Question about HP Office Equipment & Supplies
I keep getting activation lost from my HP3050A when i scan?
I have installed my Hp3050a deskjet and cannot get my scanner to work, i'm able to print and copy but when i scan i keep getting Activation lost. I does wirelessly see my computer and have checked that the printer is enabled on my computer
  • 47 Answers
SOURCE: scanner not set up
Have to uninstall and reinstall full software solution. First uninstall using the hp program, then use add/remove program uninstall Image zone, extended capabillities and HP update, restart pc and search for scrubber in Hp software it's in utility folder, ccc, doubleclick it to work. then you are ready to reinstall the fully software.
Posted on Dec 08, 2008
SOURCE: trying to scan, but keep getting error code
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
Posted on Sep 05, 2009
SOURCE: Printer and copier work fine- scanner says USB not connected.
I had this same problem and it is fixable, but not the way you would probably like, though you can still scan with the printer. You just have to open the Paint program and click from scanner or camera, and then choose your printer and click scan preview, and then scan, it works just fine but its a little time consuming.
Posted on Sep 21, 2009
SOURCE: trying to scan, but keep getting error code 2,162,0 My scanner pr
This works!:
noavatar_s.gif the_sunman
Rank: Apprentice
Rating: 94%, 4 votes
Posted on Oct 21, 2009
Xeea
  • 70 Answers
SOURCE: I have a Canon iR1600 network printer. Need scanning facility.
download the driver i will send u the link http://driverscollection.com/?H=iR1600&By=Canon
Posted on Mar 11, 2010
The printer doesn't print when you tell it to from the computer. When you mess with the buttons, then it will sometimes print a day later.
Its not a net work printer, they how you are connected this printer for all computers & laptops?. It might be connected to one system from there its shared..right. In this situation if any computer fired print command it has to reach the local computer where printer connected. If the local computer shut down, printer unable to print due to no print command.. or else if any net work related issue with in your systems you wont get prints.. Find out were you are stuck. If printer is printing well from the local system you cannot suspect the printer. Just you start from local system, then check in all systems. Pl get back to us for further remedies..best of luck..
Feb 04, 2012 | HP LaserJet 3050 All-In-One Printer
Dont know how to scan a document
The first thing that you must do is make sure that the device is already installed to your computer. Insert the document to be scanned on the scanner. Double click the icon of your scanner and on the option menu click scan. After the scanning process, open the My Picture folder of your computer and locate the image file.
Sep 02, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
How to scan using a hp deskjet F2235 printer???please help me...
In order to use the scanning feature you would need to install the drivers and other software that comes with the printer. If you haven't install either, please visit http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3571755
and download the drivers for your operating system. It should come with some sort of imaging suite that would allow you to scan documents and save them to the computer.
Jun 21, 2011 | HP Deskjet F2210 InkJet Printer
When i press scan the green power button just flashes and nothing happens.
Iam gicing two solutions- depends on your flexibility you can scan.
Solution 1:
Please try this procedure instead of press scan.
Download picasa 3.8 from http://picasa.google.com/
  1. Make sure everything is connected and turned on!
  2. Put the photo on the glass of the scanner - face down
  3. In Picasa, click 'Import'
  4. Click the arrow for the drop down list of devices. You should see your scanner listed ... select it
  5. Now you will see a screen that depends on your scanner. There should be an option to 'Preview'. Click that.
  6. You should now see your picture, there may be some settings you want to change here, but if it looks OK then
  7. Click the button to Scan
  8. When it's done scanning, you're back at the standard Picasa Import screen. Click Import all.
  9. Select a folder to put it in. I made a folder called 'Old Photos' for the first one, then, for each subsequent scanned photo, I selected that existing folder from the drop-down list.
Solution 2:
please download HP Deskjet Full Feature Software and Drivers from the below link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=3571753#N193
select your operating system then download full feature software and drivers and install .
then It will work when you press scan.
Even if it is not working there may be some hardware button problem...may be...
If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jun 09, 2011 | HP Deskjet F2210 InkJet Printer
I am having HP F-4288 Deskjet Printer All purpose. I have lost the Installer CD How can I download the drivers & the printer? I need to scan,copy & print regularly. Kindly help for Installation
Steps in downloading the driver
1. go to www.support.hp.com 2. enter your product name which is f-4288 then click next 3. click 'software and driver downloads' 4. choose your operating system then click next = to know your operating system just click start then right click on my computer or computer then click properties 5. click driver (1) 6. click 'HP deskjet full feature software and driver 7. click download then run
May 16, 2011 | HP DeskJet F4280 All In One Printer InkJet
The scanner won't scan to the computer, but when I test it in scanners & cameras it says it is working.
This is my solution :
1st step : Turn on your *HP Deskjet F4185*.
2nd step : Click the Start menu.
3rd step : Click Devices and printers. A new window will appear.
4th step : Then, click the "Fax button ".The window Fax and Scan window will appear.
5th step : On the lower left corner , click "Scan" below the "Fax" button.Scanned documents (if there's any) will appear.
6th step : Click "New scan" button below the "File" button. And your printer will start! Glad to help..
Mar 29, 2010 | HP DeskJet F380 All-In-One Printer
I cant access my printer to scan a document. what am i doing wrong?
does the printer have a scanner built on it? or is it a 3 in 1 printer? when you purchase these printer it comes with a installation disc for the printer driver and the software to use to these stuff, if the softeware is properly installed and there is no activity in the printer or scanner then have the printer check maybe theres a mechanical problem with in the printer/scanner
Nov 20, 2009 | HP DeskJet F380 All-In-One Printer
Cannot scan
you must be install your scanner driver or scanner software. If you see your scanner properties then you can get scane
Oct 23, 2009 | HP DeskJet F4280 All In One Printer InkJet
F380 hp all in one
This issue occurs if the scanning files are not installed properly. Once search for the hpqscnvw.exe file and try to scan from there and check for the result. If you are able to scan then download scan diagnostic utility from the hp.com and run it. If the issue persists reinstall the software.
May 20, 2008 | HP DeskJet F380 All-In-One Printer
315 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
