CanoScan lide25 - Getting error message when copying "cannot open file"
My scanner quit making copies, won't scan. I have deleted the files and reinstalled the programs from the disc that came with the scanner. I get the same message. Cannot open file. When trying the repair mode on installation, I got a message saying a file was locked. Didn't write down which one. HELP !!!!
  • 202 Answers
SOURCE: Tvichw32 Driver Open Error
Hello Aunt Pat
(01) Is this scanner "new" to the computer it is installed on now (where you're experiencing these issues)?
(02) Did this problem show up w/out apparent cause or relation to any recent changes on your system (e.g. New hardware or software installed, updated, upgraded or removed; system crash; computer repair; etc.)?
(03) Did the problem appear soon after a change to your system? (see above examples)
There are many references to this issue on the Internet. I've listed a few here. You can find many more, if you like, by performing search engine queries.
THIS links to a Roxio forum thread regarding this issue. (Even if you aren't using Roxio software, the information here could be relevant to your issue.)
THIS link will explain a bit about what TVICHW32 driver is.
I'd reinstall the ASPI drivers. A driver file may have become corrupted. (Assuming you'd been using this scanner successfully on this system until recently.)
You can find links for Adaptec's ASPI drivers on their web site HERE. They also have an ASPI version checker you can run to find out what verison is installed on your computer.
** Please, post back here w/ answers to
** these questions and the results of what
** you've tried. We may need to go back
** and forth a few times. We WILL continue
** to work w/ you until your problem is re-
** solved.
** Just be sure to not rate the experts' "sol-
** utions" until that time. Once you do,
** the problem will be closed and we'll no
** longer be able to assist you.
** Thank you @:)
Posted on Apr 10, 2008
SOURCE: Canoscan Setup Utility CD-ROM missing
i have a canon d646u and i have the same cd was what can i do? is there another way to pair scaner with pc?
Posted on Sep 07, 2008
SOURCE: need a driver for installing scanner canoscan lide 25
I ended up buying VueScan and it solves the problem. The scanner works great now. I heartily recommend it so you never have to work with Canon drivers again.
Posted on Oct 24, 2008
SOURCE: How do i save the image once i have scanned it on CanoScan LiDe25
it may be that you have to close the program - i had a similar problem at first but found it stores them all until the program is closed, then a window pops up with little thumbnails of all my scans (meaning you can continue to scan new images without apparently having saved them to the harddrive). This new window allows the user to untic whichever scans are not desired... there is a svae button at the bottom, and the svaed scans will be found in the Pictures folder in a sub-a folder with that days date as the name.
Posted on Feb 09, 2009
SOURCE: canoscan 9950F won't scan, says scanner locked, but it isn't
I was surprised by the same problem this morning. First time I've had a problem with in years. Checked the lock... it was already unlocked. I solved the problem by unhooking the USB cable from the hub, restarting my Mac (seems to be the key), replugging the cable and restarting the scanner. Worked like a charm. Hope it works for you!
Posted on Apr 11, 2009
My canoscan LIDE 100 won't make multi copies of my drawings!
The scanner itself does not make copies. You scan and then reprint as many times as you need with a printer. Make sure your image settings are suitable for your printer eg save as a jpeg or pdf file and then reprint that. If you are trying to make your system do a function it is not capable of, you need to change the way you are doing it.
Mar 02, 2017 | Canon CanoScan LiDE 90 Flatbed Scanner
Lide 60 not working in mountain lion
Guide to installing Canon CanoScan LiDE 35, 50 and 60 on Mac OS X 10.8. Mountain Lion:
  • If this is the first attempt to install the scanner, skip this part
  • Trash the following files/folders from these folders:
HD:/Library/Image Capture/Twain Data Sources
delete the CanoScan CanoScan XXXX.ds file
(Make note of any other files that may be in this folder. If other files are present, move them to the desktop for now. Then place them back after successfully using the scanner.)
delete the 'CanoScan XXXX' folder
delete the folders containing the name CanoScan, or starting with CNQL.
delete the CanoScan Toolbox Application
delete any items named "CanoScan Toolbox"
  • Restart your computer, then empty the trash
  • Make sure your scanner is well connected
  • Download the right driver depending on your Model. Also download the Scanner Software. Copy the filenames and search them via Google. Make sure you download the Canon files from an official Canon domain.
CanoScan LiDE 50 and LiDE 35 work both with the 35 driver:
CanoScan LiDE 60 driver:
VueScan Software:
VueScan 9.2 (or later) x32 for Mac OS X
Alternative to VueScan: CanoScan Toolbox. I prefer VueScan.
Try your luck with Version 4 or Version 5.
CanoScan Toolbox 4: cstbosx4934ej4.dmg
CanoScan Toolbox 5: cstbosx5014ej4.dmg
  • Open the downloaded driver file (lide35osx7721en.dmg or lide60osx11131en.dmg)
  • and Double-click the ScanGear file, install and restart when prompted
  • Open the downloaded VueScan file (vuex3292.dmg) and drag the VueScan application to the Mac Applications folder
  • Open the VueScan application. The scanner should be recognized automatically.
(Alternatively try and install CanoScan Toolbox 4 or 5)
Nov 04, 2012 | Canon Office Equipment & Supplies
If I try to scan or copy some files, it writes me: 'Error in scanner and follow instruction in manual. Scanner driver will be closed.(Code:201)'. Please help
copy and paste the link below to your browser...
Mar 01, 2011 | Canon CanoScan 3000F Flatbed Scanner
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
Can not scan. keep receiving message "unable to open file".
try to reset the file link (toolbox CS -> settinf -> save -> image file) where the scanned file will be saved.
Apr 16, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Link Scanned Image - Error Message on Canon CanoScan 500F
"Link Scanned images to..." refers to the programme you want to open the file. Navigate to the .exe of your preferred viewer
Mar 25, 2009 | Canon CanoScan 5000F Flatbed Scanner
Failed to open a driver
OK. Here is what you do. (I just did this on an Intel Mac running OX10.5.6)
First go to the cannon site and get the program (File name: deldrvosx1510en.dmg) to uninstall the drivers for your scanner. Also, delete copies of the scan toolbox that you may have installed in your application folder.
Then go back to the canon site for the LiDE 25 and install the drivers (file name: lide25osx11030en.dmg.) This part is very important, in the middle of the install a dialog will popup asking if it is OK to run something like deldvr, DO NOT ALLOW IT TO RUN, HIT CANCEL.
Install the canon toolbox software (it should be version 4.9.x not 5.0). File name is : cstbosx4934ej4.dmg
You should now be good to go.
What a %^#%$#-up process on Canons part.
Dec 24, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Trying to make a copy- worked last week?
This is most likely only happening when attempting to scan through the CanoScan Toolbox. You can scan directly through ArcSoft PhotoStudio which came with the scanner. However, the error through Toolbox is likely caused by some limitation or restriction in the computer, possibly permissions of some sort. You may try deleting temp files from the Temp folder on the hard drive.
Jul 15, 2008 | Canon CanoScan 4400F Flatbed Scanner
The Scanner's "Copy" program does not open
Try updateing the software. goto and download up dated drivers for you model.
Feb 15, 2008 | Canon CanoScan 3000ex Flatbed Scanner
150 people viewed this question
