Question about Bosch Washing Machines
Bosch Avantixx 7 washing machine keeps coming up with code CL - why?
Machine loaded and will not start because error code cl is showing?
  • 1294 Answers
SOURCE: LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
Posted on Jan 06, 2008
SOURCE: CL ERROR
"CL" means Child Lock. Press and hold RINSE+ & PRE WASH Simultaneously for about 3 seconds to de-activate.
Posted on Jan 23, 2008
SOURCE: LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
Hai Idiots
ITs on CL (Child lock)
This occurs only if the power is turned off during the washing period
Press the TEMP and OPTION together for 3 seconds and it will go off
Amber
Posted on Nov 11, 2008
SOURCE: LG WM-1285FHD Error Code 'CL'
The "CL" code is not an error! This means "Child Lock"!
To unlock a washing machine you will press and holding within 3-5 sec two button, marked "child lock".
And happy day will come! :))
Posted on Dec 19, 2008
  • 351 Answers
SOURCE: CL error message
That means that your washing machines child lock is on. You can find two buttons Temp and Options in the panel. Turn the machine on, press these two buttons together for 3 seconds and thats should be it.
Posted on May 09, 2010
DLG2351r model LG front load dryer wont start also says CL
It seems as though your machine's door switch is faulty as the machine will not start if this switch does not operate properly.
The reason that I suspect the door switch is because the CL error code stands for "child lock".
Check the door switch for continuity and condition, replace if faulty.
Oct 03, 2014 | LG Dryers
What is the error code CL mean for LG WM1285FHD
LG washing machines indicating error code CL may have the child lock activated.
Try holding down the temperature and eco/rapid options together to turn off child lock.
Some LG series use "TEMP and OPTION" at the same time.
Thanks
Oct 10, 2011 | LG WM-2277HW Front Load Washer
Washing machine is showing error code CL
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. The fault specified seems an over load or over current in the motor. So remove motor and check to confirm.Make sure there is no jamming of the aggitator or the drive, and too much of load. Power off and reset.
Thank you for using fixya.
LG error codes
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6333
Sep 23, 2011 | LG WD-80130F 7.2kg Washing machine
On an LG front loading washing machine, what does the code CL mean?
Hi Emma Haigh,
CL means Child Lock, please follow my below Tip on how to remove the setting:
L.G CL ERROR/CODE
Kind Regards
JEDMEYER1
* If you found this solution helpful, please rate it
Aug 01, 2011 | LG Washing Machines
ERROR CODE CL for a Westinghouse front loader Model 708
Hi, cl means that the machine is over loaded, push stop clear to clear then try again with a lighter load....
Take care
Jun 15, 2010 | Siemens WE61021GB Front Load Washer
Cl is showing on display and machine wont work
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Feb 26, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Washing Machines Logo
3,783 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
