - MOTHERBOARDS Dg41wv Uatx Intel Gma...
Cant boot
check the Boot controller order in bios. If it is in raid and you have changed the HDD order then you are lost . Reinstall freshly
Apr 04, 2012 | Intel (SR2500ALLXR) Server
Wont boot says array controller wont start and no bios dell power edge 2500 server
Sounds like the RAID controller has failed. I would replace this first as RAID controllers are less expensive than replacing the system board, or the server as a whole.
Suggested: PERC 5i (RAID 0/1/5) or PERC 5iR (RAID 1 or 0 only)
Jan 03, 2010 | Dell PowerEdge 2500 Server
How to clear bios with jumpers intel s875wp1-e mobo
From the manufacturer's web-site:
http://www.intel.com/support/motherboards/server/s875wp1-e/
download the "specifications" document for your motherboard.
Jan 02, 2010 | Intel Server Board S875WP1-E (S875WP1LX)...
I cannot get the 2 x 4500Gb SATA drives to show up in the BIOS of a intel s875wp1 board. It is an older board and had the RAID setup in place - I just want the 2 x SATA drives as normal so turned off the...
ATA/IDE has nothing to do with SATA. Ignore.
Try plugging in the drives into the non RAID sata ports on the motherboard. I think when you disable raid you also disable the raid ports. You should have another set of sata ports on the motherboard, probably a different colour.
Nov 26, 2009 | Intel S875WP1-E Server Board Motherboard
Computers & Internet Logo
42 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
