Question about HP Color LaserJet 2600n Printer
Belt is not cleaning of image
Copies coming off with latent partial image on outside edges...not cleaning off well before subsequent copies
  • 4 more comments
  • torvan Oct 28, 2008
    It is a faint image on the outside 1" edge of copies that seems not to be getting cleaned off...maybe it's the large belt that transfers the image to the paper I don't know...just want to get 'clean' copies again
    All cartridges were replaced and still happening
  • torvan Oct 29, 2008
    ALL TONER REPLACED AND 'GHOST' OF ORIGINAL IMAGE STILL THERE...THE TRANSFER MEDIUM IS NOT BEING CLEANED OFF AFTER INITIAL IMAGE TRANSFER.
    Copies coming off HP2600n with latent partial image on sides...not cleaning off well before subsequent copies..repeats image every couple of inches down the page
    Is there one 'drum' or one built into each color?
  • torvan Oct 30, 2008
    Best answer so far..will take to HP Service depot
    Guru:
  • 859 Answers
When you understand how laser copiers work, the same principle works in laser printers. When you send an image to the printer it is similar to an image being scanned for copying.
How this works. When you go to print something with a laser printer the program sends an image via the printer interface (software). One of the options with laser printers is full page, full bleed (no margins on edges). This can happen by design, you formatted it that way in the printer interface dialog box. Or this happened by mistake, software not working correctly.
Once this image is charged in the printer, paper is passed under a tungsten wire that charges the paper so toner melts into the paper as charged by the printer interface.
Apparently by design or mistake, this image data is still residing as an image in your printer. This then needs to be cleared away and removed.
To clear the old image away and provide a new clear set of data apparently residing in ram you can do one of two things. 1.) remove and reinsert the ram modules. This is dependent on your skill level. When you access the panel where the Ram resides there is a way to reset the printer, usually through a jumper, but... this is not true for all printer models. And, if you cannot follow this line of thinking, or have never done this, then it is out of your area of expertise and should NOT be attempted.There are too many mistakes you can make in doing this such as not using a ground strap. Again, if you don't know what that is (I don't know what your skill level is).do not do this. 2.) you can print a blank page at full bleed, that is no margins of any kind. This blank page you print at full size with no margins (full bleed) should clear out the dirty data that you are seeing now..
If that does not work, then you have no choice but to call in a printer tech to handle this problem for you. A printer tech, by the way, will be able to resolve this for you, professionally.
If this has confused you. Or, you do not fully understand the concept of what this effort does or how it is accomplished please do not "Refuse and Repost" just yet. Ask for more clarification on this process until you do fully understand it. Other experts here besides me will understand sending a full bleed blank image to your printer to clear out the dirty data in memory, (not dirty material in machine). This has nothing to do with your drum, rollers, toner or tungsten wire.
Regards,
Worldvet
Posted on Oct 29, 2008
    Scholar:
  • 155 Answers
You said in your comment that the image repeats every couple of inches.is due to the faulty pcr roller in the tonner cartridges its located in the cartridge behind the drum of the cartridge.but you also said that the cartridges were replaced .if the replaced cartridges are new then its not the problem of cartridges but if the cartridges are refilled or recycled/secondhand it too can have faulty pcr roller.
but if the cartridges r new then its not the problem of cartridges.then it could be the problem of
1)printer requires servicing (as the rollers and gears r not able to move at the required speed so the image is repeating)
2)there is also a pressure roller in printer same pressure roller problem in the printer could be faulty.
3)there is a small lens in your printer if that lest has dust on it these problem could occur. but servicing will clear that problem.
feel free for further assistance.
thanks.
  • 94 Answers
Try cleaning any toner of the drum as toner tends to stick to it and transfers to the paper
  • 4 more comments
  • Andy Bathgate
    Andy Bathgate Oct 29, 2008
    if youve had a paper jam the self cleaner does not clean the photo receptor and usually needs cleaned manually
  • Andy Bathgate
    there should only be one Drums as toners are charged by colour by different wave lengths of light (by the way it does use a laser as the name suggests) and are atracted to th photo receptor area of the drum and since its in the margins i'm betting printing has been interupted (probably a paper jam) and left toner on the drum in the margins area and is being repeat each cycle of the drum
  • Andy Bathgate
    Sorry last comment should read "doesnt use a laser as name suggests"
  • Andy Bathgate
    Andy Bathgate Oct 30, 2008
    use the analogy that a laser printer is only a well dressed laser copier and think how much drum cleaning they require
  • Andy Bathgate
    manual cleaning illustrated
    document.tlSearch.tx.value=unescape("")
    HP Color LaserJet 2600n Printer - Cleaning the printer
    During the printing process, paper, toner and dust particles can accumulate inside the printer. Over time, this buildup can cause print-quality problems such as toner specks or smearing. This printer has a cleaning mode that can correct and prevent these types of problems.
    This printer has two processes for generating cleaning pages: one is automatically generated and one is manually generated. When a new black print cartridge is installed, a cleaning page will be automatically generated prior to calibration.
    Clean the fuser using HP Toolbox
    NOTE:
    Use the following procedure to clean the fuser using the HP Toolbox. To clean the engine when the computer is running an operating system that does not support HP Toolbox, see the late-breaking Readme on the root of the CD-ROM, or visit http://www.hp.com/support/clj2600n .
    1. Make sure that the printer is turned on and in the Ready state.
    2. Open the HP Toolbox using one of the following methods.
      • On the Windows desktop, double-click the HP Toolbox icon.
      • On the Windows Start menu, click Programs (All Programs in Windows XP), click HP , click HP Color LaserJet 2600n, and then click HP Color LaserJet 2600n Toolbox .
    3. Click the Troubleshooting tab, and then Troubleshooting Tools .
    4. Click the Print button next to step 1, "Click the "Print" button to print out the Cleaning Page."
    5. Remove the Cleaning Page from the output bin, and load it printed side down in Tray 1.
  • Andy Bathgate
    Andy Bathgate Nov 02, 2008
    you total free-loader
  • 728 Answers
Check your ink cartriage to make that they are not low and make sure the heads of the ink cartriages are clean by printing out a test page that should clean off the heads.
Posted on Oct 28, 2008
  • Jazz Boyce
    Jazz Boyce Oct 28, 2008
    Try a test page. That should alidgn the belt and clean off the heads to make sure you have clean copies. To do a test page, go to control panel, click on the printers and faxes button and right click on your printer from the list and select properties at the bottom. On the general page, go down to the bottom and click print test page. Arter that, it should work.
  • HP Master
  • 19,396 Answers
Ispect the topner cartridge, check that the toner is not defective and spreading excessive dust.
Try replacing the toner and printing few pages.
    Master:
  • 538 Answers
Hmm..what belt are we referring to_..and is that image a line or an actual rendering of an image?
  • A Womans Computer Man
    A Womans Computer Man Oct 28, 2008
    would you mind doing a test page, first, and letting the experts here know that result?
AR-M355 Latent copies.
This make is not my specialty, but if the fuser's been replaced, then it can only be a drum cleaning issue causing that problem.
Dec 28, 2009 | Sharp AR-M355N Copier
Konica 1015 copier has been in storage for 10 years
You need a drum cleaning blade. These blades will go bad if left unused for that much time. This part cleans all that toner off of the drum in between copies. Cheap part at about $25.00 to $35.00
Just google konica 1015 drum cleaning blade and you will find one.
Dec 28, 2009 | Office Equipment & Supplies
Canon PC6re copier makes copies that are dark on the long edges
Just fyi, a Canon PC-6e is a copier that is about ten + years old of a model... The drum unit will make the copies better.... But, you most likely need to clean the optic's. Have you tried to make the copies lighter??? If I am correct, there is a small botton on the control pannel that will turn... It will make the copies light one way and darker the other way... Good Luck
Apr 20, 2009 | Canon PC170 Copier
Our Gestetner DSm645 gives Dark Copies..........
Sounds to me like the drum needs replacing, and likely the developer too. There is probably a haze of toner still on the drum. You can check by opening the right side cover and looking at it. Is there toner on the drum (green cylinder). It may not be too obvious depending on how dark the copies are. GENTLY wipe a tissue across it after making several copies - it should be clean if the drum is functioning properly. If it is, it could be the fuser that is wearing out, but I'm leaning toward the drum. As I said, if you need to replace this, it is a good idea to do developer at the same time, because these machines tend to be a little sensitive.
Mar 18, 2009 | Office Equipment & Supplies
Black streaks all over copy
Copies come out with one black line
Feb 05, 2009 | Sharp AL 1631 Copier
Gestetner 2722z copier, new drum, new transfer belt, smudges yet
The image is not transferring properly..........
remove and clean all corona wires (thin wires that create the latent image) use a q tip and dip in rubbing alcoholhot
Also make sure the fuser rollers are hot(insert or trick safety switches to determine if the fuser lamps are lighting usually upper and lower
Also check the imaging lamp to be sure it does not have any dark burn marks on it and clean the mirrors and the glass under the coy area
Dec 30, 2008 | Gestetner Office Equipment & Supplies
Cleaning
depeds on where it's coming from. Open the front door, is there toner on the big black belt? if yes get a clean dry cloth and wipe , turn belt at edges only. It may be that the toner is leaking, after markets sometimes do that.
Jul 09, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
205 people viewed this question
Seeker5211
Seeker5211
