TELEFUNKEN AIRCON PROBLEMS
My Telefunken Split unit aircon is flashing either CF or CL after it has been switched off. It seems to be working perfectly. What does this mean?
  • 9 Answers
SOURCE: TCL split sytem aircon has an error faults ER
Try tcl website
Posted on Mar 13, 2009
  • 400 Answers
SOURCE: WATER LEAKING FROM MY SPLIT TYPE LG AIRCON
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Posted on Mar 19, 2009
bobicehouse
  • 1524 Answers
You have a clogged drain.
Posted on May 23, 2009
  • 17 Answers
SOURCE: TOYO TA-09CHS aircon problem
Okay, let do this;
Turn unit On and go out to condenser unit and see if the cooling fan motor is runing and strong.
I sure you cooling fan motor is not working.
Once the comoressor protector detected over heat it shut it seld down.
nguyen@ite.net
Posted on Jun 09, 2009
SOURCE: ERROR CODE CH5 AIRCON SPLIT LG
we have some problme we have need a help please helpe us when we turn on air conditon its gave us error (E7)
Posted on Feb 21, 2010
My Telefunken Split Unit Aircon model TAS 120B flashes "CF" after it has been switched off. What does this mean? It seems to be working well with no visable problems. It is only 4 months old.
telefunken tas120 airconditioner runs for 30 minutes and then switches off for 5minutes and then keeps on switching on and off at shorter periods. I have changed the sensor with my other machine of the same make and model but although it works in the one machine it has not solved the problem. What other part can I swop.
Thanks
Mar 25, 2011 | Heating & Cooling
My LS-H186 VML 1Metal Art Cool 12000 BTU Air Con does not heat up
You should also check the outside unit to make sure the coil is not clogged with dirt or grass clippings and the fan is working. The reversing valve that switches it from cool to heat could also be a problem. If it isn't shifting it will not switch between heat and cool.
Apr 29, 2010 | LG Art Cool LA181CNW Split System Air...
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Telefunken TAS 180E aircon unit, After startup the unit runs for
have 9000btu recently changed the compressor,cleaned the system,installed a drier,runs for 2days and start icing up on the
discharge,like it short of gas ,stop the unit for a while check the gas its shows 390kpa.what could be causing it not to work properly
Dec 31, 2009 | Heating & Cooling
I have split system aircon model no ese21hra wont
You should change the remote sensor receiver unit on the unit.
Nov 14, 2009 | Heating & Cooling
Vw sharan tdi cl 96/97 model,does this model have aircon
sharan aircon front fan not working. Fuses 15 , 20, &21 working ok. please help
Jul 05, 2009 | Heating & Cooling
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
