Question about Panasonic SA-HE200 Receiver
Overload signal recently began to occur randomly on my home stereo receiver
I have my flat screen Samsung LED TV, a 5 changer DVD/CD, a blue ray disc player and an HD Direct TV receiver hooked up w/2 Cerwin Vega floor speakers and an MTX subwoofer hooked up to it. It has worked fine for a couple of months and just this past week it will randomly shut down my stereo w/the read-out "Overload". It will work the next day - and sometimes work the entire evening - while other times the "overload" error message and power down will occur.
nfandres
  • 168 Answers
SOURCE: "No Disc" error message
remove the cover of the unit and try to clean the lens with a soft clean dry cotton swab or if you have a compress air cleaner, just blow it. most of the time cleaning can solved this kind of problem. good luck!
Posted on Feb 22, 2008
  • 5 Answers
SOURCE: Wont read disc-error message HO7
this prob. happens bcouse of the board of the dvd player
HO 7 means soft. ware prob. of the pcb call to the panasonic tech. they have the soft. cd and they will sort out ur prob. whithin 5 min. its like soft. update only
Posted on Jun 11, 2008
SOURCE: overload, switch off
I was able to fix this problem by replacing a fuse. Remove the cover (7 screws). Directly behind the fan are 2 boards with 5 fuses on them. The boards are 1 over the other. The fuse I replaced was labeled F5 and on the top board with the fuse facing down on the underside of the board. This also fixes the error code F70. The fuse is 8 amp, 125 volt and not available at Radio Shack.
Posted on Jun 23, 2008
SOURCE: How can I fix my
OPEN DVD PLAYER AND USE A HAIR DRYER TO HEAT AROUND THE LASER AREA FOR ABOUT TWO MINUITES IF THIS DOESNT WORK REPLACE THE MOTOR
Posted on Nov 20, 2008
SOURCE: overload & shotsoff
i cannot get sound as my ac receiver says overload what can i do
Posted on May 18, 2009
How to connect dvd player to changhong tv Model ud42yc5500ua
Changhong 42" Class Ultra HD LED TV - UD42YC5500UA ...
www.newegg.com > ... > TV & Video > LED TV > Changhong
Newegg
Rating: 3 - β€Ž112 reviews - β€Ž$481.93 - β€ŽIn stock
Buy Changhong 42" Class Ultra HD LED TV - UD42YC5500UA with fast shipping and ... Samsung BD-J5100 Blu-Ray Player ..... Blu-Ray/DVD Disc Playbac.
How to connect a standard DVD player to a TV - YouTube
? 2:57
https://www.youtube.com/watch?v=8pARHjY8xoo
Jul 5, 2011 - Uploaded by All About Home Electronics.com
How to connect a standard DVD player to a TV .... is the make and model of your blu-ray dvd home theater ...Missing: ud42yc5500ua
Dec 30, 2015 | Televison & Video
Connecting my new samsung blu-ray player (bd-fm57c) to my toshiba theaterview tv.
I don't think that cord will work. HDMI carries video and audio signals, you might get video but probably no sound. You might as well try anyway though so here goes... The red green and blue plugs are your video and the other red plug and the white plug is for stereo sound. The yellow plug is just a lower quality video plug. So plug in the red blue and green plugs into the component video inputs on the TV then the red and white plugs into the audio inputs. DON'T plug in the yellow plug. If this doesn't work go to your local home theater store and ask for a receiver or switcher that will downscale high def HDMI to component video and stereo audio. You can probably pick up a cheap one for around $100. Good luck!
Mar 29, 2014 | Toshiba 50 Inch Big Screen Flat Tv Theater...
This is not a car dvd/cd changer. it is a pioneer f727 301 disc changer. I took all of the dvds out and reinstalled them, still no sound.
Check Your Wiring Harness On Back Of Player Also Your Stereo Sometimes Pioneer Tends To Get Loose Inside The Wire Harness plug.
Mar 17, 2012 | Pioneer DV-F727 DVD Player
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
Hi, Ive tried to set up my samsung blue ray
It seems as though the HT works fine, so to get the TV itself to play through the HT setup, take the audio out from the TV and hook it up to a separate channel on the HT receiver. Turn on TV and receiver and put the receiver on the respective channel of the receiver. I hope this helps.
Oct 26, 2009 | Samsung Audio Players & Recorders
CD changer will not mix discs randomly
RANDOM PLAY SHUFFLE M.I.X (has a little folder next to the mix sign. (#5 button) NOT #6
SHUFFLES ALBLUMS AND SONGS
This option randomly shuffles the next disc and songs
More info here if you need it:
http://www.retrevo.com/support/Alpine-CDA-9856-Receivers-manual/id/1060dj492/t/2/
Sep 03, 2008 | Alpine CDA-9856 CD Player
LG home 5 disc dvd changer
defective call customer support or bring it back to were you bought it
Jul 21, 2008 | LG 1000W XM-Ready 5.1-Ch. Home Theater...
How to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
Jan 06, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
As a CD player - shuffle/random?
The point of buying a 5 disc CD/DVD player is that you can let the machine play randomly through all 5 CD . Where is that button ?
Dec 10, 2007 | Venturer SVP580 Multi-disc DVD Player
Random play for all cds in player
You might have to push each Cd button first so that it initiallizs all 5 disks and then press random
Nov 22, 2007 | Panasonic DVD-F87 Multi-disc DVD Player
Panasonic SA-HE200 Receiver Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
