Question about Fedders Appliance Air Conditioner Wall
I have a Fredders AC/Heater unit and the energy save and heat button keep on blinking and it wont stop blowing heat once the room is heated enough.
I have to manually lower the temperature down to 69F so it wont get too cold.
Saigua
  • 981 Answers
SOURCE: FEDDERS D CHASSIS A6D24E7A
Oh, the compressor motor's borked or overworked and overheating, or its capacitor failed short (perhaps the motor is shutting off from thermal shutdown...but you get to find out whether that's so. Be safe.) Alternately the temperature sensors have gone touchy on you. Once you gently vacuum it clean, try keeping incandecent bulbs in series with the compressor to get an idea of how loaded that thing is as it runs for those 5 minutes or so; the load might change more than you expect, just pay attention.
Hopefully you won't have to replace the compressor or motor; but it's doable if you're a certified technician with like equipment (so you can handle the refrigerant decently.) Most shops will streamline a bunch of similar jobs together to cut the waste and setup time.
Bigger conditioners are so much more efficient than little ones...syndicate the A/C?
Posted on May 30, 2008
fireman23
  • 6 Answers
SOURCE: heat doesn't work on ac unit
u have to be more specific. is it gas or electric. If electric check breaker first. Gas check thermocouple
Posted on Apr 01, 2009
  • 659 Answers
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
luker711
  • 91 Answers
SOURCE: My AC unit wont blow the cold air.
No, you probably have a bad evaporative fan motor, capacitor or switching. It usually takes a Pro 1/2 hour to track down such a problem with good training.
Posted on Jul 09, 2009
hvac1960
  • 2133 Answers
SOURCE: This is a heating and cooling company looking for
You're right. The eating element always be behind the evaporator coil.But check whether your unit model has heating and cooling or cooling only.
Posted on Dec 15, 2010
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
How do you program this heater
temp setting
1. press the temp/timer button untill the temp icon blinks
2 use up and down arrows to set temp.3 the temperture icon will stop blinking and the current room temperture will appear after desired temp. is set.
4 the heat will turn off shortly after the desiredtemp. is reached and the temp. ndisplay will blink.
5 the heater will turn back on when room temperture drops below the set temp.
timer : auto -off press the temp/time button untill timer icon blinks. the hour display will apear. the auto off icon will also appear.
2. use up and down arrow buttons to set the heater operation time between 1 and 10 hours. this function will activate once the timer icon stops blinking.
3. the heater will automaticly turn off when time runs out.
set temperture first so heater will cycle on and off till shut down time reached
Feb 02, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
The clean button keeps blinking off and on and will not go to any cycle to clean.
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Jan 25, 2011 | Whirlpool 24 in. DU1100XTP Built-in...
The clean light keeps blinking and the dishwasher will not start. I pushed the cancel button and it runs for about 30 seconds and just shuts off. Nothing happens when you push the start button.
Hi
Daniel
Jan 01, 2011 | KitchenAid Dishwashers
Wont kick wont start i see the red ligh lights blinks 2 times then 4 times what shall i do thanks
4 Flashes indicates an over heat. Either the room air blower could not push enough air over the heat exchanger due to a blocked filter or closed registers. You will need to replace one or more of the sensors to get the unit back up running. Test each sensor with an Ohm meter to find out which one blew. There may be a reset button on it if you are lucky.
Dec 30, 2009 | Goodman GMS90703BXA Heater
Heater keeps going off on its on also fan not
Please provide more info. When it goes off does it come back on by itself or do you have to flip a breaker? Is the furnace gas or electric? If it is not moving enough air across your heat exchanger in a gas furnace or across electric heating elements this will trip a safety switch that will stop heating but not fan. Low air speed is most likely from inexperienced or improper duct design/ installation. Duct sizing is very important to move enough air. Don't believe me try breathing thru a straw. If your unit is a gas furnace it has a flashing code that will tell you what is wrong codes listed inside unit door. Could be lots of things. Reply with more info.
Dec 04, 2009 | Goodman Heating & Cooling
Heater smell when AC comes on...
The fan that blows the air blows through the heater coils before it blows through the A/C.As long as the heater doesn't come on, there is not much that can be done. ZCooking the attic room will be a problem because it is the heat rises thing, and on top(literally) of it all, the roof is radiating heat.
Sep 21, 2009 | LG Heat cool Window Air Conditioner
How to disable the energy saver of the amana ptac unit. Once the AC reach the lowest temp on the room , the unit turn off, then when room temp raise it turn on.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=PTH153B50AJ&siteCd=AMA
This is the link to find the manual for your unit. Make sure the model number is correct. You should be able to find the info you are looking for if it is possible to disable the energy saver. Hopefully this will help.
Mar 20, 2009 | Amana PTH153B50AJ Heat Pump Air...
A solid red light
If you have the economy button on turn it off. If there is a draft around the room sensor it will read much lower than the room. That should make the heater run wide open all the time however. Make sure the screens and fan blades are spotless. When it is 4 degrees outside your heater may be working very hard to try to heat the room.
Stay warm,
Tom Hawkins
hawkins111@gci.net
Jan 01, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Fedders Appliance Air Conditioner Wall Logo
51 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
