Question about Radio Communications
TK-2207 Stun/Revive DO Kenwood Trnsceiver Model TK-2207 having the remote kill/Unkill, stun/Revive functionality
What is this? my Icom IC-F4029SDR displays 'sorry'
It appears that the radio has been locked out from service. Return it to whom you got it from.
From pg 35 of the manual:
D D Stun and Revive
The dispatcher can send MDC 1200 signals that will stun or
revive your transceiver. If a Stun command is received that
matches your station ID, the transceiver will display "SORRY"
and you can not receive or transmit. When a Revive com-
mand is received that matches your station ID, normal operation is restored.
Jun 17, 2014 | Radio Communications
The radio has been locked out of service by the owner. Return it to get it unlocked:
Pg 35 of the manual:
D D Stun and Revive
mand is received that matches your station ID, normal opera-
tion is restored.
Kenwood tk3317 has stun on screen
At some point a STUN signal was sent to the radio possibly because it was STOLEN. The owner/agency/company or radio shop thought this was necessary because of security or malicious interference to the system. It will need the Kenwood program cable and software to fix it. Perhaps a radio shop can advise you and determine the status of the radio??
Dec 04, 2013 | Kenwood Tk-762 Transceiver
Not heating anything up
if the light comes on and you here it buzzing but its still not heating up its likley to be the megertron burned out,, (thats the aerial for the microwave's to transmit off) its very expenive to replace,,,
bont try replacing it yourself, inside the microwave is very high voltage even if its been turned off for a long time,, 1000's of volts and they kill,,
have you ever seen a stun gun working??? this microwave has the stun guns very big brother inside it?? it dont stun,, it kills! play it safe drop it into a repair man to fix or better still buy a new one,,there so cheep now its realy not worth spending good money on an old microwave,, go out and treet yourself and play it safe!
Oct 25, 2009 | GE JVM1650SH Microwave Oven
Maytag microwave Model MMV5100AA turntable no longer turns. Is this an easy fix? The rest of the Microwave works fine. I think I may have flooded the floor of the microwave with water. It worked awhile...
to be realy honest ,,, yes! but be warned there is a very big capacitor inside this microwave and it will be charged up with 1000's of volts,
if you tuch it, your dead! be warned dont tuch it!!!!!!!!!!!!!!
have you ever seen a stun gun working??? they realy hurt you!!!!
well this microwave has the stun gun's very big brother inside of it and it wont stun you,,,it will kill you!
if i were you i would drop it into the repair man to get him to fix it for you,,, or get a new microwave,, there very cheep now,, is it realy worth killing your self for a fuw bucks?
Oct 25, 2009 | Maytag Microwave Ovens
The microwave makes a popping noise, then a loud grinding noise
this could be any thing? first ask yourself how old is it???
if its more that 3 years old you would be better off just dumping it as getting it fixed would cost more that its worth??
and there so cheep now too!
however dont go trying to get inside of it to see if you can fix it yourself
there is a lot of very hight voltage in there even if its been turned off for a long time,,this voltage is in the 1000's of volts and it kills
have you ever seen a stun gun working???????????
well this microwave has the stun guns very big brother inside of it,,
it dont stun,,,, it kills! is it realy worth taking a risk for a fuw bucks?
please play it safe
Oct 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Carnt get goodmans me21w microwave out of defrost mode
this is most likley to be the programer packed up,if it wont let you out of defrost its not worth getting it repaired as it will cost to much
ask yourself how old is it? rember there so cheep today! from £50 up!
please dont think of trying to have a go yourself at fixing it,
inside this microwave there is very high voltage,, in the order of 1000's of volts,,,it could kill you if you tuch it! be warned,
have you ever seen a stun gun working?? it realy hurts you!
this microwave has the stun guns very big brother inside of it,,,,,
it dont stun you,,,,it kills you? is it realy worth it for a fuw bucks!,
Oct 25, 2009 | Microwave Ovens
Not all the buttons work on the panel of the mircowave
buttons that stop working could be many things more often its the pad its self but it could also be the programer,,,what ever it is, its not realy worth having it repaired a new microwave costs from £50 up at todays prices,, ask yourself this,,,, how old is it?????
also please dont try fixing it yourself, there is some very high voltage inside your microwave even if its been turned off for a long time,,,
this voltage can kill you,,, be warned!
have you ever seen a stun gun working,,,it realy hurts you!!!
your microwave has the stun guns very big brother inside of it
it wont just stun you,,, it would kill you,,,
is it realy worth it just to save a fuw bucks??? play safe buy new,,
Oct 25, 2009 | GE Microwave Ovens
Our r-1491 microwave fan won't shut off, even when
its just the door switches playing up on you,,but is it worth getting it fixed? after all a new microwave onle costs from £50 up today,,
please dont try fixing it yourself unless you realy know what you are doing in there, there is 1000's of volts hiding in there even if its been switched off for days, and them volts will kill you,
have you ever seen a stun gun working???it realy hurts you,,,,,this microwave has the stun guns big brother inside of it,,and it wont stun you,,it will kill you,, is it realy worth that for a fuw bucks?
Oct 24, 2009 | Sharp R-1491 Microwave Oven
GE XL1800 model #JVM1850CD 001 -turntable won't turn and makes a grinding noise when turned on. Any suggestions on part number to replace the motor?
why are you diceing with death ???
to fix your microwave will cost you more that £50 thats over the price of a cheep new one??? darft that is,, why not just buy a cheepy and use that? also i do hope you know that inside your microwave there is very high voltage over 1000 volts,,, it could easly kill you if you tuch the wrong part,,,
have you ever seen a stun gun working? it realy hurts you!
your microwave has the stun guns very big brother inside of it,,,
it wont stun you,, it will kill you,, so far you have been lucky your still here, please stay that way play it safe go out and buy a new one?
Oct 24, 2009 | Samsung MW1030WA Microwave Oven
Radio Communications Logo
47 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
