TV not working just making some funnig noise - Televison & Video
    Genius:
  • 2,920 Answers
Its probably time to replace the set
Posted on Oct 28, 2008
Tv just started making a very high pitched noise, although picture and sound are fine?
Barb, noise may be from a power supply/ transformer on it's way out.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HELP what is that high pitched noise when tv is on
Is your LCD making buzzing or high pitch noise
Mar 04, 2016 | Sanyo Dp55441 TV
Free tv repair advice
The noise you hear must be from its back-light inverter board. The ferrite core in the inverter transformer may make a high whistling noise and will be annoying. Contact any technician. It can be stopped by gluing. But is a skilled work.
Apr 23, 2013 | LG 60PV450 60-Inch 1080p Plasma HDTV
Tv went off/black and it now makes a "blinka-blinka-blinka" noise inside when plugged in?
The horizontal output section circuit to your TV has some shorted component/s. you have to replace them. Contact any experienced service technician. This is a very skilled work.
Oct 03, 2012 | Curtis CM36020S 36" TV
TV is making a loud ear piercing noise.
Ur high voltage is going through FBT,the big black block of plastic with a wire red or gray solder to the board.The Flyback transformer.There a steel "3 inches like a paper clip like steel.Put some supper glue on that "3 steel paper clip look like, will help or stop loud wishling noise all together.
Apr 21, 2010 | RCA HD52W59 HDTV Projection Television
DVD player in 1913-TDXB makes noise and won't allow TV to operate. First the DVD player quit working and now it makes a clicking noise when the set is turned on and set won't go past the DVD. Can the DVD...
Take the tv aparts,take some Q tips with some rubbing alcahol clean the DVD laser eye.Should help the DVD player side to work,than the tv might go in to the functional modes.
Apr 14, 2010 | Televison & Video
My tv is making a loud roaring noise in the back
I had the same problem, it was the color wheel (part # 270916). The bearings go and it starts making noise. It was fairly easy to replace.
Jan 16, 2009 | RCA HD50LPW175 50" HDTV
Shuts off by itself, then makes weird noise in back of TV
have a tech check your flyback conection in side the set some times thay come loos during shipment.
regards
daniel.
Jan 05, 2009 | Sony KV-32S42 32" TV
My TV is making cracking noise
Its the plastic cassing making the noise. If you press the tv together along the edges you will here a crack. Samsung and others did not use 99 cent padding between the plastic and the metal you need cushion padding. Its like not using a gasket or seal. Its a simple fix but the tv companies say its expansion.
Oct 30, 2008 | RCA 14F512T 14" TV
Runnig very hot
kindly change fuser unit
May 18, 2008 | HP LaserJet 6p Printer
High Pitch buzz noise when plugged in and it doesn't turn on
The tv has a shorted component and that is why is making the noise,call a qualified technician to find it and dont try to use it anymore.Is not a fuse.
Sep 12, 2006 | RCA F25649 25" TV
Televison & Video Logo
Top Televison & Video Experts
