Question about Brother DCP 115C All-In-One InkJet Printer
Waste ink tank / absorber
Where is the waste ink tank / absorber (is there one for each colour ?) and how do I get to it (them) to empty / clean). Have reset the purge counter and 'Unable to clean' has gone (thanks everyone who posted instructions) and printer working fine but am worried about the waste tank(s) which must be filling up.
  • chaz_forde Oct 31, 2008
    I was told by Brother that 'Cannot Clean' (fault 460) means that the absoption pads needs to be replaced. Their sponsored engineer estimated a cost of about £80 to replace the pads although the 14 months old machine only cost £40 new and was used about 12 times. Can you please inform me where I can buy absorption pads for the Brother DCP-115C printer & how I can access the old ones on the machine? ThanksR. Forde
You need to dismantle the printer by opening the scanner lid, pinging the blue arm out of the white retainer with a screw driver, flip the scanner lid right over onto the desk on the LH side of the printer - it will come off its hinges for this. lay it lid down on the LH side of the printer - be careful not to snap the power and data cable connecting with the base. Next you have to remove the 4 retainer screws in order to remove the plastic cover over the rest of the base. The pad and ink box are at the rear on the right hand side.
Posted on Dec 06, 2009
Message about ink asorber full keeps appearing
When the printer is not being used, the print-heads slide to their "resting" position,
in order to keep the ink-jets moist, i.e., to NOT dry-out.
Some ink is absorbed into that INK-ABSORBER.
Now, after a few years of usage, that ink-absorber is "full".
Like taking-out the garbage from your kitchen waste-basket when it gets full, and replacing the full waste-basket with an empty waste-basket, it's time to get your printer serviced -- replace the "full" ink-absorber with an "empty" ink-absorber.
Note that CANON printers do not actually "measure" the fullness -- they electronically estimate the fullness, given information about how much you print, and how often you print, and the "density" of the pages that you do print (text is much less dense than colour-photos).
Mar 09, 2011 | Canon PIXMA iP1600 Printer
Pixma MP 130/110 Printer/Copier/Scanner waste ink absorber full, It neither prints nor copies
Cleaning the waste ink pads is easy.
Are your ink tanks empty and have you been using non Canon cartridges?
Regards,
Worldvet
Aug 01, 2008 | Canon Office Equipment & Supplies
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
Waste ink tank reset
Google is your best bet for a question like that, where did you get the instructions to reset the waste ink absorber?
Look there also
Jul 18, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
5) Select OK
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink error message, now the printer won't print until the waste ink tank is emptied or replaced.
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Jan 11, 2010 | Canon PIXMA iP90 Mobile Printer
Ink colour print problems
Ink that leaks out of the ink-cartridge when the print-heads are "parked" is absorbed into the "reservoir" tank. The tank is full. Get it emptied.
Sep 14, 2009 | Canon i9100 InkJet Photo Printer
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
Ink waste Absorber
you are correct about the waste ink tank,did you check the pipe (if any)which use to carry the ink to waste tank,if it is clogged than also the problem will arise.
Mar 31, 2008 | Canon PIXMA iP2000 InkJet Printer
Immovable Cartridge & Printing problems
try to remove the front cover of the printer is 2 screews or 3 and a few clips and whit a clean cloth absorb the waste ink from the waste tank, and this is o quik fix that i use.
Oct 18, 2007 | Office Equipment & Supplies
Brother DCP 115C All-In-One InkJet Printer Logo
1,352 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
