Question about Dell InspironTM 1501 Notebook
Black screen puter works great but now every 30 to 60 secs screen blacks out if i close lid and reopen all is the same i can carry on then in 30 to 60 secs it goes black again what is up im going to through yhis thing out the frigging window pleas help?
  • Dell Master
  • 998 Answers
It sounds like your “Suspend Switch” is acting up. The Inspiron 1501 uses a mechanical switch to detect if the lid of the system is open or closed. A camber is built into the hinge of the system that activates the suspend switch plunger as the LCD is lowered to the closed position. If the switch is broken or nonfunctional, then it can be replaced separately. It is located under the hinge cover next to the right hinge on the system.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Oct 28, 2008
Screen goes black after a couple hours
There are a couple of possible causes and solutions... Please give some more info.
Is the hibernation period long enough to allow the TC4200 to cool down or is it just long enough to close the lid and reopen it?
I believe I can give you a definitive answer with more info.
Jan 26, 2014 | Compaq tc4200 Tablet PC
While using the screen goes black but if you look hard you can see it is still on because I can see the brighter windows but just barely. I can close the lid and reopen and the screen is on but the...
It could be your LCD inverter is going bad. CLICK HERE to see. It is relatively easy to replace. Remove the LCD screen bezel screws and gently lift away close to the bottom. The inverter is on the bottom right under the LCD itself. Usually 2 screws to remove and unplug then replace. If it is not the inverter then it is your LCD backlight in which case you will need to replace the screen.
May 15, 2011 | Panasonic Toughbook CF-51 Notebook
Screen goes black , but when you close the lid and reopen it comes on just a bit then goes black , Is the screen bad ??
it could be the switch that change to Standby mode when you close the lid <br /> I can fix this <br /> <a href="mailto:doron_c21@yahoo.com">doron_c21@yahoo.com</a><br />
Aug 26, 2010 | Toshiba Satellite A135-S4527 Notebook
The laptop screen is almost blank/black. an external monitor is working ok. when i close the lid of the laptop and open it again the screen comes on for a sec but then goes off again almost blank/black....
As per Dell Technical support LCD kit needs to be Replaced.
I Would recommend to
Run PSA Diagnostics. Check for PSA Error codes
if unable see display during PSA Diagnostics use External monitor to make note of Error code.
Check Error code on support.dell.com
If no Error codes. Then Only option is replace LCD kit
Jan 19, 2010 | Dell Latitude D430 Notebook
Check cartridge check print paper light and
remove color or black cartridge, close the lid, let the printer initialize, and then reopen lid and add 2nd printer cartridge...
this should sove the problem
Nov 30, 2009 | HP PSC 1210 All-In-One InkJet Printer
Screen stays black after closing and then opening Inspiron 6000
you try pressing the power button once?  or maybe even pressing any keys.
also try adjusting your power management
vista) start. control panel. power option.  Edit plan settings.
xp) right click anywhere.  properties.  screen saver tab.  power management.
Mar 09, 2009 | Dell Inspiron 6000 Notebook
Black screen
Yes, it could be stuck in hybernation
Or.. Check to See if the Lid Switch is Stuck Down... Some laptops have alittle Movable plastic pin that depresses when the lid is closed to turn the screen off... this can sometimes get stuck down to the board button.. causing the symptoms youre experiencing
Jun 04, 2008 | Toshiba Satellite A105 Notebook
Dell InspironTM 1501 Notebook Logo
153 people viewed this question
Alun Cox
