Question about Dryers
Dryer vent is clogged, how can i access the inner portion of the vent for cleaning?
    Problem Solver:
  • 5 Answers
Take hose off back of dryer shop vac it out
Posted on Feb 25, 2012
Ben-mrfixit
  • 68 Answers
SOURCE: Dryer takes too long to dry clothers and yes I
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
Posted on May 07, 2009
  • 97 Answers
SOURCE: Air vent clogged - cleared it out but now dryer will not start
Because of no ventilation would have caused the hi limit fuse or thermal fuse to blow. can check with an ohm meter before replacing.
Posted on Jun 09, 2009
  • 236 Answers
SOURCE: Lint trap allows too much lint to pass thru.
If the vent is in a vertical arrangement you will need to have a chimney sweep(they are around) or get a cleaning kit for a 4 inch duct(18cm) from a place like Harbor Freight tools($10-15 USD). Doing it your self will be much less expensive. The lint filter can not catch every thing. If it is dammaged replace it but the durt will need to be cleaned periodically due to the nature of the incline. You will also notice faster drying times caused by improved air circulation. Be sure your dryer duct between the machne and the wall is cleaned, hooked up and not collapsed. If this is helpful please leave feedback. Thanks,SnugglePants
Posted on Nov 03, 2009
SOURCE: takes 2-3 hrs to dry a load. Put new dryer hose
Dryer turn on makes a humming noise intermitantly and won't dry at all have changed coils. It's not the fuse or vent. Help??
Posted on Nov 24, 2009
  • 534 Answers
SOURCE: no heat in dryer
The element to heat the dryer has gone out. You removed the back of the dryer to remove lint you will need to remove the back of the dryer again to access the heating element. It is in the lower left or right hand corner (depending on model) and looks like the inside of a toaster oven small thin wires. Take the assembly out (make sure the unit is unplugged always) get the model and serial # and purchase replacement from an appliance parts house.
Good Luck hope this helped you some
Dave
Posted on Jan 23, 2010
My dryer is very hot to the touch
It is most likely clogged with lint, pull the lint filter and clean down in the hole it slides in. remove the vent hose and clean out the dryer and make sure the access tube going out is not clogged, remove access panel and clean anything you can see inside the dryer. Be sure to unplug the dryer before you clean out the inside. it could possibly be your high limit thermostat but usually when it goes out it burns out the element pretty quick and you have no heat. Hope this helps
Apr 13, 2014 | GE GTDX300EMWS Dryer
Dryer will not get hot
how old is it? One thing i run into a lot, is that the exhaust vent may be clogged.
if that is the case, clothes tend not to dry due to lack of air circulation. And the heating element in the dryer will not kick on. That vent is typically located in the back lower panel of the dryer. And is hooked up to a vent hose. check the hose for debris (lent) remove anything you might find. also disconnect where the hose meets the dryer, and check dryer portion as well. If nothing is clogged, then you may have a bad heating element.
Apr 05, 2014 | Whirlpool Dryers
Dryer stopped drying yesterday.
www.RepairClinic.com
Sounds like the heating element quit.
Jan 25, 2012 | Splendide 2100XC
My dryer Kenmore DWJR ELE 2406028 FM64 stopped working. First it would stop at intervals. Now if I let the dryer cool, I can get it to run for a few minutes. It is over 10 years old.
Sounds like it is overheating. Clean your dryer vents and remember it is attached to GAS lines so don't pull on the cabinet. You can usually pop some hidden clips on the Dryer panels to remove them and access the inner workings of the machine.
Servall is a company which carries the dryer parts and may be helpful to you. They have a Website and sometimes have Diagrams you can use. You can also try the Kenmore Website for the photos.
If the dryer vents are clean, it sounds like a thermal switch is overheating and shutting the unit down.
Jan 25, 2012 | Dryers
Our dryer works but it takes about two full cycles at 60 minutes each on high to dry the clothes
Sounds like the vent is plugged. Disconnect the vent hose from the vent and test again. If it drys normally your vent is plugged and will need to be cleaned.
Jan 02, 2011 | Kenmore Elite HE4 Electric Dryer
My miele T220 has recently started pumping out steam from the circular vent / hole on its lower right side. It didn't used to do this so I 'm wondering why it's started and how to stop it. Not sure if...
Only 2 things can cause this. The external vent tube is blocked or clogged, not allowing the moist air out of the dryer, or the internal portion of the vent is clogged. The external one can also be caused by the external flapper on the outside of the house.
Jul 20, 2009 | Miele Novotronic T220 Electric Dryer
Dryer is taking several cycles to dry clothes.
Very common problem. You need to call a duct cleaning company and tell them to clean your dryer vent. Rule-of-thumb: dryer vents should be cleaned every couple of years to prevent them from being clogged with lint and causing lint fires. This is definitely your problem. Good luck :)
p.s. one way to verify a clogged vent is to go outside where the vent exits the house and feel the air-flow. should have adequate air-flow.
Jul 13, 2009 | Amana NGD7200TW Gas Dryer
My Dryer gets hot but it takes 2 hours to dry a load. My Vent goes from dryer up to the roof. I am sure it is clogged just dont know how to unclog it.
Go into atic and see what the vent is made of . Home depot sells 4 inch connectors whether hose or aluminum maybe 1 foot long . They may even sell a 4" brush connected to about a 10 foot cable ( a lot of parts houses do ) . Cut the tubing or hose and feed the cable down to someone who can pull the brush down . The top portion you will have to use injinuity to clean .
Jul 12, 2009 | Whirlpool WED9200SQ Electric Dryer
Kenmore 400 Series electric takes ver long time to dry.
Mar 09, 2009 | Kenmore 73952 Gas Dryer
Maytag dryer isnt as hot as normal
HI I am not an expert but we had the same problem once. It may be that the tube which air flows through to the vented portion has a blockage, of lint ( a lot of it) enought to clog the airflow which is not allowing the unit to dry your clothes in one load. Check both ends of the coiling and the outside vent. good luck
Dec 20, 2008 | Maytag SDE3606A Electric Dryer
Dryers Logo
Top Dryers Experts
