Question about Samsung SV5000W VHS VCR
When convert PAL-NTSC w/ SV-5000W to Samsung Plasma only B & W pic
I have tried to connect the Samsung SV-5000W to Samsung Plasma & I am only getting a B & W picture. I have read most of the manual and can't see a fix.
  • jasm55555 Oct 28, 2008
    I have tried the input all the ways possible and that didn't change anything. I have great sound and good, not perfect picture. Is there a specific setting to get color in the TV. I ahve tried all the setting in the TV & still just get B & W.
  • 2,326 Answers
If your TV is multisystem, you will be able to change the color oscillator frequency to NTSC or PAL.
For NTSC you should tune the plasma to 3.58 Mhz
What is the plasma model number?
Posted on Oct 28, 2008
  • Samsung Master
  • 1,879 Answers
PAL will show-up B&W on a NTSC screen.Got to match the two to use teh same color system.
    Master:
  • 538 Answers
The connection cable..did it come with the plasma or the pal-ntsc unit..
  • Samsung Master
  • 19,396 Answers
Switch through the TV input selector until you find the proper input channel , probably you are using the wrong input.
  • Ginko
    Ginko Oct 28, 2008
    First try switching through the TV input selector until you find the right input channel , if this is not the reason try the connection cable.
    If this still cannot fix it check color balance settings on tv, check also image settings on receiver box, see if is set PAL or NTFS and change picture format.
How do i change my channel tuner from NTSC to PAL?
you need to get a converter that takes pal and converts it to ntsc.
Apr 16, 2012 | Sanyo DP50747 50 in. Plasma TV
How to convert from pal bg to pal I in panasonic th50pv30
Specifications for the Panasonic TH50PV30 Plasma. Broadcast Standards, PAL-I.DVB, AV-NTSC:PAL 50/60Hz, NTSC, M-NTSC. Picture size, 42" (106cm) Discontinued Model.
Should work, have a look in the intallation menu for the correct country that you want.
Hope this helps.
Mar 09, 2011 | Panasonic TH-50PV30 50 in. Plasma...
DVD player only plays in black and white on Soniq 42'' Plasma TV. (Have tried 3 different players all have the same problem)
The color loss is most likely due to a NTSC/PAL compatibility issue. If you bought the players overseas in a PAL region (http://upload.wikimedia.org/wikipedia/commons/0/0d/PAL-NTSC-SECAM.svg) and the TV is NTSC or vice-versa, there will be a color loss. Thiss because the different regions have different formats and when you go from one to the other, the color does no transfer over. You can buy a PAL to NTSC or NTSC to PAL converter to fix this issue.
Oct 06, 2009 | Televison & Video
SAMSUNG PLASMA TV (NTSC)
Here you go:
http://ddrgame.stores.yahoo.net/game-accessory-ntsc-pal-converter.html
This is the cheapest that I could find for you. You will have to put in your exact address to get the shipping charges. I couldn't just put in Nigeria to get that info. The site wanted specifics. Ebay is also another option. Good luck!!
Sep 25, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
No colour..
Sounds like you're feeding the ADVC the wrong broadcast format. Either PAL when the ADVC is in NTSC mode, or NTSC when the ADVC is in PAL mode.
Alternatively, your capture software may have a broadcast format setting as well, and that may not be matching what the ADVC is sending out. Remember that the ADVC does not do NTSC<->PAL format conversion, so NTSC analog input becomes NTSC DV, and PAL analog input becomes PAL DV.
Aug 07, 2008 | Canopus ADVC-110 A/D Converter...
Cant see Picture
Nope. The AV inputs except a composite video signal that is either NTSC or PAL. You will need to convert the PAL signal to NTSC.
Dan
May 09, 2008 | Philips 50PF7220A Television
Not working
first you should know that the uk system is pal and the usa system is ntsc. ok connect your cable box using the rca cable to your converter then out of your converter to you tv. the converter box should have buttons for out and in now remember that pal signal is going in to your converter (it should automatically selected it) but you would probly have to select the signal that is going out of the convert and the signal going out is ntsc so make sure u select out signal to be NTSC. hope i could help
Apr 02, 2008 | Samsung SV5000W VHS VCR
Pal to NTSC
Hi, Based on your post/description, you need to get a multi-system TV to go with your multi system VCR if you are going to playback VHS tapes from different regions. You are quite correct "Plays NTSC tapes to NTSC, Will not Play Pal to NTSC" to play PAL (even Secam) you would need a PAL/Secam TV. They have a different system for color and audio. In some cases, you can still play PAL but you get it in black & white and picture squeezed from top & bottom. Hope this be of some help to you. Good luck and kind regards.
Aug 22, 2007 | Samsung SV5000W VHS VCR
Samsung SV5000W VHS VCR Logo
204 people viewed this question
Henry  Thomas
Henry Thomas
