Question about Numatic Henry Bagged Canister Vacuum
How do you change the carbon brushes on a henry hoover
4 Suggested Answers
  • 64 Answers
SOURCE: How to change carbon brushes on henry
the brushes are easy to change, follow the directions in your book.
Posted on Nov 01, 2009
SOURCE: my hoover smells of ammonia
I too have a problem with a bad smell coming from my henry hound hoover, but thats probely because i haven't used a hoover bag. I took the cloth filter out,banged all the dust off, then sprayed it with 'RugDoctor' pet stain remover for carpets and upholstery. It still smells a bit, but not half as bad as befor. I have now ordered a reusable,zipable,washable cloth hoover bag especially made for Henry's. It cost £8.80 from ebay with free postage. Hope this helps Nikki.
Posted on Nov 21, 2009
clean it out da
Posted on Mar 20, 2014
Henry hoover problems
brushes need changing on motor overheating
Sep 03, 2014 | Numatic Vacuums
Henry hoover airo brush not working
yes, it probably is stretched.
Jan 07, 2014 | Vacuums
Henry hoover brush not rotating so not picking up
Check the ends of the rollers for a build up of hair/thread, etc between the bar and the ends. remove if found.
Dec 29, 2012 | Numatic Henry Bagged Canister Vacuum
Henry hoover
Hi it can be the connector at the end of the Henry cable inside the cable rewind unit happened to us!
Nov 14, 2012 | Numatic Henry Bagged Canister Vacuum
Hi, My Henry hoover has stopped working about 10
Check the motor brushes as well as the on/off switch.
Sep 20, 2017 | Hoover Vacuums
My Henry Hoover cut out and will not work. Emptied bag and replaced fuse but no success.
If no burning or smelling, maybe nothing to do with motor, and if caused by the safety cut-out, it will need about an hour to cool down, and then check filter, bag, and drop coin through hose, pipes and the floor tool, to check for blockages and to stop it running hot. Damaged cable, worn carbon brushes, broken electrical rewind electrical contacts or even the printed circuit board (later models) are the most likely causes.
Jul 08, 2011 | Hoover Vacuums
New Henry Numactic Moter - How to wire?!
on the motor there are 2 connection together and one on it's own and on the brushes 1 each ignore these .and on the motor fix to the 2 tab one that you can see a wire connection on and then fix to the other side of the motor .this worked for me
Mar 11, 2010 | Henry Numatic "" Canister Vacuum
You need to know that very seldom will new carbon brushes alone `FIX`a motor in todays vacuums as they are higher RPM than those of 30 years ago.
On a salvageable motor a good rebuild procedure will generally include repacking bearings, cleaning suction fans and reseating new brushes with an abrasive seating stone at low speed with a motor run in device with variable voltage
That said, I have not done a HENRY in years but it likely will contain a generic AMTEK Lamb type motor as it is sold as more durable vac.
On a traditional vac motor, carbon brushes are removed by releasing a clamp over the brush. The brush holder will have either a flag terminal on it where the wiring will disconnect from the side, or a flat flag terminal which slides into a pocket on the carbon brush housing.
. If you are going to the trouble of replacing the brushes, remove and inspect the old ones for wear and chipping. Also inspect the commutator surface on the motor where the brushes contact. If there are any curved gaps between segments, or if the com is worn like an apple core , you need a motor complete.
If the motor has simply worn to the point where a brush has stuck or worn to nothing, you may be bale to reseat the new brushes, however any evidednce of BLUE sparks or noise is not a good sign . Best of luck. Post back if you need more help
Nov 01, 2009 | Henry Numatic "" Canister Vacuum
Electrical Burning Smell from Henry HVR200 Vacuum Cleaner
Hi! Highly unlikely that you need a new motor.  Highly likely that you need new carbon brushes.  The smell is caused by excessive sparking between the worn brushes and the copper commutator segments.  Most carbon brushes (and from memory I suspect this includes Henry's) have a copper wire buried in their last few millimeters, and you really need to change them before that becomes exposed.   The longer you run it like this, the more likely you are to damage the commutator, so change them sooner rather than later.  When you change the brushes, you can smooth off the commutator with very fine abrasive paper (the objective is to smooth it, not scratch it!), and then blow all the dust away (or **** it away if you have another vac, of course).  Incidentally, you don't say if you are using a paper bag in your Henry. Some people, because the top-hat filter is so good, try to manage without a bag.  This is false economy!  You should always use a bag. I hope this helps! I value feedback, so please remember to rate this response.
Feb 28, 2009 | Numatic Henry Bagged Canister Vacuum
Numatic Henry Bagged Canister Vacuum Logo
125 people viewed this question
Top Numatic Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
