Question about MSI X58A-GD45 LGA 1366 Intel X58 SATA 6Gb/s ATX Intel Motherboard
MSI X58 not detecting hard disk - MSI X58A-GD45 LGA 1366 Intel X58 SATA 6Gb/s ATX Intel Motherboard
Smooth_Gecko
  • 125 Answers
SOURCE: MSI MS-6590 Hard Disk
Up to 160 GB is supported by the KT4 Ultra (MS-6590)
Posted on Aug 01, 2007
Benimur
  • 6966 Answers
SOURCE: My Mother Board Does Not Detect My Hard Disk
Hi, I will assume that you are referring to the "Mother Board Does not detect 160GB SATA Hard Disk" when installing Windows. You need to press F6 when asked if you want to install other driver and follow on screen instructions. Good luck and post back how things are or should you need further information.
Posted on Aug 22, 2007
chohanji2003
  • 17 Answers
SOURCE: how do i install seagate st3500320as 500 gb sata
ther are jumpers betwwin the data cable and power cable of hard disk...ur 40gb hard disk will be on primary...if u are attaching ur hard on same cable u should put jumper on Secondry
Posted on Mar 10, 2009
  • 74 Answers
SOURCE: msi x58 pro beep codes
If you have a way to get online, then google in Computer beep codes, this should help you out.
Posted on Sep 20, 2009
  • 20 Answers
SOURCE: my msi ms-6590 doesn't detect my sata hard disk, i
You need driver for the Promise 150 controller for Serial ATA RAID . Link http://www.tomshardware.com/reviews/athlon-boards-kt600-chipset,676-7.html
Posted on Nov 22, 2009
X58 pro e hard to cold start
Three long beeps may signify a keyboard error, and 3 short may refer to memory error. These are best guesses, because MSI uses several BIOS manufactures. Test your RAM one chip at a time to help isolate bad dimm.
Aug 31, 2012 | MSI X58 Pro-E Core i7/ Intel X58/ DDR3/...
My hard disk is 80GB (IDE) when i try to connect another hard disk 320GB (SATA) the mainboard doesnot detect 320GB SATA hard disk and my pc restart every moment note: MSI 848P NEO-V
Hello samanozy ,
Some older motherboards will not support a too wide HDD whatever the interface.
Another point is to know if you have set the boot priorities in the BIOS . Your machine is maybe attempting to boot from the Sata drive .
Best regards ,
fanaudi .
May 13, 2011 | MSI 848 NEO-V P4/Intel...
MB MSI K8MM-V, Unable to detect 80 GB primary HDD. What need to be done ? Update Bios ? Which one ? Ravi
If the BIOS cannot detect the 80Gb hard disk then it is probably faulty.
Make sure the jumper on the hard drive is set to MA (master), if this doesn't work set it to CS (cable select) If it still isn't detected by the BIOS then the hard disk is faulty and you need a new hard disk.
Mar 13, 2011 | MSI K8MM-V Motherboard
I am not able to detect sata hard disk in msi mother board
Your model K8MM-V motherboard does not have a SATA controller only IDE disk controllers and therefore it cannot detect a SATA hard drive.
To install a SATA hard drive on this motherboard you need to purchase a PCI SATA disk controller and install it on the PCI expansion slot and then attach the SATA hard disk to this SATA controller.
Aug 21, 2010 | MSI K8MM-V Motherboard
I have a Maxidata msi 865GM3-LS (ms - 7037 Ver:1) Motherboard , have two hard drive as master and slave. Suddenly when opened the pc, I got a message disk boot failure and unable to ...
Not shown in BIOS!!!
How old is that hard disk?
Have you been receiving messages showing "SMART error" or something like that?
If yes, hard disk can be damaged.
Aug 11, 2010 | MSI 865GM3-LS (MS7043020) Motherboard
Hi.I want to format my hard disk and install windows xp home edition. But it end up by saying it cant detect my hard disk. im using MSI km400 with sata.
Windows XP comes in 2 'flavors', one being the OEM or 'Full' version, and the other is the 'upgrade' version. The Full version will setup and format the hard disk, applying the boot track. The Upgrade version expects to see the boot track there, and will not proceed further. You may need a utility like Seagate Diskwizard to setup the hard drive for installation. That program can be downloaded from Seagate's website.
Apr 02, 2010 | MSI KM4M-V KM400 SocketA 333FSB 2DDR...
Msi x58 pro beep codes
Sep 20, 2009 | MSI X58 Pro Motherboard
Aug 22, 2007 | Intel Motherboard
MSI X58A-GD45 LGA 1366 Intel X58 SATA 6Gb/s ATX Intel Motherboard Logo
21 people viewed this question
Top MSI Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Terry Hair
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
