Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Can't close my garage door - Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
  • tybeeal Feb 21, 2009
    chamberlain liftmaster garage door will open, and the safety reverse works. However, when fully open, will not close - either remote or direct. The indicator lights on back of unit suggest trouble with reverse. Any suggestions?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
If you have a Craftsman/Liftmaster can you push and hold the wall button to make it go all the way down? If you can than photo eyes are your issue. Check and see if they are both lite.
Posted on Jan 04, 2009
Why would a Craftsman model 139.53985DM garage door opener not open when it is cold outside?
Safety light issue. Blocked beam. Misaligned beam. Or broken wire.
Mar 03, 2015 | Building Materials
Linear garage door opens and closes when close to unit about 10 '
when the door stops moving when going down, pull the emergency release handle on the door and then push the door closed by hand. Once it's closed push the emergency handle back so it engages the chain. Open the door and close it a few times to make sure it closes all the way with the motor.
Oct 01, 2014 | Linear Corporation Linear Garage Door...
Craftsman 1/2 H/P garage door opener door goes closed but then opens
Try adjusting the "closed switch" forward a little in case the door is going too far when trying to close.
Sep 03, 2014 | Building Materials
My liftmaster will not close the garage door
Photo cells "safety beams" not aligned or bad, holding wall control will allow you to over ride them.
Jan 24, 2013 | Home Security
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I...
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Jun 06, 2011 | liftmaster Garage Door 1/2 Hp
Garage door only closes halfway
If the main light is flashing 10 times when the door reverses when closing it is a door sensor problem. You can override this with the door control but not with a remote. Make sure the door sensors are pointed at one another and the small light on each one is on and not flickering.
Jul 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have to hold the push button inside my garage to close garage.
You have a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not blinking. Also check the wiring.
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
1,056 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
