Question about Gateway Computers & Internet
Keyboard trouble none of the keys on my keyboard that correspond with the function key work I've tried to press the fn key & scroll which helped get the letters working but my up & down arrows, pgup/pgdn, & home keys are working in fn mode for example when I press the up arrow key the brightness increases down arrow it decreases when I press the home key my sound mutes & now that I'm typing this I'm finding that my letters switch to fn mode without me even having to press the fn key please help
  • 903 Answers
You need to reload that software that came with the keyboard. Uninstall the keyboard from device manager :- Control Panel>system>device manager. Then reload the software for the keyboard, which should also have the drivers. If you do not have the software, let me know the make and model of the keyboard and I will see what I can do.
Hope this helps
Posted on Oct 28, 2008
How do I control lock keys
The keys above the Function keys (Num Lock, Scroll Lock, maybe speaker volume or display brightness) will be in a different color than the white keys on your keyboard. Usually they will be blue or orange. There is a corresponding function key, usually left of your spacebar, that is in the same color, and it is usually labeled FN.
Press and hold the FN key and press the Num Lock key. Then release both of them. That should turn off your Num Lock.
Nov 01, 2014 | Computers & Internet
Where is the scroll lock key on my keyboard
Hi Mark,
for scroll Lock on your laptop try the key combination hold the Fn key and press the F12 to activate scroll lock, the same can be used to undo the Scroll Lock too.
as you will see that you can also activate most other functions with the Fn Key combination when used with the keys which have the functions printed on them in the same color as the Fn Key
for example Fn+F3 keys will toggle WiFi on or off, Fn+F4 will put the computer to Sleep, Fn+Up Arrow to increase Volume and Fn+Down Arrow to Decrease Volume etc.
hope this helps
warm regard
Apr 19, 2014 | Gateway NV53A24u Laptop
How to turn on numlk for gateway NE56R31u
You may have hit a certain combination of keys on your Gateway laptop and turned on the NumLock function accidentally. The result is that the rectangle of keys from the 7 key down to the question mark key have become a number-entry keypad. Worse, Gateway manuals don't discuss this function.
Hold down the "Fn" key on the bottom row of the keyboard, and press the "NumLk" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F11" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the F11 key and "Scroll Lk" key simultaneously. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F9" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "Scroll Lk" key. Type the letters UIO. They should come up as letters. If none of these help, then it's probably a keyboard malfunction and you'll need to get it repaired.
Feb 17, 2013 | Computers & Internet
HOW TO DEACTIVATE TEH Fn KEY IN DELL LAPTOP
Hi names Rui, to turn Fn in you dell you need to:
1. Open your laptop and turn it on. Then locate the Fn key. It is located on the lower left side of the keyboard, next to the Ctrl key.
2. Press and release the Fn key. Now examine the keyboard carefully. You'll notice that many of the keys have icons or letters and numbers printed in blue upon them. These keys and functions are operated when the Fn key is enabled, as you've just done. Test it out by looking at the lower right side of the keyboard. You'll see two keys with small blue "sun" icons. These control the brightness of the screen. Press the lower one several times and you'll see the screen darken. Press the upper one. The screen brightens.
3. Press and release the Fn key again. Now try using the brightness keys. The screen brightness will not change. You've turned off the Fn key.
The Fn key (also known as the Function key) is a feature found on most laptop computers. The Fn key allows keys on a laptop computer's keyboard to serve more than one function, a clever way of increasing the utility of the keyboard when space is limited. Dell laptops make good use of the Fn key, and if you own a Dell laptop, you should be aware of where the key is and how to use it. So i hope this will help you.
Jul 20, 2011 | Dell Vostro 1510 Laptop
Somehow I have enabled the scroll lock on my Studio 1537. There is no scroll lock key so what keys together will unenable the scroll lock.
It should be on one of your function keys you might have to use your FN button which when you find the scroll lock on the function key ( press and hold the FN button which is located bottom left side of the keyboard and then press the function key that the scroll lock is on )
May 09, 2011 | Dell Studio 1537 Laptop
I have a new HP keyboard which seems to have three or four choices for upper and lower case. For instance, the number 6 key has a choice of 6 or ? or several other designs likw an arrowhead which I cannot...
Keyboards can have various functions for each key that are enabled by first pressing a modifier key. Some keyboards may have an Fn key that stands for 'Function' that are identified by a bluish-purple color.
You would have to hold down the Fn key before being able to use the corresponding function.
Other keys may have items that can only be used once you press the NmLk (Number Lock) key. Usually you only have to press the NmLk key once to enable these alternate functions and then press it again to disable.
Mar 12, 2011 | Computers & Internet
Can you tell me how to switch my laptop keyboard
Hold function (Fn) key down and press the key on the top row that has a sign (picture) showing a padlock insde a square. (Num lock key) Normally "scroll" key
Apr 02, 2010 | Gateway 2520915 Keyboard
How to use the Fn funktions on a ThinkPad T41
Each combination Fn-F1, Fn-F2, Fn-F3, etc. does some thing different.
Try and see what each does. For more details read your manual.
Good Luck
Sep 01, 2009 | IBM ThinkPad T41 Notebook
Keyboard stuck in Fn mode
had the same prob on my laptop which doesn't have a seperate number pad so all I needed to do was to press "Num lock".
Apr 04, 2008 | Balance CN6555 Notebook
Function keyboard turned on advent QT5500
Hi
Try this my friend,
Press F12, Num Lock, and FN at the same time.
OR F12 and Num Lock/ Scroll Key.
OR Hold the Ctrl and Fn key down together and press also
the Ins(Num LK) key.
Post me whatever the result is... so we could Fixya the problem.
Feb 03, 2008 | Computers & Internet
Computers & Internet Logo
351 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
