What's your problem?forgot how to set day and date on my Sharp Model spc403 clock.
Forgot how to set day and date on my Sharp Model spc403 clock.
Press and hold the cal button :)
Posted on May 08, 2012
2 Suggested Answers
SOURCE: Setting time & Date
I copied this from another post & it worked for me:
To enter the date
1. Be sure to switch to "rate set" from GT
2. Enter the month
3. Press the decimal point
4. Enter the day
5. Press the decimal point
6. Enter the year
Example 3.09.2007
7. Press the button that look like a clock/calendar
To enter the time
2. Enter the hour (please use military time)
4. Enter the minutes
Example: 13.24 or 9.24
5. Press the button that look like a clock/calendar
Then change the "rate set" back to the GT setting.
Posted on Mar 24, 2008
I need manual to set sharp weather station spc403
You should be able to obtain one from Toshiba's website.
Mar 14, 2014 | Sharp Atomic Weather Station Alarm Clock
Setting up the Date & Clock after reset
Follow the instructions on the first page of this manual.
Apr 05, 2013 | Sharp EL-1197PIII Calculator
Sharp spc403 instruction manual
hold "Cal C/F" for 2 or 3 second then the year will blinking. The press "Adj CH" to move year.
Then press "Cal C/F" again it will blink month then press "Adj CH" to change month, and date.
May 21, 2012 | Audio Players & Recorders
The day inscription is two days late, monday, watch says saturday
So to change the Day and Date of your Watch, slowly pull the Stem out... (Do note that if you have a Waterproof Watch, you'll need to unscrew the Stem counter-clockwise, which is towards you, until it unlocks, then you can pull the Stem out!) But this is where you need to go slow. If you pull it out slowly you should hear one snap. (It stops on the first notch) If you pull the Stem out all the way, it snaps twice and ends up on the second notch. (See picture below) The second notch, or all the way out, is where the Stem needs to be to set the Time.
day-changed.gif But the first notch, or first snap, is the secret and the key to setting the Day and Date! In the first notch position, you'll see that if you spin the Crown one way, it will change the Day. Spin it in the opposite direction and it changes the Date!
Do keep in mind that you may have to spin the Day and Date a couple rotations because it most likely will alternate between English and Spanish. Just pick the correct Language for you and it's done! When the Day and Date are set, push the Stem in all the way and enjoy your Watch!
If you still have the problem with your Watch changing Dates at Noon instead of Midnight, that just means you're on the wrong 12 hr cycle. (It's set for Twelve at Night instead of Twelve at Noon) All you need to do is pull the Stem all the way out, (second notch) and Spin the Minute and Hour hands ahead 12 hours. If it's Twelve O'Clock, spin it ahead until it's Twelve O'Clock again. Doing that will put the Watch on the correct 12 hour cycle.
Jun 27, 2011 | Watches
I HAVE A PANASONIC DVD,VHS RECORDER MODEL #DMR-EZ48V.WHEN TRANSFER A VHS CASSETTE TO A DVD THE THUMNAILS ON THE DVD HAVE THE DATE OF 1/1/2000. HOW CAN I PUT THE ACTUAL DATE OF THE RECORDINGS ON EACH OF THE...
Try setting the clock on the remote press [FUNCTIONS] go to SETUP menu - locate the CLOCK option (it should be under 'OTHERS' in the setup) and set the current time, press [ENTER/OK] to store if necessary, then press [RETURN] to exit the setup. Once clock is set correctly, future DVD thumbnails will show the actual date/time of recording in this (and similar) model combo units. If auto clock setting is not possible, set it manually as above.
I assume in spite of the wrong date/time, your DVD recordings have been successful. Incorrect clock and date setting usually only affects timer recording for VHS.
If you have lost or misplaced your original owner's manual, you can download a free pdf version (for Region 1 model) from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ48VK
or, if you live outside USA, download the 'Australia/NZ' pdf version of the manual (for Region 4 model) from:
http://www.panasonic.com.au/Products/DVD+and+Blu-ray/DVD+-+Players+and+Recorders/DMR-EZ48V/Downloads
either one of these will provide you a full copy of the original user guide/setup including clock.
All free. Hope these suggestions help.
May 02, 2011 | Panasonic Televison & Video
How do I change the date on a Sharp EL-1801V calculator?
Below is the step by step directions on how to update the date/time/tax rate. To set the date, time or tax rate, set the "Grand Total/Rate Setting Mode Selector (GT . RATE SET) to "RATE SET" position.
For Date:
1) Enter in the order of month, day and year, with the decimal point in between each set of numbers. Month 1-12, Day 1-31, Year: 2000 - 2999 (4-digits) or 00-99 (2-digits).
Example 04.10.2010
2) After the year, press the button with the clock/calendar symbol to complete the entry. When this button is pressed, the number entered is evaluated and displayed as "date" if the value is within the following range; "Error" is displayed otherwise, and the previously set date is restored.
For Time:
1) Enter in the order of hour, minutes with a decimal in between the hour and minutes, then press the button with the clock/calendar symbol to complete the entry. (No seconds value is entered) When this button is pressed, the number entered is evaluated and displayed as "time" if the value is within the following range; "Error" is displayed otherwise, and the previously set time is restored. Hours must be represented with 0-23 (24-hour system for the hour entry), Minute: 0-59.
FYI, This calculator uses CR-2032 lithium battery.
Enjoy!
Apr 10, 2010 | Sharp EL-2630P Calculator
How do I set the date and time
First set to "Rate Set"
Then enter the month, day and year seperated by a "." then hit the Clock/Date button. So 7-7-09 would be entered as 7.07.2009.
It's the same idea to set the clock. You use a 24 hour period. So 4:12pm would be entered as 16.12.
Jun 09, 2009 | Sharp EL-2196BL Calculator
Sharp EL-1801P III Calculator Setting Time & Date
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
Feb 17, 2009 | Sharp EL-1801P Calculator
HOW TO SET A CLOCK AND CALENDAR ON SHARP EL-1750P CALCULATOR
GT •RATE SET GRAND TOTAL / RATE SETTING MODE SELECTOR:
“GT”: Grand Total
“•”: Neutral
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Aug 22, 2008 | Sharp EL-1750PIII Calculator
Setting time & Date
To enter the date
2. Enter the month
4. Enter the day
6. Enter the year
Example 3.09.2007
To enter the time
Mar 10, 2008 | Sharp EL-2196BL Calculator
519 people viewed this question
jasbo
jasbo
