Question about Kenmore 54501 Dehumidifier
How to use
I have lost the instuction manual. I have the humidity level set for 65% and the unit is set to go on and off every three hours. The humidity in the room now reads 58-60%. The humidifier still turns on. Even though it is set to 65% and the room is below that number, will the machine still turn on because of the 3 hour on and off? I thought that once it reached that level it would not go on until the humidity level got higher. Also, very often when we go down to the basment it will turn on and off a couple of times. Strange..I hope you can give us some insight. Thanks so much
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Sorry its kind of late. if you still have this problem let me know
Posted on Dec 19, 2007
SOURCE:
How do I set the humidity % on my dehumidifier? I lost the User Manual and the unit is not collecting water after running for hours. Make: Airworks - Model: A1DMDA10AG
If you have an LED screen on your unit, lower (arrow down) the humidity extraction level to 35 - 40%. If you have an analog unit, turn the humidity extraction knob to Maximum (which should be clockwise).
Hope this helped you and thanks for choosing FixYa.
Aug 15, 2011 | Dehumidifiers
I have always set my M7DH45B2A at 60 percent (it's in the basement). Lately it runs all the time and the humidity does not go below 65 percent. It seems "stuck" there even if I lower my...
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 65 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope the above helped you. Please let me know and thanks for choosing FixYa.
Aug 10, 2011 | Maytag M7DH45B2A Dehumidifier
I have a Haier 65 pint dehumidifier. When I press the control button to lower the humidity setting, the word On comes up and I do not see numbers lowering.
Let's start from the beginning. Turn the Master ON/OFF Switch to OFF. Unplug the unit for 5 minutes. Then plug the unit back end, and turn the Master ON/OFF Switch to ON. Now, lower the the humidity extraction level to 40%, by using the Arrow Down Button. You will need to lower it by pushing the button for each % setting. DO NOT push and hold the Arrow Down Button.
Doing the above should solve the problem.
Jul 12, 2011 | Haier HDN655E 65 Pint Dehumidifier...
My dehumidifier kenmore model 580.52650 is working fine but turn off and turn back on every three minutes it is this dangerous, any solutions ? THANKS.
I think the problem may be caused by the humidity extraction level you have the unit set on. (i.e. It's set to high). Lower the humidity extraction level to 35%. This will allow the unit to run longer and extract more humidity, before it either shuts off, because the humidity level has been reached or the bucket is full and needs to be emptied.
Don't forget, the air intake filter should be cleaned regularly.
Hope this helped you. Please let me know.
Jul 08, 2011 | Kenmore 54501 Dehumidifier
Product is about 6 years old. Used in basement. Worked great until this year. Now will run continuously but collect little water. What type of service do I need? This is a 65 pint per day Whirlpool.
There is some service that you can do ... Clean the filter and the cooling coils, regularly. Check the humidity level that you have the unit set on. It may be set to low and there's just not that much humidity in the air at this time, for it to collect. From what you said, it sounds like you may have it set on continuous cycle which could account for the lack of a lot of water in the bucket. In continuous run, the fan stays ON all the time. It's supposed to do that, so that the air is constantly moving and the sensor only turns the compressor ON, if it senses a humidity level 5% higher than what you have it set for. Try running the unit on a 1 or 2 hour cycle (if your model will do that) rather than continuous cycle.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
May 18, 2011 | Whirlpool 75-Pint Dehumidifier
As soon as the compresser statrs it shuts down
The reason for this, may be an improper humidity setting. The percentage shown on the LED screen is what the unit will maintain, not remove. In other words if it's set at 65%, that's pretty high and the humidity level in your home may be 65% at this point. If you lower it to say, 45%, the unit should turn ON and continue to run until the 45% level has been reached or the bucket becomes full and the unit turns off, because of that.
Hope this helps you solve the problem. Please let me know. Thanks
May 09, 2011 | Comfort-Aire BHD-301 Dehumidifier
I have a Goldstar Dehumidifier, model # GHD30y7 (S No 611TADR26946). It has worked well for a couple seasons. This season it will not stay running. It cycles on but shuts off after a couple minutes. I have...
Kreston, check the humidity level you have it set on. It may be that there is not enough humidity in the air for what you have it set on and it automatically shuts OFF.
Keep in mind, whatever level (percentage) you have it set on, is what it will maintain, not remove.
For example - if you have it set on 65%, that's pretty high level of moisture/humidity. But, it's not how much it's going to remove from the household air. Unless, the humidity level rises above 65%. Then it will only remove enough to maintain 65%.
If you want to remove humidity/moisture, you have to lower the setting below 45 to 50%, Try that and I think you'll meet with success.
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Goldstar DH304 Dehumidifier
Of our three 54501 Kenmore dehumidifiers, none produced water after two - three weeks. They run but no humidity is drawn out of the air.
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. For instance, if you have the dehumidifier set on 65 to 70%, that's a high level of humidity to maintain in a house. If you have it set for 35 or 45%, that's a low level of humidity to maintain in a house. Which, generally is what you want to maintain in the hot, humid summer months. I find it uncanny, that all 3 units are not collecting any water. So, it may simply be the case, that the humidity level on each unit is improperly set.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filters on a regular basis, not is the time to do so. And while your at it, clean the cooling coils too.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 30 to 40 minutes and check the water collection bucket. If there's water in it, it's working as it should.
Hope this helped you to solve the problem. Please let me know.
May 03, 2011 | Kenmore 54501 Dehumidifier
LG LD65EL Dehumidifier doesn't work properly
What do you have the humidity level set at on your dehumidifier? The average is 65%. Make sure you do not have it set at 75% because if you do this could be causing it to keep the humidity so high.
Jul 02, 2008 | LG LD65EL Dehumidifier
User Manual has no guidelines.
When you first turn on the unit it is set to 40% humidity which is the lowest the unit will accept. You can only move the up arrow from that point. The 63 you are seeing is the actual humidity. If you want 50% youo need to press up arrow till 50 is displayed. The manual for this unit is terrible. Just leave it as it is and it will attempt to bring it down to 40%. 30 to 50 is the recommended humidity range.
May 03, 2008 | Haier 65-Pint Dehumidifier
Kenmore 54501 Dehumidifier Logo
191 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Marvin
Marvin
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
