Question about LSI Logic MegaRAID 8708EM2 8port SAS RAID (LSI00187) Storage Controller
Drives are not detected
When i plug drives to the controller they are not recognised sometimes when i plug more drives the controller start being recognised as LSI Megaraid ???? instead of the model
  • acorp_bg
    acorp_bg Feb 25, 2012
    SERVER---
    Server IP: 192.168.149.1
    Server Name: hx0rz
    OS name: Windows 7
    OS Version: 6.1
    OS Architecture: x86_64
    Driver Name: megasas2.sys
    Driver Version: 5.1.112.64
    Application Version: MegaRAID Storage Manager - 11.06.00.0300
    HARDWARE---
    Controller: MegaRAID SAS 8708EM2 (Bus 4,Dev 0)
    Status: Optimal
    Firmware Package Version:11.0.1-0042
    Firmware Version: 1.40.282-1279
    BBU: YES
    Enclosure(s): 0
    Drive(s): 0
    Virtual Drive(s): 0
    BBU---
    BBU Battery Type IBBU
    BBU Status: Healthy
    This is the overview there is one disk attached, The motherboard is Gigabyte GA-X58A-UD7
  • acorp_bg
    acorp_bg Mar 10, 2012
    Problem solved. There are 2 types of SFF8087 cables forward breakout and reverse or so. So i had the wrong cables
2 Suggested Answers
SOURCE: LSI Web BIOS won't start?
I have a LSI 8888ELP on a Asus P5Q Deluxe and had the same problem with not being able to access the Web BIOS.
What I found was I could access the Web BIOS if I disconnected the hard drive that plugged into the onboard controller.
Posted on Oct 28, 2010
DVD drive recognised but disc not recognised
not sure how its recognised on control panel
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Apr 05, 2012 | NEC MultiSpin ND-1300A (ND-1300A)...
My PC is working fine, when my mouse starts lagging and a blue screen pops up, telling me to reboot my computer. so I do, and when it comes on, a screen comes up saying American Trends and some other...
The message you are seeing (ami trends) is the 1st stage of the netbook booting (the bios), this checks that all the system components are present in a sequence.
From what you are describing, it looks as though the hard drive has slowly been failing and this would account for the lagging mouse. The Bios error message "hard disc error" confirms that the bios has not been able to detect the hard drive, which could mean that the drive has failed, the drive controller has failed, or, (possibly) this is virus related. Pressing F1 to resume will achieve nothing, as this is a sort of skipping step that ignores the problem.
Before going into the stages below, try to access the bios (press F2 just as it powers on), look for the screen which lists the boot order and drives attached, see if it "sees" the hard drive (primary master) and that it is selectable. If so, reboot and see if it now detects it. Sometimes removing and reinserting the drive is enough to get it to be recognised
If it then works, worth virus scanning the drive to be on the safe side
Fixing the problem:
Firstly, you need to see if the hard drive has indeed failed, the best way is to substitute the hard drive with another one known to be good. If this is recognised in the bios, than this has most likely been the issue. You will need to reinstall windows (external CDrom and windows OS needed)
Secondly, if the hard drive is not detected by the bios, the fault lies in the hard dive connection ( check the connection from the hard drive to the motherboard, make sure it is firm and not loose, sometimes even a loose fitting drive will not be recognised). If it still is not recognised then the problem lies with the motherboard and will possibly need specialist repair
Apr 20, 2011 | ASUS Eee PC 1000HE Netbook
Not recognising the drivers . i have 320gb wd portable ext hard drive WD3200BEV Ext USB Drive
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 20, 2011 | Western Digital (WD3200JS) 320 GB Hard...
Hello, I have plugged my 500gb Elements hard drive into my usb port on my computer. I have been using this drive successfully for many months. This time the computer recognised that i plugged something in...
hope this helps
Apr 10, 2011 | Western Digital Computers & Internet
Having a problem with an external HDD. Although it is getting power - any OS cannot seem to pick up the HDD. This means I cannot access any of my files. It is a Samsung G2 Portable HDD.
Sometimes it takes a few minutes for the computer to detect a USB device when it's plugged in. Try rebooting the computer while the external hard drive is connected and powered. Then wait a few minutes before we start worrying. The last resort is to contact Samsung and tell them their product is defective - they might have a fix.
Dec 30, 2010 | Samsung Computers & Internet
Hard Drive not recognised
If you are trying this on XP or other Windows OS, find out if it gets detected or not. you will find a icon below in your desktop
If this icon is on your taskbar and you are still not able to find the drive then you might need to manually configure the drive and partition in your computer management.
To go to computer management and assign drive letter to your drive detected follow below
go to start->control panel-> administrative tools->computer management-> locate disk management-> on the right side pane you might find detected hard drive but no drive letter-> right click the drive and select change drive letter and path->click on add->from assign the following drive letter select a drive-> click ok-> and your new drive will be assigned a drive letter and you can access your drive.
Below are the screenshots to do it. Hope this helps
May 23, 2010 | Western Digital My Book Essential Edition...
Sounds like a possible problem with the usb ports. Does the usb drive work on other pc's? If so, does your laptop recognize other usb devices (flash drives, mouse, keyboard etc.)?
If your laptop won't recognize other usb devices all the time, try this: go into device manager, go to the bottom, expand 'universal serial bus controllers'. Starting at the bottom of the list, right click on each item and left-click 'delete'. At some point you will likely lose your mouse/tochpad as it is probably an internal usb device. If this happens, press the power button on the laptop once to shut it down. Restart it, and windows will re-detect the deleted usb hubs and hopefully fix the problem. If this doesn't do it, go back and delete the other usb root hubs and host controllers. This is totally safe for your system and often fixes this issue. Windows will always re-detect hardware at boot time.
let me know if this helps or not :)
Aug 18, 2009 | LG GSA-H10A Burner
Unable to play songs on the Alba 512 mb Mp3 Player
Managed to fix it !
Windows XP or any other version had an issue in completely recognising the media player.
Every time I would plug in the MP3 players, Windows would show that a new hardware has been plugged in and try to set-up the drivers. It would also breifly recognise it as being a music player and assign drive E: and F: to it. However every-time I would try and select the E: or the F: drive to inspect its contents Explorer would hang-up and crash.
So I re-did this in MS Dos prompt mode. i.e. for thos who are not familiar do the following :
ClicK Start - Run - and type cmd to bring up the command prompt
then type cd\
and go to the root C:
Plug in the MP3 player and wait for the detection. Once detected on the C:\ prompt
Type Format E:\
Be Very Very Careful that you don't type ***** Format C: ***** otherwise that would be the end of your hard drive and all the data :-)
After the E:/ has finished formatting the control should return back to the C:\ prompt from where you would be able to type E:/ and go the E: drive
Unplug and plug the mp3 player again and now windows should be able to detect the player properly and not hang-up.
You may have just lost all the songs on the mp3 player but now the player is back into life. So start copying your songs and enjoy your player !
Good-Luck.
Jan 08, 2009 | Audio Players & Recorders
Ps3 not recognising ps3 games and movies
Sounds like it could be failure of the Blu-ray drive. A friend of mine had the same issue.
Contact Sony support and if it's under warranty they will fix it free of charge (here in Australia they do anyway).
Aug 19, 2008 | Sony PlayStation® 3 (60 GB) Console
IOGEAR COMBO not recognised
Is your hard drive detected by the computer? Did you try changing the USB ports? You can check if the drive is detected by Right click on taskbar > properties > startmenu > customize > advanced > scroll down completely and select system administration tools "Display on the all programs menu" > ok. Click on start > all programs > administrative tools > computer management > double click on storage. click on disk management(local) here you should see your drive. If you dont then the drive is probably not detected. If you see, you can just re-format it from here and it will appear in your my computer.
Dec 21, 2007 | IOGear COMBO ION GHD135C160 160 GB Hard...
LSI Logic MegaRAID 8708EM2 8port SAS RAID (LSI00187) Storage Controller Logo
158 people viewed this question
Top LSI Logic Computers & Internet Experts
David Payne
David Payne
Are you a LSI Logic Computer and Internet Expert? Answer questions, earn points and help others
