Question about Hardware & Accessories
Insructions for grasslin Electronic timer STA-E
Setting the clock
5 Suggested Answers
SOURCE: I need instructions on how
Open following links for analog timer instructions:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FM
FM1STUZH-120 is 120Volt 24 hour timer with manual override button.
Each tripper-or-pin on timer dial represents 15 minutes.
The timer can be set for several different purposes.
Since the timer has manual override and NO NC terminals, the best way to proceed is to wire your timer, turn power ON, move 10 trippers-or-pins outward, leave rest of pins inward, then manually rotate dial to watch when load turns on-off. Then move override switch to each of 3 positions and repeat same test.
These actions will reveal correct wiring and switch setting for your purpose.
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jun 05, 2011
SOURCE: grasslin timer doesn't display and it ticks
Grasslin Tactic timers have reset button as last step troubleshoot.
http://waterheatertimer.org/pdf/Grasslin-Tactic-371.pdf
Replacement timer is Tactic 771 Plus
http://waterheatertimer.org/pdf/Grasslin-Tactic_371_Plus_X20.pdf
Posted on Jun 12, 2011
SOURCE: grasslin pin timer how to
Open following links for setting analog timers including Intermatic FM1 series
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#FM1
Posted on Jul 09, 2011
SOURCE: the clock dial on my
I don't know what the 2:00 o'clock arrow is.
KM series Arrowhead is located to right side of timer dial.
To set clock, manually rotate timer dial clockwise until current time lines up with arrowhead
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#KM
If this is not your timer, then add a comment with description of timer for possible help
Posted on Jul 24, 2011
Hi i have a grasslin bath timer with a dial clock,how exactly do I use it?
Dial clock ... experiment by rotating dial clockwise several times to see what turns on-off.
Step by step for analog timers on following link
Gene
Water Heater Timers Save Money
Feb 28, 2015 | Hardware & Accessories
Grasslin Intermatic pool timer turns on and off randomly
did you change the base out or just the clock?? it could be shorting out threw the base
May 29, 2014 | Intermatic Grasslin Pool Time Clock 24hr...
Grasslin ecosave timer not working
Add a comment and say if the timer worked before and stopped working, or if this is new installation that does not work correctly.
Otherwise the timer expert is guess that the problem is incorrect wiring, defective timer, tripped circuit breaker, or if the clock motor has gotten weak over time, and stopped working.
Or, Contact Grasslin UK:
http://www.grasslin-controls.co.uk/ecosave.html
Aug 25, 2012 | Hardware & Accessories
The clock dial on my grasslin analog timer does not correspond to the time on the "2:00" arrow. how do i realign the clock dial to be in line with the arrow?
Jul 23, 2011 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
We have installed GM40 time. which control shaft on / off cycle i.e 4 hours on / 2 off. i checked selector switch postion, i.e continuous on (upper position) and continuous off (lower position) in this...
I have GM40 timer sitting in front of me.
I cannot understand your question because I do not know what the 'control shaft' is.
If you mean the black-colored FM1 clock dial with captive trippers, then this dial is supposed to rotate continually as long as timer has power.
http://waterheatertimer.org/images/FM-1-Grasslin-Intermatic-20.jpg
Grasslin/Intermatic GM40 page
http://www.intermatic.com/products/grasslin/electromechanical%20time%20switches/multi-voltage%20time%20switches.aspx
The manual says quote:
With the manual switch in the middle position, the GM40 is in automatic mode and will switch at the programmed times. In the upper position "I", the load is permanently ON. In the lower position, "O", the load is permanently OFF. End quote.
In any switch position, the FM1 clock dial will continually rotate.
If your Load does not turn on-and-off according to the trippers set on FM1 clock dial, then 1) wiring is suspect or 2) if dip switches are not correctly set before applying voltage, and timer could be damaged.
The timer arrives with dip switches pre-set for 277Volts.
You can also manually rotate clock dial clockwise to observe when the load turns on-off.
Add a comment and give more information.
I would like to know what the 'control shaft' is, and what voltage you are using, and what dips switch setting you have, and which wires are connected to each terminal.
Apr 13, 2011 | Intermatic GM40 - 24 Hour/7-Day Dial...
I do have and Intermatic ET724 timer and it has stopped working. I don't think it works with battery as it is attached to our bathroom light switch . any luck to fix it? or it is time for a new one??
That's a good old timer.
Grasslin ET724 in-wall timer is no longer available.
http://www.amazon.com/GRASSLIN-ET724-Grasslin-Et724-Electronic/dp/B000BHCFT6
There are several programmable timers on the market.
Intermatic EJ500 is simple to install and program. Works on battery but is for incandescent light only, not for fans.
http://www.amazon.com/Intermatic-EJ500C-Indoor-Digital-Switch/dp/B000E8VAIO
GE 15071 from Home Deport is inexpensive replacement and works with fans, lights.
Needs no battery. Uses electric circuit to operate clock.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
More timers:
http://waterheatertimer.org/Programmable.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 20, 2011 | Intermatic ET724-A-CS - 24Hr. and/or 7-Day...
Grasslin timer instructions
Grasslin timers and manuals
Click timer-categories on left to see drop-down menus
http://www.intermatic.com/products/grasslin.aspx
Grasslin electronic time switch
Click on model number and drop-down menu shows manuals
http://www.intermatic.com/products/grasslin/electronic%20time%20controls/electronic%20time%20switches.aspx
Oct 11, 2010 | V, Inc. 12v Dc Timergeneratortransfer...
Hardware & Accessories Logo
198 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
