Question about Hotpoint Washing Machines
Location for the filter on the hotpoint wt965 ultima
dazmaraz
  • 67 Answers
SOURCE: Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
you have a blocked filter, unplug from mains, take off back panel you will see a black sump hose coming from the tub to the pump, tilt the machine forward and put a dish or bowl under sump unscrew clamp and pull off slowly to release any water in the drum. You will find a blockage, also what appears to be a ping pong ball dont throw away it is meant to be there.
Posted on Mar 07, 2008
  • 100 Answers
SOURCE: how to clean the filter
the dryer filter is in the dryer box on top of the drum, under the lid of the machine at the rear, sometimes has a grey hose going into it, the box will have to be removed and split to access it.
the wash filter will be either at the front of the machine behind the kick plate or at the rear behind the lower panel attached to th bottom of the drum.
Posted on Feb 25, 2009
  • 4 Answers
SOURCE: ive got a ultima WT965 and it keeps saying F-08?
F08 means the heater relay on the main pcb is faulty and the only way to clear it is to replace the main PCB (situated at the lower lh side - looking from the rear). Unless the new pcb is pre-programmed a new EEPROM will be required with the pcb. To be honest it would be better for you to conact HOTPOINT direct (tel : 08709066066) as if the appliance is under 5 years old they will repair it for £100 as the parts are free as long as you have hotpoint to fix it. The programming of the eeprom/pcb is done by the engineer from his laptop. For a small extra fee you can cover your appliance for a further 12 months as well as having it repaired.
Posted on Apr 17, 2009
SOURCE: Hotpoint WT965 ultima fault code
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Posted on Jan 07, 2010
  • 86 Answers
SOURCE: where is the filter on a hoitpoint ultima wf860
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter is under the rear of the machine inside the sump hose. Remove the lower rear inspection panel and tilt the machine forward, keep it tilted by placing a tin of peas or something under it at the rear. Now put a shallow bowl or dish under the sump to catch any water that may still be it the drum and remove the retaining clip. Pull the hose free from the tub and the filter is inside. (Work safe and remove the power plug from the wall before commencing any repair) For more tips on repairs use this link selfix-uk
Posted on Mar 11, 2010
Leaking hotpoint ultima washing machine
Hotpoint ultima wt965 washing machine This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 16, 2012 | Hotpoint Washing Machines
is your door locking when you switch on
Nov 09, 2011 | Washing Machines
I have a hotpoint ultima washing machine wt965 and the display is flashing f-05
F05 - Pressure switch jammed on full - Check pump for blackages. Also resetting the machine sometimes solves the problem switch off at plug for 5 mins then switch back on and try again. hop this helped
Sep 26, 2010 | Hotpoint Ultima WF865 Front Load Washer
My hotpoint WT965 displays F02 error and wont spin?
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
Mar 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
Test on display cant use washer
turn the machine on while you press the start and on buttons at the same time until dOFF appears.
Dec 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint WT965 ultima fault code F05
Aug 27, 2008 | Washing Machines
in this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
Jul 29, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint Ultima WD72 Front Load Washer/Dryer
This video will show you how to keep your soap draw clear and how to service the parts.
a 4 THUMBS rating is appreciated for answering your FREE question..
Jul 08, 2008 | Hotpoint Ultima WD72 Front Load...
Mar 06, 2008 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
37 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
