Question about Samsung Televison & Video
Region settings for samsung HT-D355K/XA - Samsung Televison & Video
SOURCE: decode the samsung ht-z210 player
desculpe, rgti, a dica estava em outro forum sobre o mesmo aparelho. ele serve para todos os modelos de ht samsung desta mesma serie:
1. Remove disc from tray (remova o dvd).
2. Switch off player and unplug power cord (desligue o aparelho e depois desconecte a tomada).
3. Wait 30 seconds, then reconnect power cord (espere 30 segundos e reconecte a tomada).
4. Turn on player with remote. Wait for player to finish loading and display 'no disc' (ligue o aparelho pelo remoto. espere ate carregar e aparecer o aviso no disc).
5. Press enter on remote. (There will be no on-screen response.) aperte entre no remoto. nao aparecerá mensagem alguma na tela.
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.) aperte os numeros, nao havera resposta na tela.
7. Press enter on the remote. Player will automatically shut off (aperte enter no remoto. o aparelho irá desligar automaticamente).
8. Turn player on (ligue o aparelho)
9. Turn off (desligue o aparelho).
10. Turn player on then off again (ligue/desligue de novo).
11. Player is now region-free (o aparelho está desbloqueado).
*peguei a dica em ingles mas traduzi para ajudar a galera...
Posted on Nov 03, 2008
SOURCE: region codes
While looking through some forum posts i found the way to fix the problem. It takes a bit of fiddling around but it does work... I tried it out last night.
Firstly you need to put a DVD of a different region into your player and wait for it to start to read the DVD before you commence the procedure... it takes a bit to get the timing right.
when the DVD can't be read it, on screen Eject Disc will come up
Press Repeat & Hold 3 Seconds (it may work using either repeat button on the bottom, i tried both.
Press 76884
After entering those 5 digits, you should see a number in the top left corner of the screen corresponding to the current region (4 being Australia region)
Press 9 for "auto-region" mode ie. Region Free
Turn Off Machine
and there you have it. The timing is crucial so start trying as soon as the DVD is in. It took me 5 goes before it worked.
You will notice that it may take a bit longer for the other Region DVDs to be read then normal but it's only a few seconds longer.
Posted on Dec 02, 2008
  • 5 Answers
SOURCE: region codes for Samsung ht z110
1. Disconnect your player from its main power source for 30seconds
2.Reconnect your player to its power source
3.Press the power on button on your remote control
4.Press the Enter button on your remote control
5.Press 8,4,2,6 and 9
6.Press Enter on remote control and the your player will place itself on standby mode
7.press the power on button on remote control.
your player is multi region.
posted by alfredsaviou
Posted on Feb 05, 2009
SOURCE: region free code for samsung HD-BD2E
Haven't tried it, but found this online somewhere....
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
4. Reconnect to mains
5. Turn on player with remote.
6. Press ENTER on remote.
5. Press 8, 4, 2, 6, 9.
7. Press ENTER on remote. (The tray will open)
8. Switch off power from remote, then switch back on.
9. Player is now Region Free.
Posted on Mar 22, 2009
  • 219 Answers
Try this
Posted on Apr 25, 2009
I changed the resolution from 720 to 1080 after that it is not working how to fix it please help me out to fix it Samsung DVD player HT-D355K
You have probably selected a resolution that is not supported by your TV. Your best option is to reset the player to factory default settings.
With the power on and no disc loaded, press and hold the STOP button on the remote for >5 seconds. That will reset all of your settings.
Jun 03, 2016 | Samsung Audio Players & Recorders
I Lost My Samsung HT-D355k Home Theater's Remote & Now Surroud Speaker & central speaker is not Working. help me what should i do?
Get a replacement remote of a substitute to help you select menu items. Otherwise try to navigate the menu using the buttons.
Check this site to get manuals for this product.
HT D355K HT D355K ZN Support SAMSUNG Gulf
Feb 09, 2015 | Samsung Audio Players & Recorders
I would like to make my SAMSUNG HT-F5500W region free
There seems to be useful info here:
http://forum.videohelp.com/threads/342271-Samsung-HT-D6750w-Region-Free
Dec 07, 2013 | Samsung HT-F5500W 5.1-Channel 3D Blu-ray...
Samsung ht-d4500 region code
I just leave this message to tell you that this really worked for my blue ray samsung ht-f4500/zx in Mexico City. Thank you very very much. Cheers
May 02, 2012 | Samsung HT-D4500 Blu-Ray Home Theatre...
I cant play any discs on my samsung ht x200 due to a disc region error
Go through the set up menu on the Ht DVD player (if it's all in one) and change your settings for the region code. Obviously it is not the one that you have already set it to (probably set by manufacturer). NTSC, PAL, etc. I hope this helps.
Oct 26, 2009 | Samsung HT-X200 Theater System
No disc on samsung
Hey,
For clarification, was this home theatre system purchased in North America? If so, in all odds it is a "Region 1" DVD player. To play a "Region 2" video, you will need either a 'multi region' player or one that is designated as a "Region 2"
regards,
Hortona
Mar 24, 2009 | Samsung HT-DS100 System
Samsung HT-TX500 region free
hi there
i live in Thailand and just made my HT-TX500 region free,
this is what i did
your dvd must be off with no dvd inside
push power on wait til no disc come up then push enter
then push 84269 then push enter then wait for the dvd to turn off
wait 5 mins.then push power on and that worked for me
Dec 13, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Samsung HT x20 region code
For Samsung HT-X20 the region code unlock listed workd perfectly. Just hit 8,4,2,6,9 then ENTER (do this twice) and it will play your DVD which it did not before.
Abe
May 11, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
Multi region player
DVD players come out of the factory region locked. You can either buy an player that does not have a set region (you can only get these online) or you can unlock the DVD player on a computer using software.
Feb 14, 2008 | Samsung HT-Q100 System
Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
Feb 02, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
Televison & Video Logo
155 people viewed this question
Henry  Thomas
Henry Thomas
