Question about Enlight Combo (5601908) (Beige) (5601908) CD-RW/DVD-ROM Combo Drive
How to take back door panel off vauxhall combo van
5 Suggested Answers
pope-group
SOURCE: wireing diagam for vauxhall combo diesel van
rac engineer repaired fault for door locks traced fault to fuse board but since then no
reverse lights
Posted on Jul 15, 2009
EngineerMC
  • 185 Answers
SOURCE: i have just bought a vauxhall combo van 2004 and
A common fault with the 1700 engines is the airflow meter which is on the air intake, needs plugging into the an ECU diagnostics to check, shouldn't cost much to repair if it is that.
Posted on Feb 14, 2010
zqdesign
  • 5 Answers
SOURCE: how do you change the wing mirror on a vauxhall
Lucky You, I can’t wait to get back to Europe, home actually, anyways your vauxhall 2003 combo van. Take your door panel off, start with armrest, unscrew it, these screws are right under the area you would be resting your arm on, this area is seen by large holes, these can be deep so a long medium Philips should be used.
Nest is door handle to unlock door, you have plastic cover or metal, some have a small screw or slots to fix it securely. Unscrew or use a thin small screw driver to gently pull each slot from panel or lock mechanism. Now your window is most likely manual, so I will explain this first, two ways these are secured, the handle you use to roll window up and down, a screw right in the middle, just unscrew or a ring clip, this is between the door panel and handle and is removed by a special tool made to do this or a screw driver on one side of clip, a quick tap with your hand on top ot screw driver or by prying from the top of the inside of ring between gear and clip.
Your door panel uses snaps generally, but some have screws where snaps would be as well, around the outer edges of the door panel , if snaps are used gently use a wide instrument rather the your fingers, this can break fittings of panel, so use a wide flat instrument, a large screw driver or a mini crow bar used to pull nails.
If speakers are mounted, be careful not to rip speaker wires, just pull the wire fasteners from the side of magnet, remember their location so you reinstall them correctly.
Now with a flashlight look under and up to see your mount base for wing window, remove the fasters and pay attention to the top pivot for wing window, most of them are pins and easily removed by a slightly sideways downward slowly pulling down, careful not to bend pivot slot or pivot pin. Some have also been secured by a screw on the top of door frame where pivot is mounted. Which is an obvious dismantling procedure, remove fastener, usually a screw, another Philips of some sort star screw or an alien screw. That’s it now your wing window should be free and in your hands. The reverse to install a new wing window. Good luck
ZQDesign
Posted on Jun 08, 2010
Testimonial: "Thanks but there was an easier way just pop off the triangle plastic cover take out the 3 screw with a star drive and jobs a good one."
SOURCE: vauxhall combo van starts then cuts out
Try banging the top of the speedo binancle. The 12 or 14 pin behind the speedo is a 'dry' joint and once I cleaned all the pins and sprayed in electrical spray into that fitting ...bingo no more problems.
Posted on Jan 12, 2011
My 2010 Vauxhall astra combo van has F showing on gears selected dashboard panel and i cant get gears
You need to have a fault code test run on the transmission control module (TCM) as a first step to seeing what is going on here.
Sep 21, 2016 | Vauxhall Cars & Trucks
I have fitted new doors to my Combo van but when I have shut them they will not open on the key or by the handle!! Doh! Can anyone help?
Get the AA or RAC to get you in. You need the key to the new doors, or swap the locks from the doors you had.
There are a number of YouTube videos showing ho to break into your own vehicle.
Dec 29, 2015 | Vauxhall Cars & Trucks
Could you tell me where to put my screen wash fuse on a Vauxhall combo van
LOOK FOR YOUR MANUAL BOOK FOR VAN,IF CANT YOU WILL FIND DIAGRAM ON HERE.
Apr 23, 2015 | Vauxhall Cars & Trucks
My windscreen wipers have stopped working on my vauxhall combo
my Vauxhall combo van keeps on blowing the windscreen wipers fuse what can cause this sometime there working for a round ten mins then blow the fuse
Apr 16, 2012 | Cars & Trucks
How do you change the wing mirror on a vauxhall combo van 2003 complete unit
ZQDesign
Jun 07, 2010 | Enlight Combo (5601908) (Beige) (5601908)...
Ex post office combo van need to change rear door lock to central
Hi Bernard, try this http://www.vauxhallownersnetwork.co.uk/showthread.php?141866-Ex-Royal-Mail-Combo-Van-%28rear-doors-opening%29&highlight=convert+ex+post+office+combo+rear+door+loack+to+central
Apr 05, 2009 | Enlight Combo (5601908) (Beige) (5601908)...
Wireing diagam for vauxhall combo diesel van
reverse lights
Apr 03, 2009 | Enlight Combo (5601908) (Beige) (5601908)...
Removing a speed limiter from a vauxhall combo cdti van
The speed-limiter is likely to be enabled via the ECU. Removing the limiter is a five-minute job if you have access to the GM Tech 2 electronic management/diagnostic tool.
If the van is yours then there's no legal requirement for the limiter. You could just book it in at a Vauxhall dealer for the limiter to be removed. They may charge you for an hour's labour though. Still worth doing in my opinion.
Jan 25, 2009 | 2005 GMC Sierra
Vauxhall combo van 2003 ex post-office - curtesy lights
the head light i dont know but the indicators i can help with, on the right hand side under the bonet, behind the metal panel, there is a black box unsrew it be carefull and have the key ready as the alarm will go off change the indicator relay the lid of the box will tell u which one it is thy should now work thanks jezza
Jan 02, 2009 | Enlight Combo (5601908) (Beige) (5601908)...
Enlight Combo (5601908) (Beige) (5601908) CD-RW/DVD-ROM Combo Drive Logo
294 people viewed this question
Top Enlight Computers & Internet Experts
Larry Maranto
Jerry Umali
Raymond Solomon
Level 1 Expert
Are you an Enlight Computer and Internet Expert? Answer questions, earn points and help others
