Question about Kenmore Elite HE4 Electric Dryer
Technical diagram I have contacted sears about the same FH error that comes on the screen of the washer. It has been three months and sears has not come to fix the problem. I called a local repairman and it was discovered that the technical diagram is missing. Is there anyway that I can get a copy of that sheet?
    President:
  • Kenmore Master
  • 2,651 Answers
FH is a code satinf there is no water entering the machine, check our water supply to the unit.
heres alink. use ghw9400 as a midel)its a whirlpool machine, i dont have acess ti the sears site. same tch sheet though)heres the explaination of the FH anyways:
If after 30 seconds the control does not detect water
entering machine, the valves will be turned off and the error
code will be displayed. OR If the control has turned the
water valves on and after 8 minutes the flow sensor has
detected 10.5 gallons of water passing through it, but has
not detected the pressure switch trip, the valves will be
turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
■ If there is no water in the unit:
—Make sure that both valves at the water source(s) are
turned on all the way.
—Check for plugged or kinked inlet hoses or plugged
screens in the inlet valves.
—Verify inlet valve operation.
■ If there is water in the unit:
—Verify drain pump operation.
—Verify that the pressure switch hose is in good
condition and properly connected to tub and pressure
switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves, pressure
switch, drain pump, flow meter, and Central Control
Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the
part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle
Posted on Nov 03, 2008
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Sear washer flashing fh
fh means full loud okay
Jan 24, 2013 | Sears Washing Machines
FH IS FLASHING ON THE WASHER AND IT HAD STOPPED WORKING ONLY 5 MNUTES INTO ITS CYCLE
The FH error code means the computer on the control board didnt detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the scrrens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced
GENE
Sep 11, 2011 | Maytag EPIC MFW9700S Front Load Washer
HE3t has an FH error code checked the following and are OK. pressure switch, flow meter, and inlet valves water flows in without restriction. What else could it be? Craig
Thank you for contacting fixya.com.
FH error code means low water inflow. In this error washer is not filling when the fill valve opens.
To clear the error please follow the bellow instructions:-
Press the "Stop" button twice with your finger. This cancels the cycle and stops the washer. Unplug the power cord from the wall outlet.Turn the water shut off valves clockwise to stop the water flow to the washer through the supply hoses. Pull the washer away from the wall enough that you can access the hose connections at the back of the washer.
Set a bucket under the area of the hose connections. Unscrew the hose connections from the back of the washer. If necessary, use a pair of slip joint pliers to help start the connections turning until you can turn them by hand. Set the ends of the hoses inside the bucket.Inspect the screens on the inlet ports on the back of the washer where the hoses connect. Sediment and other debris can block these screens, causing fill problems. Clean the screen with an old toothbrush.
Thread the hoses back onto the washer. Look for kinks in the hoses. Kinks cut off water supply to the washer which causes the FH error code. Once you connect the hoses, turn the water supply valves counter-clockwise to supply water to the washer. Move the bucket away from the washer and push the washer back into its working position.Plug the power cord back into the outlet and start the wash cycle again. If the FH error code comes up again, call a service repairman. If the hoses have no kinks and the inlet screens are clean, there is a problem with either the pressure switch or the flow meter.
Please get back to us if you have further query else please accept the suggestion.
Jun 02, 2011 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
F11 error code
The F11 code means there is an electrical with the Maytag Epic washer. This could involve wiring, fuses or a number of other issues.
Press the "Pause" button twice to stop the current cycle. Press the "Drain" button to remove any excess water. Try to run the washer again. If the F11 code repeats, shut the washer off and contact a service agent
The FH error code may be mistaken for the F11 code. The FH code signals a water supply issue and has nothing to do with electrical problems. Check the LCD screen to ensure you read the proper code
Dec 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
FH appears
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code
Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3
    Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
  • Dec 14, 2010 | Whirlpool Washing Machines
    Error code FH on my AWM, what does it mean?
    "FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
    Thank you !!
    Jul 12, 2010 | Whirlpool AWM8163 Front Load Washer
    Washer pauses and beeps, then flashes either FH or HF, can't tell. After pressing pause, it shows how much time is left. If I hit the start button, it starts back up, and eventually does the cycle all over...
    "FH" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. The following link explains how to troubleshoot:
    http://www.fixya.com/support/r3608753-fh_error_code
    This is one of those error codes that can be tricky to troubleshoot due to the many potential causes of the problem. My adivce to you is to eliminate the easy common sense items first, such as making sure the water taps are turned on sufficiently, the inlet hoses aren not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
    For the more complicated potential causes, each one of these washers comes with a technical data sheet inside.
    To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
    The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
    Read through the information provided and let me know if you have any further questions. I hope this can help you.
    Mar 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Washing machine won't start, after a minute or so screen flashes H then F then repeats
    This is one of those error codes that can be tricky to troublehsoot due to the many potential causes of the problem. My adivce to you is to eliminate the easy common sense items first such as the water taps not being turned on all the way, a clog in the drain pump, or a siphoning problem.
    Each one of these washers come with a technical data sheet inside. To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
    Feb 23, 2010 | Kenmore Elite HE4 Electric Dryer
    Washer is flashing F and H
    F11 and FH are two completely different error codes. "F11" is a Serial Communications error between the Central Control Unit (CCU), the Motor Control Unit (MCU) and/or door latch. The "FH" error is a No Water Detect error code that means the CCU is not detecting ANY water or INSUFFICIENT water during the fill cycle. The following two links explain each error code and some things to look for to diagnose your problem:
    "F11" Error:
    http://www.fixya.com/support/r3608695-f11_error_code
    "FH" Error:
    Read through the information provided and let me know if you have any questions. I hope this helps you.
    NOTE: There is a technical data sheet inside the washer that explains all diagnostics procedures, troubleshooting tips, error code explanations and wiring diagrams. To access, remove the lower toe panel under the door by locating and removing the screws under the bottom front edge. With the screws removed, the panel will drop down, then come off. You can prop the two front feet of the washer up for better access to the panel screws (a 2x4 works well for this). The tech sheet should be located directly behind the panel, or affixed to one of the cabinet interior walls. I hope this information is helpful.
    Jan 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore Elite HE4 Electric Dryer Logo
    139 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal De
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
