Question about Toshiba 2860 Copier
It is telling me to close the front door when it is closed
  • Toshiba Master
  • 628 Answers
Check the actuator....maybe out of position
Posted on Jul 14, 2012
Car ajar light and alarm goes off on 2005 tribute
Pits one of the five door ajar switches. They are located in the door latch mechanism that holds the door closed. The best way to figure out which one it is is to scan the body control module. With all the doors closed. It will tell you which door is giving the open signal. This will need to be done with a high end scan tool that any good shop or the dealer will have. The most common one to fail is the driver front door.
Apr 04, 2013 | 2005 Mazda Tribute
Its says to close front cover but it is already closed. I have opened and closed it many times with no change in result
GENERALLY THERE IS A PIN ON THE FRONT DOOR THAT BREAKS AND WILL NOT TRIGGER THE SWITCH TELLING THE COPIER THAT THE DOOR IS CLOSED. yOU WILL HAVE TO LOOK VERY CAREFULLY AT THE MACHINE WITH THE DOOR OPEN AND LOOK FOR AN OPENING THAT WOULD ALLOW AN ACTUATOR OR PIN TO GO IN ( USUALLY LOOKS LIKE A SLOT). TAKE AND PUSH INWARD WITH A NAIL FILE OR SOMETHING OF THE SORT WITH THE MACHINE ON AND IF THIS IS THE PROBLEM, THE MACHINE WILL POWER UP. SUPERGLUE SOMETHNG IN PLACE TO SUBSTITUTE FOR THE PIN ON THE DOOR. GOD BLESS, HOPE THIS HELPS.
Nov 06, 2010 | Toshiba 2860 Copier
Dell 3000cn front door open error
Check to make sure the door if fully closed and that your photoconductor unit is installed correctly.
When you close doors on your printer there are tabs that push a switch to tell the printer the door is closed.
locate the switches and play around with it, push the switch in and out with a flat screwdriver.
Worst case scenario is you will need to replace the switch.
Mar 31, 2010 | Dell 3000cn Laser Printer
When I press the start button on my dryer it depresses but the dryer doesn't start. What si wrong?
Are you certain the door is closed? If it is closed, you may have a defective, loose or broken door switch. The machine will not start if it thinks the door is open. You say it is closed and it may well be closed. If the switch doesn't tell the machine the door is colosed, as far as the machine is concerned, the door is open. You will probably have to remove the top and/or front of the machne to check this out.
Let me know if this works for you.
A
Sep 14, 2009 | Whirlpool LGR5636L Gas Dryer
Freezer door opens easily
The freezer door has a rubber gasket fitted with magnet beading. In case the gasket is torn or the magnet strip is missing due to continuous use the door does not close. Just replace the gasket and you will see that the door does not open unless you physically open it.
Jul 13, 2009 | Refrigerators
I have a canon ir 400 the machine shows close the front cover but it is already close?what is the problem?
Try to open and closed the front door several times,If the left cover and the front door are closed properly and still showing "close front door" most
probably the internal contact of door switch are not good , door switch replacement is needed
Jul 06, 2009 | Canon imageRUNNER 400S Copier
Error "close front cover"
make sure the protrusion that activates the switch telling the machine that the door is closed is not damaged.
Apr 02, 2009 | Ricoh Aficio 1018 Printer
"Close the front cover" sign even the door is closed already
On Canon copiers the close front door can be caused by other doors besides the front door.Try the fuser door an the left and the vertical transport door.Good Luck
Mar 27, 2009 | Canon imageRUNNER 400S Copier
Machine doesn't recognize door is closed
Open the door, and look closely at any little plastic latches to see if a small part hasn't busted off.
They usually have plastic prongs that tell a small switch inside the hole it goes into, that the door is shut. It's a toughie.
I'd google around for it. Use the talking marks " ". Like google something like "Ultima 1000" space "door won't close" or 'dryer' 'door won't close'.
That will bring up dozens of other people who've asked questions to OTHER sites.
Tried holding it shut? DOes it work when you stand there? You could tape it with gaffer tape.
Methinks, its a latch problem, something's busted off.
Feb 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
