Question about Nokia 2760 Cellular Phone
My Nokia 2760 battery charge decreases gradually even after charging till battery full comes.. Now i have changed my sim card to another mobile and the same problem arises with the other mobile too
I changed my sim card to Nokia 1100. Till 4 or 5 hours after placing the sim card in that mobile there was no problem.Then i attended a phone call , after this batter indicator showed battery Low status
  • 380 Answers
It is not a sim problem
it is the problem if the batterry
you have to change the battery
Posted on Feb 25, 2012
My nokia 2760 not powering and not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 12, 2012 | Nokia 2760 Cellular Phone
Unlock code for nokia 2760
Hi, You can get the unlock code for a Nokia 2760 from www.prounlocking.com/nokia-2760/rs8wp9/ at affordable cost. Here are the steps for unlocking a Nokia 2760,
1 - Switch on your Nokia 2760 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2760.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2760 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 2760 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
Sep 26, 2012 | Nokia 2760 Cellular Phone
My NOKIA 3110c phone got switched off by itself and has not come alive. If I try to switch it on, the screen blinks white thrice and then goes dead again!
Firstly, Remove Sim Card , Memory Card and try to reboot 3-6 times,sometimes this trick is working.Even if the problem still persist better to contact mobile repairing shop or follow the procedure below.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 23, 2011 | Nokia 3110 Cellular Phone
Need instructions and restriction code to be able to use abroad with local sim card
Restriction is nothing but the unlocking for your mobile,
unlocking means in your phone just removes the SIM card restriction on your phone so that you can use any other network's SIM card.
To get the restriction code for your Nokia 2760 model mobile, just visit this site www.unlocking4u.com/nokia-2760/rs6wp9,in this site just give your IMEI number , country & network lock after that within a short period you can get the restriction code for your nokia mobile with step by step instructions............I hope this may helpful to you.........
Aug 08, 2011 | Nokia 2760 Cellular Phone
The phone gets off itself even if the battery is fully charged gets hang. doesn't allow any application to run may be there is a virus and yes it works well when there is no sim inserted in it
Its not any virus. Your sim card is defective. Go to your network service provider and replace your sim card with a new one and your problem will be solved.
Nov 02, 2009 | Nokia 2760 Cellular Phone
My Nokia 2760 seems to restart itself about every five-ten minutes. This means i cannot access messages or basically do a thing. Won't charge properly or anything. Tried taking the battery and sim card out...
The same thing happens to mine about every week or so. I take out the sim, and restore the phone to factory settings, including deleting all files. This is a pain, but does get the phone operational again.
Jul 20, 2009 | Nokia 2760 Cellular Phone
The phone nokia 2760H it comes on then shuts off,what is the problem? battery?sim card? or the cellphone?plz tyvm
Charge your battery if does not works replace battry it is over charged and needed to be replaced.
Jul 14, 2009 | Nokia 2760 Cellular Phone
Motorla Slvr L7 Won't hold charge
nokia mobile phones has maximum charge holding capability.motorola phones consumes more charge if we use mp3 player in it.are you a continuous user of mp3 player then try to decrease it
Jan 15, 2009 | Motorola Mobility SLVR L7 Cellular Phone
1600 not charging
Either your sim card is not seated correctly, the contacts are dirty, the sim card is dead, the copper contacts in the phone do not reach the sim card or the electronics in the phone are faulty. Try to change a new battery' check the battery terminal contact'.
sometimes is not properly alligned' or maybe your battery is loose in tha back houssing of your phone.
Nov 11, 2008 | Nokia 1600 Cellular Phone
China Make N95
dear,
charge the phone with its own charger. dont use universal charger or other nokia mobile charger. china mobile have this problem. so charge the battery with the charger that came with it. hope ur problem will be solved.
regards,
Jul 23, 2008 | Nokia N95 Cellular Phone
Nokia 2760 Cellular Phone Logo
245 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
