Question about Sanyo MM-7400
Sanyo 7400 my sanyo 7400 is having a happy. screen goes blank while sending text msgs, messages ive deleted are reappering in outbox it sits and flashes on and off without me touching it and is generally being a pain in the bum
0 characters
1 Points
The message inbox says I have 1 new message, even though I have deleted all messages and there are no unread texts. It also displays the small envelope icon on the main screen in the bottom left corner,...
go to the mesage tab and click options then search for the option on the sim mesages and when it opens delete all the messages in the sim message box and check whether any messages in the outbox
Jun 23, 2011 | Samsung Renown Cell Phone
My texts are just queing in outbox and wont send, but i can recienve them okay.
try to remove the sim and change with another simcard then delete the msgs in the outbox so you can send a msg using your original Sim.
Jun 01, 2010 | Sony Ericsson W890i Cellular Phone
When I tried to send the text message on the screen it says sending message but it then it will be just transfer to the outbox and won't be sent. why is that?
k660i can't send texts stuck in outbox problem
1 move the text that can't be deleted from OUTBOX to DRAFTS
2 if you still can't delete it go to SETTINGS-FLIGHT MODE select SHOW at STARTUP
3 switch phone OFF and ON again. select FLIGHT MODE at the beginning. switch phone OFF and ON again
4 select NORMAL MODE if asked. go to DRAFTS and delete that message
phone should be working now
Jun 01, 2010 | Sony Ericsson K660i Cellular Phone
Memory card flashing on screen
Sep 24, 2009 | SKYPE WP-S1 Cell Phone
Unable to send text messages on my new nokia 5800
All you have to do is go to your message setting on your phone:
1. Open Messaging
2. On New message sellect options at bottom
3. Open settings
4. Open Text message, you should see: Message centre, message centre in use ect..
5. Open message centres this should go to next screen then open again, this screen should have : Message centre name & Message centre number (from your network provider you need to find out what is the message centres name & number are e.g in Australia it should be SMSC1 and number is +61411990001) then just manually enter these in there.
Feb 26, 2009 | Nokia 5800 XpressMusic Smartphone
Texts go to outbox but are not sent
Had a similar problem myself (Sony Ericsson W890i) - just a plain old SMS message got 'queued' in the outbox, and all further messages I tried to send got sent to the outbox too without ever being sent.
What I did was delete all the messages that I could from the outbox (5 out of the 6 which had been 'queued'), and the one remaining message that I could not delete I cancelled, sent it to the Drafts folder, and then Saved it (to the SIM). I then switched off the phone, took out the SIM card, put it in my old Sony Ericsson handset, switched that on, went to the Messages folder and deleted this one troublesome SMS message from the 'Saved' sub folder. Replaced the SIM in my current handset, and sending messages thereafter was no problem. Hope it works for you too!
Dec 10, 2008 | Sony Ericsson Walkman W810i Cellular Phone
When sending a text msg, it goes to outbox, wont send
I had the same problem and I read on down and saw someone's phone was stuck in flight mode. I remembered that for some reason, my phone was in flight mode the other day, so I went in and took it off. I realized the problem had been since that time. So, I put the phone back in flight mode and was able to delete the message from my outbox. I put it back in normal mode and now I can send texts. Yes!!!!
Nov 29, 2008 | Sony Ericsson w580i Cellular Phone
Sending text messages...
Hi julietdb,
This sometimes occurs when a SIM card has gone wrong.
Go to Messages, Settings, Text Message, Service Centre
Then, call your ISP, ask for the SMS Service center number.
Then, verify that it is the one written in the location I gave you.
If not, replace it with the number you were given.
In case it is - there's probably something wrong with the SIM card and it needs to be replaced.
Sep 15, 2008 | Sony Ericsson K790i Cellular Phone
Get your phone flashed..
1st scan it for virus..
tell me the result..
Aug 06, 2008 | Sony Ericsson K800i Cellular Phone
Texting problems
check if u have enough balance to send the message.
May 26, 2008 | LG Shine KE970 Cellular Phone
Cell Phones Logo
19 people viewed this question
Top Sanyo Cell Phones Experts
Toyosi  Sarumi
Toyosi Sarumi
kenneth njonjo
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
