Question about Symbol MC7094-PKCDJQHA6GR Barcode Scanner
I cannot get my wifi access point connected to my mc70
I can't internet on this computer
This looks to be a WiFi only tablet. Do you have a WiFi access point to connect to or have a free one somewhere like WalMart/MickyDs etc. You then need to make sure your WiFi is turned on your tablet and then connect to the access point. Once connected you can use a browser to access the internet.
Mar 10, 2014 | Visual Land Connect 7" Tablet
How do i set up my daughters connection for er dsi? error codes 051099-1 comes up and the dsi says: no access point in range. check your ssid settings or move closer to an access point. what do i need to...
This probably means your not connected to any wifi.
You can check for a wifi access point by following these steps
  1. Go to your dsi settings (the wrench icon)
  2. Scroll over to the third page, and select "Internet."
  3. now choose "connection settings"
  4. click on one of the them that says "none"
  5. Click on "Search for an Access Point."
  6. a list of wifi access points should pop up
  • The wifi connection you are connecting to must have No Security or WEP
  • If the wifi connection is WPA you will not be able to go online for games
7. Choose one of those access points to connect to and if it is secured by WEP you must put in the password for that access point.
Good luck :)
Jul 21, 2011 | Nintendo Video Game Consoles & Games
Wifi says connected but no internet
hello
To make sure that the ARCHOS can recognize the presence of the WiFi access point, go to Menu > Settings > Wireless controls > WiFi settings and then see what is listed under the section "Wi-Fi Networks". One or several WiFi access points should be listed.
If the access point you want to connect to is not listed, then it might be
• Because the router/modem is not switched on.
• Because the router/modem access point is set to not broadcast its identity (even though it is available for use). Ask the manager of the WiFi modem/router to temporarily enable the identity (SSID) broadcasting. To do so, one would have to go into the settings of the router/modem either by using the web browser or a special application program that came with the router/modem. Search for a setting that has a name something like "Hide SSID" and make sure it is off. Once this is done, the ARCHOS should recognize the access point and be able to connect to it. The ARCHOS just needs to connect once and it will "know" this access point - even when it is later "hidden". The WiFi router/modem can then be set back to "Hidden SSID". In general, hiding the SSID of your modem/router is ineffective as a security measure so you might as well just leave it on.
please send me 4 thumbs up
Jul 20, 2011 | Archos 7 HOME TABLET V2 8 GB Hard Drive
I am not able to understand how to use the wi-fi in my samsung corby pro mobile
you need to understand two things.
Wifi is a service which requires an access point i.e. a Access point hardware, also known as Wifi Router and A wifi enabled phone. As you hve mentioned that you have corby- pro, it does have a wifi chip to access the wifi signal. Now you must get a wifi access point, i.e. a Wifi router, d link has veriety of routers, Now connect the router with broadband internet line and enable it. Configure the router through your desktop.
Now switch on the wifi on the corby pro and establish connection between the wifi router and corby . Then only you will be able to connect with internet..
Dec 01, 2010 | Cell Phones
How to install a wifi connection to my Nokia 5300 phone?
If you had wireless router or wireless access point at your place, just goto menu n navigate to communications in your mobile and select the wifi connection and enable it... Try to search for wifi connections near by select yours wifi broadcast's name and enter the security password (if installed in the wifi access point) and start browsing... Thanks...
Sep 21, 2010 | Computers & Internet
Cannot connect to wireless networks, where is
First of all check these are ok: Check your network adapter settings to see if you have your wireless card enabled. If that is ok, see if you can pick up any other wifi access points apart from your own. If you can see others fine, this means your wifi card is working correctly. If you can see your own access point and not connect to it, check the signal strength, items like microwaves and cordless phones can interfere with the signal. If you have a good signal try connecting. If it is asking for a key/password, then you will need to find the authentication key for your wireless access point.
If you cannot see your wifi access point but can see others, then you may have SSID broadcasting disabled, or the wifi might not be functioning correctly. Check these in your access point settings.
May 15, 2010 | Dell Inspiron E1505 Notebook
My work has given me an mc70. how do i connect to the internet? mcdonalds has free wifi in australia and would love to know how i could set it up so that i can log into the internet when i am at mcdonalds....
There are a few variants of the MC70.
MC7090 - the 9 defines the Wireless function.
MC7004 - the 4 defines the phone function.
Hence a MC7094 would have wireless and phone functionality. If you have a "9" version then you can use the free wifi. There would be a PCMCIA card symbol in the bottom right hand corner of the device. Click that and "find WLANS". Then connect to the one you want.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Mar 25, 2010 | Symbol MC70
I have the mc 70 how do i get started if i wanted to send my orders using wifi
i thank that you have to configure you acces point first, and configure also your unit to communicate with your acces point in setting( ip adress,subnet mask,ssid,keys...) and and connect your acces point to your system( switch,modem ,,,)
Feb 03, 2010 | Symbol MC70
Nokia E61 Wifi connection
setup Internet access point for WLAN menu>tool>settings>connections>access points select options>new access points Enter Connection name Data bearer: select Wireless LAN WLAN network name: select search wlan to select wlan in range. network status: select "public" if you can see wlan in range WLAN network mode: select infrs or adhoc WLAN security mode: select same settings used by WLAN access point WLAN security settings: Homepage: select the homepage you want
now you can connect & browse the internet. hope this helps
Jul 08, 2009 | Nokia E61 Smartphone
MC70 having roaming issues
If you're just speaking to the MC70, there is a setting on the CDMA (Sprint, Verizon), but I don't know if this works on the GSM version.
1) Got to: Start > phone
2) Dial ##DEBUG (##33284)
3) Select Talk
4) Select System
5) Select Details.
The rest should be clear.
Apr 28, 2009 | Symbol MC70
Symbol MC7094-PKCDJQHA6GR Barcode Scanner Logo
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
