Question about Whirlpool AWM6120 Front Load Washer
The water doesnt go into the area where the soap is
When I turn my AWM5083 front loader washer on, the water goes in the machine, but it doesnt go into the little compartment where the soap and softener is..
    Champion:
  • 249 Answers
It only go's into that compartment on the very last rinse,you have,3 compartments .(1,hot )(2 cold)(3 softener)
Posted on Dec 15, 2007
Water runs out of soap box during rinse cycle
Hi there, given this a lot of thought. I had same problem. Could be that you are in a hard water area. Soap is not dissolving properly and building up in the rubber tube between soap box and drum. How I resolved this. Turn off power remove top cover of washing machine and massage the rubber pipe between soap box and drum to soften and cause undissolved saoa to drop into drum. This should rectify problem. Also consider using every month some descaler powder called Descaler cheapest from Axxxxn best wishes.
Feb 26, 2014 | Amana Tandem 7300 Washer and Dryer Stack...
The washer smells bad. We have taken it apart and cleaned between the tubs. The agitator turns in both directions
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 21, 2010 | Whirlpool LSQ9659PW 2 SPD 10 CYC 4 TEMP 5...
Water left in tub at end of load smells bad you don"t see water but can hear at a turn of the tub by hand.
May 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
I have a bad smell and a dark gloppy stain in my washer on the plastic section of the front loading part of the washer- can i get that replaced?
Apr 20, 2010 | Frigidaire ATF6000ES Front Load Washer
Neptune MAH 4000AWW works good but some whater is left
Apr 11, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Is powder or liqued detergent better for front
They are trying to make money off you!!!!!!! LIQUID!!!! Dont ever!!! use powder soap in your front loader. Powder soap doesnt dissolve all the way and then gets into the bearings of the washer and eats them away! This caused about a 450 dollar repair for your repairman. Never use powder soap.
Feb 19, 2009 | Frigidaire ATF6000ES Front Load Washer
LG front loader problem
If you remove the top cover you will see the soap dispenser unit on the left. It has a large rubber hose connecting it to the drum. If you remove two screws at the front you can free the dispenser for maintenance. You can undo the clips on the various hoses and check that they are clean.
Some people report some dripping from the soap dispenser even when the hose is unblocked. This seems to be a design fault.
Nov 04, 2007 | LG WM2277H Front Load Washer
LG front loader not filling properly
You have to remove the top of machine to have access here. Plug off the wall; you need a grip plier to loosen the clip to see what is blocking the hose.................refit carefully & firmly.
Nov 03, 2007 | Kenmore 44102 Front Load Washer
Whirlpool AWM6120 Front Load Washer Logo
64 people viewed this question
Sal De
Marvin
Marvin
jimorris77
