Question about Admiral AW22 Top Load Washer
Admiral washer wont fill or spin
Washer stopped filling up during rinse cycle, now wont fill or spin or anything
  • Luwana Bolch Feb 25, 2012
    next day, washer is working fine, could this be the control knob, and how would i fix it, also, how can i unblock the filter? thanks
    i know somethings wrong, dont wanna wait til it breaks again
SOURCE: Machine won't stop filling
Sounds like your solinoid valve needs replacing. It cuts the water off when it has reached the right level.
Posted on Apr 14, 2007
  • 90 Answers
SOURCE: Admiral Washing Machine not spinning
Make sure the safety switch that the lid operates is getting pushed down. Use a popcicle stick or non metalic object to push the switch in and try to get it to spin. This switch goes bad alot. It is in a wet environment. You will normally hear or feel a click when the switch is depressed. If not, use a putty knife or butter knife to push the top retainer in that are located at the front outer corners in the gap just where the top of the machine meets the rest of the unit. While pushing in you should feel a slight resistance but it should spring in and allow the top to lift up. Make sure to unplug the unit first.... Find the switch and unplug the two wires from it and use something like a paper clip or small wire to connect the two wires together. Let the top set back down, doesn't have to snap down and try to get it to spin again. If this works then the switch is bad... There are plastic parts on some machines that push this switch when the lid is closed that get broken off without you noticing until it just doesn't work right..
Posted on Feb 10, 2008
SOURCE: loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Posted on Feb 11, 2008
Yozzer6821
  • 116 Answers
SOURCE: Admiral Washer model #LNC6757 will not agitate
Possibly a loose agitator, try lifting the agitator, if it lifts then it is un secure, remove the softener cap and down inside the agitator you will see the fixing bolt,
You will need to lift out the agitator to retrieve the bolt if it has come fully un done, refit the agitator and secure using a socket and long extension bar.
Posted on Apr 18, 2008
  • 67 Answers
SOURCE: Admiral Washer........Spin cycle not working.
BAD LID SWITCH
Posted on May 18, 2009
I have an Admiral 20 lb. capacity heavy duty washer, not sure what model. Machine fills up with water but does nothing aftet that, all controlls seem to work fine. Before this issue it would rinse and in...
There should be a module that does the agitation bit for the washer motor(Spins one way shuts off and reverses the spin etc) There may be a capacitor under the control panel that is not working any more so the motor will not start.
Jun 04, 2013 | Washing Machines
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
Filled up with water on rinse cycle but wont work
Possible fault in the control panel , could be that the sequential switching to the next cycle is not outputted due to a failed device - a relay.
Remove the panel and check for dry soldering or parts that are burnt in your observation. Also check the voltage in the spin cycle and if this is absent the panel is a suspect as the processor does not advance from the memory set.
Jul 03, 2012 | Admiral Washing Machines
Washer is getting stuck at rinse cycle-
sorry to keep asking questions but i just need to know a little more information. are you using auto fill? have you tried manual water level settings? is your machine the one with the LCD DISPLAY?when it stops at rinse, is it agitating? if you have the LCD display have you tried the- traditional wash mode? please reply 4 further help.
May 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing machine wont quit filling during rinse cycles
if this is a top loading machine. turn it off the pull the drain hose up about six inches but do not remove it from the wall drain you should here water flowing out of the hose once the water has stopped restart you machine with the hose in the sam e position then it should fill up to the proper level and start washing. all this is provided it is not over flowing on the floor.
let me know how things go for and good luck
Sep 28, 2009 | Admiral AW22 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Admiral AW22 Top Load Washer Logo
Top Admiral Washing Machines Experts
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
