Question about LG Televison & Video
I keep getting a white info bar on bottom of the screen every 5 minutes how do i stop this
  • LG Master
  • 1,214 Answers
Hi there
Try to check if there is local interferances as such as an electrical appliance or power tool. Take a look at the antenna, if it is aimed in the right direction.
Kolbrun
Posted on Feb 25, 2012
2 Suggested Answers
  • 35 Answers
SOURCE: screen looks like color bar code
the answer will deprnd on how the fault occured
the tv may have had a knock (kids in house!!) in which case it could the the lcd panel gone
if a normal fault the more than likely the ldvs cable or dry joints either way not a job for the untrained
Posted on May 27, 2009
Picture stays on for about 4 minutes ... then 4 color bars appear across the screen ...Red, green, blue, white ???
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 23, 2017 | Televison & Video
Tip
Cordless Shark Vacuum Brush Bar Stops Working
My cordless Shark Vacuum brush bar would stop working each time after a few minutes of use. I was getting ready to throw the vacuum cleaner away, but decided to pull the bottom cover and check it first. I did the following modification and now it works great!
Just a few notes before attempting this tip: You need to be carefulafter this modification if you see the brush bar stop as this couldmean the bar is really jammed and there is a risk of the brush barmotor burning out. Most of the time disabling any fuse or circuit breaker is a very bad idea and could ruin equipment and even cause a fire. In the case of this tip, only consider the modification if you areready to get rid of the Shark because of the brush bar problem. Another option is to replace the circuit breaker, however consideringthe time and money involved vs. the cost of the vacuum cleaner it mayor may not be worth it to you. I did this modification to my cordlessShark about 4 months ago, and have had no further problems with it. I takes about 15 minutes to do this modification using a screw driver and wire cutters.
1. With the vacuum cleaner off, check the brush bar by manually rotating is with you hand. It should not be jammed or very difficult to turn. If so, remove the brush bar and clean it. Try the vacuum again. If you still have a problem with the brush bar stopping, proceed to next step.
2. Remove bottom cover around brush bar / motor.
3. There are two wires going to the brush bar motor, one wire includes a small circuit breaker.
4. Clip the circuit breaker out of the wire and reconnect the wire straight to the motor.
5. Re-install bottom cover.
on Apr 25, 2010 | Vacuums
Android keyboard (asop) has stopped working
My Kl? tablet (old one) isn't letting me use the keyboard, only a white bar shows up at the bottom. How do I fix this?
Mar 27, 2014 | Curtis ProScan 7" Capacitive Touch Screen...
Blackberry screen keeps turning white but is alright when i charge it
It sounds like you're having problems with your processor. I would take it into a repair shop
Nov 24, 2017 | RIM BlackBerry Curve 8520 Smartphone
Screen looks like color bar code
May 27, 2009 | Westinghouse SK-32H540S 32 in. LCD TV
Getting a white screen with 102 error message
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 13, 2009 | Archos 605 WiFi Digital Media Player
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Buzzing noises + white lines
hey there. i have the same problem. it is the cable box though. i got rid of it by plugging some cables from the box to the surround system. seems it diverted some of the extra power and the buzzing stopped on my pani px70e. might help u, might not :)
Oct 31, 2007 | Televison & Video
Screen problem
this may be a problem of a loose component, looking through the main board and soldering loose components, IC, transistor, all components, just have patience, this may solve the problem.
May 14, 2007 | Sharp 27H-S60 TV
Televison & Video Logo
50 people viewed this question
Computer Repairing
Computer Repairing
