Panasonic su-htb520 subwoofer not working
Tried everything...unplugged it and rehooked up cables,still no sound coming from subwoofer..soundbar works fine but subwoofer has no sound
SOURCE: Subwoofer - no sound
Had the same problem when mine first arrived. Unplug and replug the power cord at the back of the woofer. Worked for me!
Posted on Nov 02, 2007
SOURCE: Sony Active Subwoofer noise
need a schematic for a sony sawmsp1 active subwoofer....anyone????
Posted on Jul 17, 2009
  • 150 Answers
SOURCE: Humming sound in subwoofer after it's been playing for a while
It sounds like you are describing an earth loop problem. I won't go into detail in this post, but try an isolation test first. disconnect everything from the reciever except the sub and try connecting say a BATTERY powered mp3 player or cd player to minimise connections to the electrical mains earth. you could also isolate things by taking your sub to a friend's house and trying it on their system.
If it is an earth loop use a process of elimination to find out which two pieces of equipment causes the earth loop. then apply filtering.
you can buy earth loop isolation transformers for about AU$26 and I've used one on my sub myself. Theyhave RCA (phono)plugs on each end and they connect inline with the signal cable to the sub amp.
as for the thumping sound it might be the speaker protection circuitry cutting off the amp to protect the subwoofer speaker from damaged. This might be triggered if the earth loop sound is causing the sub amp to overload and clip.
Failing this there might be a dried out overheated electro capacitor in the amp circuit causing the hum. Hav a chat to your local electronics person, who should be able to spot it!
Hope this puts you on the right track
Happy Hunting!
Posted on Jan 07, 2010
Testimonial: "Thank you for your explanation of the possible causes for this error. I will investigate with the methods you suggested! :-)"
  • 71 Answers
SOURCE: I just bought the Vizio
Make sure its all hooked up right two wires switched could throw off the speakers
Posted on Nov 06, 2010
SOURCE: no sound in sound bar and subwoofer
for Jameslicon re wireless sub going on and off repeatedly. Both the soundbar and the sub have 4 wireless channels - try a different pairing of those channels. There is a sliding switch on the back of both units. I set each of mine to channel 4 and the problem went away. There is also a signal level switch with 3 levels on the back of the soundbar. If the wireless channel idea does not work, try a different setting on the level switch. Good luck.
Posted on Nov 12, 2010
Need to hook up sayo sound bar to my elment tv and my dvd player together
Help me connect my soundbar to TV, DVD, and Cable ...
www.tomsguide.com/answers/id.../connecting-soundbar-dvd-cable.html
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and cable box. ... More about : connecting soundbar dvd cable ... SolvedHow do I connectmy Element ELEFW392 TV to my Insignia NS-SB314 soundbar.
How do I connect my sound bar to the TV, BluRay, DVD, and ...
www.tomsguide.com/answers/.../connect-sound-bar-bluray-dvd-dish.htm...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... pretty hook them up and it works' followed by 'why did you buy a sound bar?' Do Ihave to connect sound bar to TV AND Dish receiver? and not to DVD? ... tv bluraysound bar and a DVR cable box together Forum; Solvedconnecting ...
Soundbar to tv [Solved] - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2198401/soundbar.html
Jan 11, 2016 | Televison & Video
No to hook sound bar to element TV and my DVD player at the same time
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and... The soundbar has an optical cable option, but my tv does not support that cable. ...SolvedHow do I connect my Element ELEFW392 TV to my Insignia ...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... first time, that paired the sound bar to the subwoofer but still no sound. ... Do I have to connect sound bar to TV AND Dish receiver? and not to DVD?
Jan 11, 2016 | Sanyo Televison & Video
Subwoofer not working.
Most likely, the "remote" wire to the subwoofer amplifier has come off or is not making good connection.
May 15, 2015 | JVC TH-BA1 Soundbar System with Wireless...
Does the Samsung UN50f6300af smart led tv support the Samsung Wireless audio soundbar HW-H450?
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
http://downloadcenter.samsung.com/content/UM/201411/20141114104022428/HW-H450-ZA-1114_Bookmark.pdf
Jan 05, 2015 | Samsung 2.1 Dolby Digital Wireless...
How do I connect Samsung soundbar 550 to sanyo dp55441?
Use the audio out ports on the Sanyo to get audio to the Soundbar. You can use a single digital audio cable or the legacy RCA audio cables. The Audio Out ports are marked in white on the back of the TV. If it doesn't work, turn off the TV Speakers in the TV's menu.
Jan 03, 2015 | Samsung HW-D450 Sound Bar
No sound coming from soundbar
You Should follow the correct optical cable and try fit
Feb 16, 2013 | Yamaha YAS-201
How to pair my soundbar and wireless lg soundbar
Press and hold the reset button on the back of the subwoofer until the light on the front starts blinking. Then with the soundbar turned on, press the stop button on the soundbar and the mute button on the remote at the same time. The display should say "REMATE". The sub light should stop blinking then and should be linked.
Feb 03, 2013 | LG Lsb316 Sound Bar With Wireless...
Subwoofer does'nt link with sound bar
  1. The wireless link indicator lights red. Or alternates red and green.
    There is no link between this unit and the active subwoofer.
    Check that this unit is turned on.
    Ensure that the digital transmitter is fully inserted
    into the digital transmitter dock on this unit.
    Turn the active subwoofer off and then back on.
    Alternatively, turn the active subwoofer off, disconnect the AC power supply cord and then reconnect it.
    Consult your dealer if the problem persists.
    Taken from the Panasonic SC-HTB520 Manual
Oct 26, 2012 | Panasonic Audio Players & Recorders
We bought a Samsung Soundbar x810 but the Subwoofer does not seem to be working properly although the blue and red led light up. I have tried rebooting/resetting per user manual instructions but it still...
Purchased a x810 & everything tests out fine except TV signal sounds from cable box. We have the Comcast cable box connected to the 50" Samsung Plasma TV hooked up to Samsung x810 Soundbar all using HDMI cables. But we are not getting cable shows sound through Soundbar. Please advise
Nov 04, 2009 | Samsung HT-X810T Theater System
No sound in sound bar and subwoofer
It could be that the unit is bad, it could also be that the device providing the input is bad. I doubt the cables are bad, but that could be also. Could it be possible that your television has a menu setting that turns the outputs off and on?
Even without the sub, you still get sound through the Bar.
Only way to test it is, different cables, alternate device to provide input for sound.
Dec 14, 2008 | Boston Acoustics TVee Model Two TV...
225 people viewed this question
 Grubhead
Grubhead
