Question about Samsung CLP-510 Laser Printer
Samsung CLP-500 problem
I have error massage "Invalid New Toner Black Magenta" ! Please help me!
  • tmach Oct 28, 2008
    yes, but I changed resistors of that cartridges.
  • Coss May 11, 2010
    Did you just replace toner recently?
    If so, was it a factory cartridge?
    Genius:
  • 1,056 Answers
Resistors? You mean the smart chips?
Here's something I found over the last few years of dealing with these newer laser printers.
Say for example you had a 13,000 page factory toner, you replace it with a 20,000 page aftermarket refill, but you trade off the chip. There are small case triggers that read the toner size (I still haven't figured if it's internal or external) The chip is programmed for a specific cartridge size. The carts don't match, the chips won't work.
Also, certain printers will recall chips that have been used, and won't let you reapeat chips until you have gone a certain number (like it has to have 4 or 5 different chips before you can reuse the first chip).
So options to get around it.
I found in the Dell printers, if you go through the menus, there is a setting that allows you to bypass using factory cartridges, I don't know if Samsung has the same menu settings, but it's worth digging through the layers.
2) Put the chip that came with it back in, and see it it will work.
3) Break down and buy a factory cartridge. I know this is the least attractive option, but it will determine if it is a read sensor, a firmware/software error, or something else.
The whole smart chip imbedding happened about 7 years ago as a settlement on a lawsuit.
Posted on Oct 28, 2008
I have a samsung clx-3160fn printer I replacEd blk toner and it keeps sayn invalid toner .... I even refilled old toner and same error... Invalid toner
I have the same problem in a CLP-300. I have tested 3 diferent aftermarket chips from different manufacturers and always the same message: "invalid black toner" and the black toner light keeps red
Sep 21, 2010 | Samsung CLX 3160fn All-In-One Printer
Invalid New Toner
You may need to get a new chip on the toner tray. If you go to the place that sold you the toner, they likely have the chip that you need.
May 20, 2010 | Samsung CLP-510N Laser Printer
Clp-500. toner streaking the paper.
I have the same streaks problem. Any solutions?
Nov 14, 2009 | Samsung CLP-500 Laser Printer
Instead of changing black toner printer (samsung clp-510)is giving error INVALID TONER BLACK
This can happen if you install a CLP-500 cartridge OR a Xerox Phaser 6100 cartridge.
Physically they are the same, but the 'chip' is different.
In the case of the Xerox, it is the programing of the chip that 'tells' the printer its a Xerox cartridge, and the printer won't accept this as valid.
If it's a CLP-500, the three contacts on the side of the cartridge have a resistor (for the capacity of the cartridge) and a falmeproof fusible resistor which resets tha page counter (for that cartridge) when a new cartridge is installed.
Oct 15, 2009 | Samsung CLP-510 Laser Printer
Toner exhaust yellow toner
samsung clp color leserjet printer writes this massage toner exhaust yellow toner. i have done the toner refil without the reset chips about two times now and i have been printing for some time now i get the message "toner exhaust yellow toner"
Oct 01, 2009 | Samsung CLP 315 Laser Printer
is it a genuine toner?
some printers will not work with certain "reman" toners.
Dec 10, 2008 | Samsung CLP-500N Laser Printer
CLP-500 vertical streaks & a horizontal line with blotches appearing randomly
I've refilled the toner cartridges a few times now and never had a problem with vertical streaks until recently. I refilled both the cyan and magenta and when I ran the test page I had dark vertical streaks on both sides. I fiddled around cleaning things, running cleaning paper through, changing reset resistors but to no avail so eventually decided to buy a replacement refurbished cyan cartridge since the streaks looked mainly blue and bingo... well almost now I just have very light magenta streaks. The issue is obvious when I compared the old and new cartridge, the replacement toner is a much duller cyan and is of the wrong consistency since once it's been in the printer everything gets covered in it which is why I think it causes the banding to occur. I'm just trying to work out now whether to try refilling the magenta again (v. messy) or just go for another refurbished cartridge (£34).
Jun 12, 2008 | Samsung CLP-500 Laser Printer
Samsung clp-510n printer
1 Could be toner on the contacts (inside the printer) that mate with the contacts on the cartrdige.
2 Are you sure they are 510 toners and not 500 ones ?? 510 toners have a chip that identifies the cartridge (Colour, Capacity) and maintains a count of the pages printed.
500 toners have a reset fuse that resets the toner counter in the printer, and a resitor that identifies the capacity
3 Are they new cartridges, remanufactured, or 'home refiled'.
if either of the later two, were the chips replaced ? - if not the cartridge still thinks it has printed its full life of pages.
Nov 28, 2007 | Samsung CLP-510 Laser Printer
Samsung ClP-500 install cyann toner
Please take your unit to an Authorized Service Center ASAP. Do not tur on the unit again. That burned fuse means that the temperature sensors inside the printer (thermistors) are not working correctly and the unit is overheating.
Oct 23, 2007 | Samsung CLP-500 Laser Printer
Samsung CLP-550 - magenta bands
I have the same problem. Any solution?
Dec 19, 2006 | Samsung CLP-500 Laser Printer
Samsung CLP-510 Laser Printer Logo
245 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
