Question about LG LH-D6230 System
LG LH-D6230 user/service manual and remote control code
Hi
I've got this system from a friend but i do not have the manual neither the remote control unit that comes with it. I do have several universal remote controls but all the codes for LG do not work. Does anyone know what IR codes to program my universal or with which universal remote control it might work? A new original remote is still quite expensive. The unit
seems to work fine but i need the remote to set it up correctly.
Does anyone have a pdf user and/or service manual for this system?
Thanks for any info.
Mike
2 Suggested Answers
  • 105 Answers
SOURCE: LG LH-D6230
The life of LG optical pick-up is Aprox.1000hours if it is more then 1000 hours used then just replace optical pick-up.
Posted on Feb 07, 2007
SOURCE: No remote controll
the remote from LG cost 22.11 . The part number is 6710CDAL01B
Posted on Nov 20, 2007
Tip
LG LH-D6235 Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
____________________________________________________________________
Download LG LH-D6235 Home Cinema System Manual
on Jul 14, 2010 | LG LH-D6230 System
Tip
LG LH-D6235 Manual Download
Would you like to review the features of the LG LH-D6235 Home Cinema System?
Have you lost your LG LH-D6235 Home Cinema System Users Guide?
Would you like a digital, searchable, pdf version of the LG LH-D6235 Home Cinema System Owners Manual?
Follow this link (& click FREE) to download a pdf version of the LG LH-D6235 Home Cinema System documentation.
I hope that helps.
LG LH-D6235 Home Theater Region Free Fix
Where can I download a manual for my LGCD/DVD Receiver Model LH-D6246 or can you tell me how to adjust the picture colour, Thank you Rob Manning
Hi Robert,
First of all, thank you for posting your question here at Fixya.
Please email me at mjsvillanueva23@yahoo.com, I will send you the copy of LG LH-D6246 Manual. File is in Pdf format (6.8MB), it can't be uploaded here.
Again, thank you so much!
Have a great day!
Mjsazon
Jan 10, 2012 | LG LH-D6230 System
Please anyone HELP!!!!!!!!!! How on earth do you set up the radio because i dont have the manual and the the correct remote....im using a universal remote
Here's the link for the manual. Page 27 describes how to do it with the front panel controls.
http://eic.lgservice.com/gcsc/dwn/main
You'll get a pop up saying you need to install an Active X Add On which is fine.
Apr 13, 2011 | LG LH-D6230 System
LG DVD player LH-D6230 - displays "dvd error" soon
Eprom corruption. Replace eprom, and edit in mode service.
Jan 07, 2011 | LG Audio Players & Recorders
Can not switch to aux mode input whitout remote control
I WANT TO KNOW THE SAME MANUALLY SWITHCHING TO AUX
Aug 06, 2008 | LG LH-D6230 System
Lg LH-D6230. How to hook up? PLEASE HELP! NO INSTRUCTION MANUAL!!
je kan met 2 tulp aansluitingen via de dvd speler audio out naar je tv gaan en dan de instelling aux van de dvd speler gebruiken zo kan je surround tv kijken
Jan 16, 2008 | LG LH-D6230 System
LG LH-D6230 DVD
I had a similar problem coming from South Africa to Australia and had to change the regional code setting.
Change to multizone format:
1)Ensure no disk in unit
2)Unplug unit from AC supply
3)Plug unit back into ac supply
4)Use remote control for the following commands:
5)Press the power key, the unit will come on
6)Wait until no disk appears on the display
7)Press sequentially the keys: PAUSE;3;1;4;1;5;9
8) "Code" will appear on the display
9)Press 0 (multizone)
10 Press sequentially the keys: PAUSE,POWER
11)The unit will turn off(standby mode), leaving the new regional code programmed. If you do not succeed at the first attempt disconnect the unit and repeat the above steps (1 to 10)
Hop this helps
Susan
Jan 12, 2008 | LG LH-D6230 System
LG LH-D6230
Feb 07, 2007 | LG LH-D6230 System
LG LH-D6230 System Logo
1,086 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Brian Sullivan
Brian Sullivan
Iron
Iron
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
