Icos Ideal Boiler
Fires up for HW but not for CH
  • 104 Answers
SOURCE: ideal c80ff
differential is set too close and water temp set too low.dirty coil can have same result -how old is unit?
Posted on Nov 02, 2008
meBNme
  • 334 Answers
SOURCE: Central haeting ok but no hot water
If the valve runs at other times, the valve is OK. you have a relay somewhere that is not sending signal to the valve when in that mode.
Trace down all the relays for that cycle and check voltage going int, coming out, and to see if the coil is enrgised.
Posted on Jan 01, 2009
  • 13 Answers
SOURCE: blank display on ideal isar 2 he 30
may just be a defective display PCB, byt more often than not, its the more expensive main primary PCB. Ideal actualy modified this PCB, and has a pre-fix of VF on it, and is orange in colour
Posted on Mar 03, 2009
  • 234 Answers
SOURCE: Need free Worcester Highflow 3.5 user manual
http://www.worcesterbosch.com/
Posted on Mar 19, 2009
  • 30 Answers
SOURCE: combi boiler no DHW
if the boiler fires when the tap is opened then the diverter valve is working ok it must be a blocked plate heat exchanger which is the stainless steel rectangular block inside the boiler connected to the pump and the mains cold water.
it will be blocked on the central heating part probably with black scale. it is possible to clean out but sometimes it is better to just change the plate. but remember to flush the system as well or the same thing will happen.
Posted on Mar 30, 2009
Ideal icos 18 fault code HF
According to pages 47-50 of the install guide, section on FAULT FINDING, the alternating H and F indicates Flame Detection Short Circuit Error. Actions are: Remove flame detection electrode terminal from PCB. Test for continuity between 2 terminal pins? If YES, replace flame detection electrode. If NO, replace PCB. If you need more diagrams and full guide go to http://idealboilers.com/installer/wp-content/uploads/sites/2/2013/08/203318_inst.pdf
May 19, 2014 | Water Heaters
Ideal icons boiler fault code h1
ideal icos
H1 fault
FLOW THERMISTOR
part number 170917
check wiring to flow thermistor NOT loose first
Sep 16, 2013 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Ideal icons boiler keeps flashing h1
ideal icos
H1 fault
flow thermistor
part number 170917
i would check the wiring is secure to the thermistor first
Water to hot for gas boiler boiler gos off
It could be dyslexia, but I think you want to know what may be wrong with your boiler in this case!
This is a VERY old design. The diaphragm is on the water section, this operates a switch to turn ON the pump, and a further device causes the diverter valve to divert boiler water from CH duty to HW duty.
From your description it appears that the boiler is shutting down on internal boiler water temperature (too high), your 'briefly too hot' HW symptom may be caused either by the boiler side of the secondary heat exchanger being blocked/caked in sludge, OR the DHW side of it being scaled. Either way a new or replacement (descaled) secondary heat exchanger MAY inprove things. It's not easy on these old clunk-pots, and EVERY disturbed seal will subsequently leak, so get a good supply of o-rings and fibre seals before you start ("you" being the competant fitter you employ)
Dec 20, 2012 | Water Heaters
My lynx boiler is good on HW but no CH, what can I check for
Check pump is working , is diverter valve moving over to ch , is stat turned up is clock set on ch, is there air in the rads , is header tank full in loft if fitted , is boiler presssure right if a combi .
Sep 11, 2011 | Heating & Cooling
Jan 01, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
