Whirlpool washing machine AWOD 6727 front loader service light on, prewash, wash, rinse hold, door open, start and F26 code flashing.r
Service light on, pre wash, wash, rinse hold, door open and start light on F26 code flashing also. what is problem ?
SOURCE: Front loader washing machine AWM 6100 Whirlpool
check brushes on motor. how old is machine?
Posted on Feb 01, 2010
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
  • 57 Answers
SOURCE: Whirlpool Front loader Washing Machine
MAKE SURE DOOR SWITCH IS MAKING CONTACT WITH THE DOOR OPEN THE DOOR PUSH SWITH WITH YOUR FINGER HIT START OR SEE IF LIGHT GOES OFF IF IT DOESNT THE SWITCH IS BAD
Posted on Jan 24, 2011
  • 6277 Answers
SOURCE: Our front loader Blanco washing
If it still has water in it I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 08, 2011
  • 6277 Answers
SOURCE: Our front loader Blanco washing machine gets to
Answered (hopefully) on your other posting ;-0)
John C
How do I get washing machine door to unlock?
The error F26 does indicate a fault in the door switch circuit. See the image below for a complete listing of what can cause this error. There is a door unlock error that would display if the door is not locking or unlocking but the F26 means the control is not seeing the door switch open and close. One thing to try first before scheduling service or replacing the part is to check the connections on the door switch.
Unplug the washer first and remove the lower access panel and reach up to the door lock and try to feel for the connections and make sure they're tight.
Jun 16, 2014 | Whirlpool duet Washing Machines
Whirlpool 3LCHW9100WQ Semi-Professional 9kg Washing Machine
Possible fault with the door switch or the control panel but you can try to open and close the door few times to reset after removing power.
click this link: error code F26
Oct 03, 2013 | Washing Machines
Whirlpool Front Loader WFS1071BW, rinse cycle problem
I had exactly the same problem with the same machine... I've seen a few people on various forums with the same problem. The problem on mine turned out to be just the EMI filter located next to the power cord inlet. I just bypassed it for now until I can get a replacement.
Apr 26, 2013 | Washing Machines
Error code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
Code F 35 i cant find my manual
christydubar --
Whirlpool Duet GHW91000 Technical Service Manual does list F35 error code. Try running the diagnostic test below and then write back with condition indication code. -- SWT
DIAGNOSTIC TEST
The control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the test mode
Close the door.
Press the Control On button.
Select the DRAIN/SPIN cycle.
Select NO SPIN by pressing the SPIN SELECT button, as needed.
Push Prewash Option button four (4) times within five (5) seconds. C:00 will show in the display.
NOTE: If Model does not have PREWASH Mode as an option, press RINSE/HOLD.
If the Starting procedure fails, push PAUSE/CANCEL button. Then repeat the starting sequence.
Test Program Control during Execution
To advance to the next step of the test procedure, push Prewash Option button two (2) times.
Indications
C:00
C:01
C:02
C:03
C:04
C:05
C:06
C:07
C:08
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
AWM6100/s door open light comes on shortly after starting
Bought a new washing machine. The motor had one of the coils open circuit and the cost of a new motor was nearly that of a replacement WM.
Oct 05, 2009 | Whirlpool AWM6100 Front Load Washer
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Brand new Front Loader not washing
well if its spinning and not washing, that does sound like aproblem with unit and not what your doing, id call a service company to figure it out, thats why you bought new, not so youd repair it
Mar 29, 2008 | Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
