How to repair LG washing machine LG WF-F711PC
  • 83 Answers
SOURCE: Dead LG WF-T8016TP washing machine
Is there any other appliance plugged in the same power point, and does it work?
Otherwise, plug another appliance in it to test that the power point is actually working.
If it is not, possibly a fuse has blown or breaker switched off in your meter box outside.
Let me know
Posted on Sep 16, 2008
drsn
  • 42 Answers
SOURCE: I KEEP GETTING A dE
you will need to replace the door sensor, this error will appear until it has been replaced. it is inside the unit and pretty much hard to get to if your not familiar with workin on it. take it to an LG tech or some one whos familiar with it..........
good luck LG's are very sensitive.
drsn777@hotmail.com for more info.
Posted on Dec 15, 2008
  • 326 Answers
SOURCE: Machine wash but wont rince or spin
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on May 06, 2009
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
Sounds like a screw or similar spinning on the spin cycle but can't get the screw out of my fuzzy logic 6.5kg WF-T652 washing machine. Don't want to force it... left or right. ??
watch the videos
Search Results
LG washer - Inner Tub Assembly replacement - Diagnostic & Repair ...
? 1:01
https://www.youtube.com/watch?v=vTKJFuKuUZg
Apr 30, 2015 - Uploaded by ApplianceVideo.com
WT1001CW LG Washer, Visit us at http://www.appliancevideo.com Do-it-yourself diagnostic and repair videos ...
ApplianceJunk.com - LG Top Load Washer Removing Bearing ...
? 4:17
https://www.youtube.com/watch?v=osTIeI7BIMI Dec 15, 2011 - Uploaded by ApplianceJunk
12:56. LG washer - Inner Tub Assembly replacement - Diagnostic & Repair - Duration: 1:01. ApplianceVideo ...
LG Top Load Washer Wash Plate Replacement #AGZ72909702 ...
? 1:39
https://www.youtube.com/watch?v=HBw4DvtrIjs Apr 11, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacing the wash plate on a LG top-loading washing ...
lg wf t652 washing machine remove drum Google Search
Apr 01, 2018 | Washing Machines
Lg washing machine WF-F6517THZ manual
I have LG Washing Machine model# WF-F6517THZ . i need to know where i can get the filter, which is in side the drum.
Jan 15, 2013 | Washing Machines
MANUAL FOR LG WASHING MACHINE, MODEL NUMBER WF-T653A
You can get the manual on the link below. Just click on where it says it is free top right.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T653A-_E
Good Luck and please rate 4 thumbs up for the free answer
Sep 06, 2010 | Washing Machines
LG WF T6517TC Washing Machine does not fill water
sir
my washing machine WF-T6517TC
when it start to wash get Alarm "dE" beep and stop machine.
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
Warning alarm
i am using an LG washing machine model WF-N6861DN.its giving a warning alarm after 3-5 seconds of operation
Jun 04, 2009 | LG WFT1071TP Top Load Washer
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
119 people viewed this question
Top Washing Machines Experts
