Question about Vacuums
Why is my wet dry vaccum blowing and not sucking?
    Problem Solver:
  • 11 Answers
The clog or the bag or canister is full. Clean or replace filters.
First of all, make sure you put the hose on the suction port. If it's blowing where it should be sucking, the polarity of the motor is backward; the wires are hooked up wrong.
Posted on Feb 25, 2012
5 Suggested Answers
Curt_W
  • 60 Answers
SOURCE: husky 6 gallon dry/vac wont **** in air, only blows air out
Maybe you have the vac hose plugged into the blow out port.
Posted on Nov 16, 2008
SOURCE: DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Posted on Jul 28, 2009
  • 747 Answers
SOURCE: my wet/dry vac is sucking and blowing air at the
your is off or cracked replace hose or duck tape it.
Posted on Feb 02, 2011
SOURCE: eureka 2812 shop boss wet/dry..water is being sprayed out of the
je ne trouve pas un magasin ou je puisse acheter des filtre a poussiere
Posted on Sep 02, 2011
Sucking and blowing
Shop-Vac® Brand. The Original Wet/Dry Vac™
https://www.shopvac.com/
Shop-Vac® is proud to be an American-based company. ... When we say the Shop-Vac® is powerful, we're talking debris cleaning, leaf-blowing, heavy-duty, wet or ... Many of our vacs are backed with a 3 to 5 year warranty, but we've seen ... I had just gotten back from work, so my arm was hurting, and I really didn't want to ...
My ShopVac Blows - WOOD Community
community.woodmagazine.com > Forums > Tools and Tool Buying
Nov 23, 2009 - My ShopVac suddenly started blowing dust out the exhaust ports. I don't mean a little dust, it blows almost as much dust as it sucks in!!!! ... ... I'd look it over very carefully looking for tears or splits. Might be a good idea just .... A few months ago I purchased a Dust Deputy and hooked it up to my shop vacuum.
10 Shop-Vac Vacuum Hacks For Around The House - Thrillist
https://www.thrillist.com/.../10-shop-vac-vacuum-hacks-for-around-the-...
Sep 14, 2015 - Simply flip the switch from suck to blow and blow leaves to your heart's... you really need to get your act together if you're using a Shop-Vac for ...
Shop Vacs...and dust control? - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Cleaning Tips
Jan 09, 2016 | Shop Vac Vacuums
My craftsman vaccum won't **** very well. The filter is not the problem and the hoses are not clogged. On the motor itself there is very little air being sucked in, however it blows out air quite well. Can...
The mini has a plastic blade, it sounds like it is loose on the shaft. The air you feel coming out is vacuum air and motor cooling air. It will feel like there is a lot of air even if you block the hose, because that's motor cooling air. The plastic blade might need replaced.
Dec 28, 2013 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
The vacuum is blowing instead of sucking
Your in the wrong hole tank is the sucking motors the blowing.
Feb 27, 2011 | Craftsman 17026 Wet/Dry Vacuum
My shop vac is not sucking anything only blowing air out of the open hole where the hose should go if I wanted to blow something. I want it to vacuum not blow out. The filter sleeve and dry cloth are...
I just had the same problem, the vac wouldn't suck in. Turned out to be because the filter was WET. It works great when I take the filter off before sucking up water or liquids! Not sure if this applies in your case, but definitely something to keep in mind. : )
Jan 17, 2011 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
I have a craftsman 2 gal wet/dry vacuume & after using it for a wet pick up without a filter, it blows dust out while vacuuming and is extremely loud. Any suggestions. I took it apart and unclogged...
It sucked up some of the muddy water into the impeller while you was using it. Then it dried out and turned to dust. After you get done using it for wet pickup take a water hose and let a little clean water **** into the impeller, with it off the tub. That will clean it then let it run till dry. That will keep it from getting moldy also. And always put a filter on before using for dry stuff. They make a universal filter that is like a satin bag. That is what I use instead of paper one. Even for water.
Dec 17, 2010 | Craftsman 17762 Wet/Dry Vacuum
Ridgid shop vac is not sucking
Check the intake hose for a blockage. Attach the hose to the exhaust outlet and turn the vacuum on. If no extracted air is blowing out of it the hose is totally clogged up
Apr 10, 2010 | Ridgid 25648 Wet/Dry Vacuum
My shop vac is blowing air out and not sucking. How do I get it to suction?
make sure top is sealed up properly also check to see if hose is not plugged in hose or inside vaccum
Aug 28, 2009 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Eureka 2812 shop boss wet/dry..water is being sprayed out of the
Jun 20, 2009 | Eureka 2812 Wet/Dry Vacuum
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Husky 6 gallon dry/vac wont **** in air, only blows air out
Nov 16, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Vacuums Logo
89 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
