Question about ASUS MW221U LCD Monitor
Volume control box staying on in midle of screen
Can t get menu to stay still
Cannot lower volume on my sony tv 32L5000
The electronic volume control section circuit is faulty. The system control section tries to adjust the volume, by sending command voltage to the volume control section circuit, but this circuit do not accept or process it. Troubleshooting to this type of fault, is skilled one. Contact any service technician, or the service center.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Timeslide" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 20, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Volume stays at 100 i try to turn it down and goes back up
Does this TV have a touch-pad on the TV for the channel/volume/on-off control of the TV? If it does, I would suspect that this board has a problem that is keeping the volume+ function stuck on.
Mar 21, 2014 | Element Televison & Video
The light dosen't stays on on the small box where it controls the volum. i even changed the battery for the remote but the problems still stays on so could u help me how to fix it or where to fix it.
The interface module is the "small box"..that green light is only supposed to flash to indicate it received the command from the remote control.
It will flash or blink twice when you press volume up ..and again when you press volume down.. etc.
It is not supposed to stay lit.
If this is not the problem.. let me know.. hopefully you have it all hooked up correctly.. and are enjoying the great sound these units offer.
Best of luck!
Apr 13, 2011 | Bose CineMate GS Series II Speaker System
The word volume is staying on the screen and the volume will not stay on. when i go to the start menu it just goes crazy, seems anything i have to use the volume arrows for are not working.
Is it working OK with remote control?
If the problem noticed when you use the front panel buttons, you
have to replace all the tiny switches at a stretch.
Due to contact problem the resistance will vary time to time.
Hence you will get crazy functions. better replace all the button
switches of this type. These are all interlinked.
Sep 03, 2010 | GE Televison & Video
The grey volume box is stuck how do i remove it
control panel volume control options hide or control panel start menu look through all of the options it will let you choose what gets on stay on the taskbar
Apr 09, 2010 | E-Machines eMachines T3830 PC Desktop
I have a dell studio 1537 volume indicator stays on screen
Try system restoring it by going to the date that it worked. Just type it in the search box on your start menu and go to it and follow directions.
Nov 19, 2009 | Dell Studio 1537 Laptop
TV stays at the "Please Wait" screen
There is something in the system control not being satified. Probably needs a main PCB.
Oct 13, 2009 | Sharp LC-26D40U 26 in. LCD HDTV
Volume pop up in the middle of my screen
no photos of said window presented? i cant see them?
must be OSD? the monitor brain on screen display (menu)?
even with the DVI cable pulled?
only a monitor stated, w1907, no PC
some monitors have button lock
read the manual ?oops HP deleted it...
it tells you to push the menu key on the monitor for 10 seconds
and it unlocks. (4 buttons right side left button is MENU)
doom?
that power deal sounds super bad, like the power supply is bad.
if the monitor fails by its self not plugged it to a PC
then the monitors is bad.
try a reset on it? ( power off for 1hr, or off then plug in with power button held? or power on with menu held (wild guesses but common practice)
ok found your manual page 4-8 shows menu page advanced
list line in list factory reset.
but if the keys are dead, and power lamp failing
the power supply is no good or worse. worse is always possible.
and expensive
ever see the support page, read the guides
https://support.hp.com/us-en/product/HP-w1907-19-inch-Widescreen-LCD-Monitor/3709665/model/3709666
its over 10 years old now. 2007?
walmart has larger one for $50
cheaper that parts or repair this.... vastly
Jul 27, 2017 | HP w1907 LCD Monitor
Sounds like one of the front panel buttons is stuck in - possibly the volume down button. If no buttons work, this could be the reason why. Just a guess. If they all feel OK, it may still be worth pulling the back off, (Without electricuting yourself -DISCONNECT POWER!) remove the PCB board that has the buttons on it, and see if it turns on without the menu. If so, check all buttons, rare but I have seen one that looked fine but with a multimeter it showed it wasnt working. If the screen still displays the menu, Id say there is a bigger problem... HTH
Jan 19, 2009 | HP f2105 21" LCD Monitor
Multiple issues with tv
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
ASUS MW221U LCD Monitor Logo
81 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
