Question about AMP (219560-5)
Speakon cable to amp
My banana plug cable end is not marked with polarity. How do I know which dual banana end goes where?
  • 33 Answers
Check the wire's insulation for ridges or striping; if the insulation is clear check the color of the wire inside. Then check the source of the wire to determine which polarity is connected to which wire. Once you know the polarity of the wires at the source, it should be easy to determine the polarity of the wire at the destination. The wire closest to the particular banana clip is most likely the one connected to it. If all else fails, you could use an OHM meter.
Posted on Oct 31, 2008
Trying to connect pyle PADH215 speakers
Pyle's PADH 215 comes with three different types of connections.... Banana Plug, 1/4" and Speakon. You can use any with this speaker. The reason there are two of the 1/4" connections and Speakon connections is that this offers the ability to daisy chain multiple speakers together as long as you watch your ohm load. And no it doesnt matter which connection you plug it in to
Mar 28, 2014 | Pyle Padh215 Dual 15" Dj Speaker
How to connect my JBL JRX 115 speaker to my Yamaha RX V673 receiver
You would use a standard banana plug to either a 1/4 phono or speakon plug. The JBL JRX 115 has both on the back. All the outputs on the Yamaha RX V673 have banana plugs. The channel you plug into would be up to you, there are many choices and they are listed on the back of the unit.
Dec 03, 2013 | JBL Audio Players & Recorders
Loud Speakers only have 1/4 inch inputs
Get the Speakons to 1/4" cables. If you're concerned about grounding, make sure the amp is turned off before plugging or unplugging the speakers.
May 02, 2017 | Music
Want to wire a female speakon connector in a plate with 1/4 connector on other end to plug into a rack mounted amp. Plugging onto speaker.
Just so I understand what you are trying to do; you have a power amp that has 1/4" phone output and want to make up a cable of x length to plug into a SpeakOn(c) connector on a speaker. Correct?
Nov 25, 2010 | JVC Audio Players & Recorders
I feel like a dork asking this question but how do you connect the amplifier to your mixer. I see that there are places for a banna plug however my mixer will not take a 1/4 banna plug.
In case you don't have one, here is a link to the manual:http://www.peavey.com/assets/literature/manuals/80300573.pdf I don't know if you are using a separate crossover between the mixer and the amp but here is the simplest explanation.I just reread your question and I don't even know whether you have a Peavey amp. Run proper cables from the main output of your mixer to the main inputs of your power amp.They will be 1/4"shielded cables or Balanced XLR cables. Do not use unshielded speaker cables to hook the mixer and the amp together.Run speaker cables from the speaker outputs of the amp to the input jacks of your speakers.Make sure the impedance of your speaker cabinets equals or exceeds the impedance rating marked on your amp. Here is the link to the newer model PV2600 manual:http://www.sweetwater.com/store/media/pv2600_doc_manual.pdf Don't use Speakon cables unless your speaker cabinets are equipped with Speakon input jacks. Banana plugs aren't as solid a connection as the binding posts are.
Nov 07, 2010 | Peavey Pv 2600 Power Amplifier
Is there a common problem with his mixer? mine not working at all.. is there a frequent fuse problem? could you send me the scheme plans? thank you! bruno
Has it worked before? There is a frequent problem caused by arcing between circuit layers in the power amp section. There is a hazard that I wrote a tip about on here regarding speaker hot polarity when using Speakon to 1/4 inch plug cables. If no lights come on, the power supply in it has failed, usually because of the arcing problem. If things light up and effects windows can be changed, plug in headphone and see if anything comes through there.
Oct 26, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Can't connect amp to speakers
MOST amps have a small plastic plug in the center of the amps speaker output sockets use a small screw to pull these out.
CABLE GUY.
Feb 22, 2009 | Cambridge Audio Azur 540A Amplifier
Wiring my peavey 112xt subs with my peavey 2xt tops
hi don't know if you have sorted this yet, you need to wire your cables that go from sub to top +2 -2 on the speakon (on the sub end only) HTH
Jan 04, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Crown amp xs900 will not reset
naz, get a hold of crown, tell them whats up. check all fuses and connections first. the unit is worth $900.00. they should be a little understanding.
Features
  • 2-ohm dual (per channel) : 1200W
  • 4-ohm dual (per channel) : 900W
  • 8-ohm dual (per channel) : 600W
  • 4-ohm Bridge : 2500W
  • 8-ohm Bridge 2100W
  • Indicators for : Signal, Clip, Power, AC Mains, Fault, Bridge, Temp.
  • Housed in a rugged, all-steel 2U chassis
  • Microprocessor-controlled protection system.
  • Flow-through ventilation from front to back.
  • Internal heat sinks with forced-air cooling for rapid, uniform heat dissipation.
  • EIA Standard 19-inch rack mount width
  • Safe with all types of loads.(2 to 8 ohms in Stereo, 4 to 8 ohms in Bridge Mono.)
Inputs
  • XLR-¼" combo connectors: One per channel
  • 3-pin female XLR connector and TRS ¼" phone jack accept balanced or unbalanced signals.
  • 3-pin Phoenix-style connectors (2-channel models only),One per channel, accepts balanced or unbalanced signals.
Output
  • Balanced XLR connectors (2-channel models only)
  • One per channel, 3-pin male XLR connector in parallel with XLR-¼" combo and Phoenix-style input connectors for daisy-chain operation.
  • 5-Way binding post output connectors: One pair per channel; accept banana plugs, spade lugs or bare wire.
  • 4-Pole Speakon output connector (2-channel models only)
  • Accepts a 4-pole Speakon connector.
Dec 31, 2008 | Crown XS900 2-Channel Amplifier
Computers & Internet Logo
225 people viewed this question
Top AMP Computers & Internet Experts
NOEL
NOEL
richie46
Tom Chichester
Are you an AMP Computer and Internet Expert? Answer questions, earn points and help others
