Question about Radio Communications
A pair of Motorola SX709 handsets
They have unused for two years, now they are charged up, one is working fine, the 2nd when switched on goes beep - - beep - - beep etc without stopping. It sounds like each beep is the one you get when a normally functioning one is first switched on, it may be that the unit is continually going through its start up routine ending in the beep. I've tried new AAA batteries and get the same result. Is there a reset button? Any ideas?
    Master:
  • 517 Answers
Good you tried new batteries. There is a reset, but it wipes the programming out. It does nothing for the radio. Still think you have a power issue. Clean the battery contacts with alcohol and a light sanding with a high grit sandpaper, like 300 or better 600. Then clean them again with alcohol. Post your results!
Posted on Jun 29, 2017
SOURCE: handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Posted on Nov 19, 2007
SOURCE: amp staying in protection mode
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
Posted on Jan 02, 2008
  • 146 Answers
SOURCE: Handset Buttons Stopped Working - Full Battery
Here is a link to Uniden's site, and on the right side of the page, there is a link for a download manual pdf and helpline
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
also worth checking if any buttons are stuck, or if the handset is set to pulse rather than tone mode, or if it has had a tumble or knock, possibly the keypad connector has come loose .
Hope this helps.
Posted on Jan 16, 2008
johnychel
  • 796 Answers
SOURCE: dishwasher not running
hello sir.....
is the Start/Resume indicator flashing?
Opening the door or interrupting the power stopped the cycle. Close the door and press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
may be the motor has stopped due to an overload....as you have mentioned...many of the buttons were pressed...
The motor automatically resets itself within a few minutes. If it does not restart, call for service.
In Canada, call 1-800-807-6777, or your nearest designated
service center.
In USA ..Call the Whirlpool Customer eXperience Center
toll free: 1-800-253-1301.
If you need further assistance, you can write to us with any
questions or concerns at:
Customer Interaction Centre
Whirlpool Canada LP
1901 Minnesota Court
Mississauga, Ontario L5N 3A7
Posted on Feb 25, 2008
eradiostore
  • 1654 Answers
SOURCE: unit won't stop changing channels
Your radio will recall the last setting you were on when you shut the radio off. So when you turn it on again, it will be in the same mode.
Your radio is stuck in scan mode, either by being programmed by the user that way, or by the button being stuck. Most-likely it is from someone playing with the unit and turning on scan. On some Motorola models scan is depicted by a little button with a Z on it. If this is the case press the Z button and then turn the radio off. When you turn it back on you should be good to go.
Otherwise, Get out your owners manual and look for directions on shutting off scan, or resetting the radio to the factory default settings. If you do not have the manual, do a quick google search for your radio model and the words "user manual". If you don't find one, post here again, and some of us will try to locate one for you.
Posted on Aug 07, 2008
Battery doesn't charge
Shirley, check if you inserted the chip properly. Usually the bars are your wifi strength. Most likely its the chip.
Mar 02, 2014 | Panasonic Lands Phones
About a week ago we purchased a new cordless phone with a second handset for upstairs. It is a Uniden Dect 6.0. Without warning the 2nd handset's buttons ceased to function. It still receives signal but...
Try putting the 2nd handset in the base station for a few minutes. Sometimes this helps it reset.
Alternatively, just switch the handsets and see if that works.
Sep 06, 2017 | Uniden DECT2080-2 Twin Cordless Phone
Battery not charging
Hello.
Here are two:
Motorola Service Centre (Tamil Nadu, Chennai )
Shop No. 2, Door - 24, New - 30, Balfour Appartments, Balfour Road, (Near Kellys Corner) Kilpauk, Chennai - 600010
Operating Hours : Mon-Sat 10.00-19.00
Phone : 044-42128393
Email : tnagar@accordccs.com
Motorola Service Centre (Tamil Nadu, Chennai)
G-7, Ground Floor, 100, Apollo Dubai Plaza, Mahalingapuram Main Road, Nungambakkam, Chennai - 600 034
Phone : 044-42125180
Email : kodambakkam@accordccs.com
Hope this helps.
May 08, 2010 | Motorola Mobility RAZR V3
Base unit appears to be working, but neither of the charged handsets will work. Both are showing red and beeping, but will occasionally go green for a second before going back to red and beeping.
The units aren't paired. Call Graco at 800-345-4109 to have them walk you through pairing it. I'll try to explain what they just walked me through:
-Turn off all units. Make sure nursery and 1st parent unit is plugged directly into wall.
-Hold negative volume down on 1st parent unit. Keep holding it down.
-Press on button on 1st parent unit and let go.
-When you hear a beep, let go of negative volume button on 1st parent unit and then press it again.
-When you hear the second beep, let go of the negative volume button.
-If you have done it correctly, the 1st parent unit should have one red light at the bottom and the rest of the lights should be green.
-Turn on nursery unit and the 1st parent unit should pair with it.
-Repeat the above with the 2nd parent unit.
Nov 18, 2009 | Graco Imonitor Digital Baby Monitor
My pair of t4508 handsets do not 'talk' to each other.
Check the programming of the frequency and interference code eliminator. Be certain they match one another exactly. Here is a link to the user's guide http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
Also, check the battery contacts on both the radio and the battery for corrosion or film. Clean with a pencil eraser if needed.
Oct 07, 2009 | Motorola Talkabout T4500 (7 Channels)...
HS 850 handset is not getting charged
The light is supposed to go off when fully charged.
With the boom closed, press & hold the main button until the blue light comes on (about 3 seconds) then release the button & open the boom. The light stays on, and the bluetooth is now in "pairing" mode. Search for it with your phone. The password is 0000 (zeros).
Jun 09, 2009 | Motorola Mobility HS850 Consumer Headset
Ge 27831 Cordless dual phone 2nd handset doesn't work
Another user (thank yoiu but I'm sorry I forgot his/her name) had the answer. It was ihe instructions but I missed it. Needed to set the 2nd handset into the main base for 20 seconds so that it could align itself.
Mar 21, 2009 | GE 27831 Cordless Phone
Motorola 580 handset not working
My handset does not connect to the base station. It flashes momentarily, but does not find the base. The base station has a humming noise when the phone line is disconnected and the talk button is depressed. Hum is also present when the phone line is reconnected. The problem was resolved by replacing the 9VDC power supply. The hum disappeared and the handset immediately connected to the base.
Oct 31, 2007 | Motorola Mobility MA580 (612572111116)...
Radio Communications Logo
65 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
