Question about Intertherm P3RA-036K Air Conditioner
No heat when I switched thermo to heat,squirrel cage fan comes on but blows only cool air no heat.
  • Anonymous Mar 31, 2014
    Why is the a/c thermo fan staying on wether the air con is switched on or off the thermo fan stop when engine stops
    Novelist:
  • 124 Answers
Need to know if its a heat pump or electric strip heat. if its a heat pump then compressor and outdoor fan will run on call for heat. being an intertherm and most of them are electric strips, i'll guess. the call for heat sends 24 volts to the heat sequencer. lots of wires connected to what is called a stack switch. wires closest to the mounting plate are 24 volts and when energized they heat up a bimetal disc that clicks on in 90 to 160 second s and energizes the first strip and fan and a few seconds later the 2nd and 3rd strips kick in. for every strip operating you pull about 20 amps. if fan is working then the other parts of the sequencer are failing to close and put power to the strips or the strips themselves are bad. these are very very confusing and tricky to work with. i have to work on them hot to observe where the problem lies. very dangerous as you are going to have to trip a 90 amp breaker if you make a mistake , not to mention the parts are not available except through wholesale only supply house. i feel pretty confident the sequencer is going to be bad and i think its probably best you call a pro to get this one squared away. sometimes when you are tinkering with old sequencers they literally crumble apart in front of you, they can get that brittle. it can be quite an adventure and not for the faint of heart when its hot. good luck.
Posted on Oct 28, 2008
Rheem rgua-080c blower motor not blowing strong
just asking, Is the direction of rotation correct?Or is fresh air open? Fan cage on tight?Is the fan getting the power it needsto reach and maintain proper RPM (SPEED). chk the fan switch. Some have resisters incorated to control speedilica
_
Jul 18, 2014 | Ruud Rheem Squirrel Cage Blower Wheel...
Amana heat pump emergency heat comes on but blower will not start. The call for heat comes in and the heating element(s) glow red for a few seconds and then there is a "click" and the heating...
Check the blower motor capicator. It should be mounted close to the motor with 2 wires to it (brown,brown/white).
Turn the blower on the thermostat and spin the squirrel cage by hand and see if it runs after by itself. If it does then definitely the capicator is bad .If it still doesn't run then check to see if there is voltage going to motor.
If thermostat is calling for fan and there is voltage present at the motor terminal then the motor is bad
Jun 01, 2017 | Heating & Cooling
Centrifugal Switch Closed is what my Furnace is telling me and it will not kick on i have a Coleman Evcon heating and cooling unit
Hello, I had the same problem and replaced the Centrifugal motor which still did not fix the problem. It turned out to be the squirrel cage that the Centrifugal motor turns. It was sticking on the rubber gasket between the motor and the squirrel cage/housing assembly. I loosened the set screw that holds the cage on the shaft and moved the cage up 1/8th of an inch and it solved the problem.
Jan 13, 2011 | Heating & Cooling
Warm air in cab but not getting the required heat . thermostat is good , core is new . but no inside heat
squirrel cage (from what i understand is the name) could be bad. its essentially the fan type blade looks kind of like a hamster wheel could have stopped rotating and isnt blowing the air into the cab. also could be your water pump. if the blade on the pump is bad then it could be circulating enough water to keep the truck cool but not enough pressure to send it to the heater core to generate the heat needed.
Feb 22, 2010 | 1994 Chevrolet C1500
Air conditioner problems
change the thermostat for a more user friendly one
Aug 06, 2009 | Heating & Cooling
Air conditioner and heat blower
You will have two fans, one fan blows out the rear of the unit that cools the condenser soil, one blows out the front across the evaporator that blows the cold air out into the room. Some window a/c's have whats called a squirrel cage fan assy. that has one motor that runs both fans. So you either have one bad fan motor (the evap fan motor) or you have a bad fan blade that has fallen off the shaft. Also check the filter see if it is clean.
Jul 30, 2009 | Heating & Cooling
Running not blowing air
sounds as if fan isnt attached to motor shaft. There is a set screw on the fan cage that if it loosens the shaft will turn inside of the fan not turning the fan( also known as a squirrel cage) You need to get access to the fan motor and see first if its shaft is rotating, if it is see if the squirrel cage is turning if not the set screw located on the inner collar of the squirrel cage needs to be tightened. Thie set screw is more than likly an allen set screw.
Jul 07, 2009 | Heating & Cooling
Volume of air coming from a/c ducts is very slight
sounds like a bad blower resistor-thats why you have no speeds 1,2 or 3. the resistor will either be near the blower motor(the squirrel cage u spoke about) OR under the dash on the passenger side just above wher the passengers feet would be.it will have usually 2 screws holding it in and wires going to it.
Jun 27, 2009 | 2001 Pontiac Grand Prix
Squirrel cage installation.
If there is strong air flow blowing into the house the sq. cage should be OK. Possibly you need to replace the pads and make sure that the pump is not clogged and is distributing enough water to keep the pads wet.
May 05, 2009 | Mastercool 67680 Evaporative Cooler Air...
Intertherm P3RA-036K Air Conditioner Logo
196 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
