Question about Refrigerators
Westinghouse Freezer has stopped freezing, still running though.
    Scholar:
  • 112 Answers
If the compressor is still running, remove the inside panel which covers your evaporator and see if it is iced over. If it isn't, you have sealed system issues. If it is, ohm out the heater element in your evaporator. If it doesn't read open, replace your defrost timer.
Posted on Oct 28, 2008
I have a westinghouse frdge freezer bj 385 motor constantly running with the door close motor stops intermidently open door motor stops recently moved fridge
Hi Peter, It it's not freezing the fridge up then it needs regassing but it it's freezing the fridge up then could be the thermostat, Good luck mate..... CHEERS..
Apr 04, 2016 | Westinghouse Refrigerators
Westinghouse rs652 freezer not working
If the unit runs but not getting cold time for a new one.If it doesnt start posssibe thermostat problem.
Jan 15, 2016 | Westinghouse Refrigerators
Bj515 top fridge bottom freezer, frisge freezing everyhthink changed control panel still freezing
Most likely a bad sensor either in the freezer, on the compressor, or the relay is stuck in the run position making it run 24/7
Mar 17, 2015 | Westinghouse Refrigerators
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
Westinghouse fj383
ne of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them
Dec 10, 2013 | Freezers
How to fix a freezer in a refrigherator?
could be expensive needs regassing
or compressor
Aug 02, 2012 | Westinghouse Refrigerators
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS27RGMFWW Freezer Not Freezing..
Yo u ha ve to Change the bimetal that its located in the freezer.
Dec 01, 2017 | Refrigerators
We have a Westinghouse WSE6100SA - side by side fridge freezer. Still under warranty. The repair guys have been twice now to temp fix the freezer, to no avail. the freezer is not freezing or I should say...
sound like the air supply baffel is the problem / or if the lower air vent is freezing over then the water is building due to icemaker / the water overflows on the inlet water fill tube to the icemaker and running down the inside behind the panel / they can take the fill tube from a ge icemaker kit and cut it in half and slide over the tube thats in your frig and it will keep it from running over / a problem wgi has had for awhile now / if you havent call sears i would since they should know the same.
Nov 25, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
