How to fix Dead set TV Sony KDL-40EX501 ? - Televison & Video
5 Suggested Answers
SOURCE: Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Posted on Nov 23, 2008
tvhelp-Dave
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
SOURCE: How to fix problem with Sony TV.When turn on sony
I just fixed one with the same problem. The light flashed 13 times.
I had to cut one trace on the hv board to one of the lamp drivers.
There is a slight but barely noticeable darken line across the screen but the tv stays on now and the picture is good. I don't
know if the lamps can be replaced but why bother now.
Posted on Jul 01, 2010
eagle338
  • 4889 Answers
SOURCE: sony lcd tv KDL-46z4100 tv.,the
What exactly does this color distortion look like? Colored vertical lines/ wavy picture/ false colors? Can you please take a picture of the screen, upload it to imageshack.us and get me the link so that I can have a look?
Posted on Jul 31, 2011
Reboots from time to time.
Hello try to upgrade the firmware version from here:
http://www.sony.co.uk/support/en/product/KDL-40EX501/updates
The update can be downloaded here:
http://www.sony.co.uk/support/en/product/KDL-40EX501/downloads/AZ1_4114EUL
Here is also a guide how you do that.
You just have to make sure its the right tv.
If this is not helping, contact your sony dealer for a qualifyed repair.
Good luck
Mar 27, 2013 | Computers & Internet
Sony kdl52nx800 will not turn on indicator light blinks 5 times
While looking found this:
Found this service bulletin for sony KLD
KLV40EX600 not austalia model but think KDL will be similar
Model No: KDL-32EX400 KDL-40EX400 KDL-32EX500
KDL-40EX500 KDL-46EX500 KDL-55EX500
KDL-32EX600 KDL-40EX600 KDL-32EX700
KDL-40EX700 KDL-46EX700 KDL-52EX700
KDL-60EX700 KDL-40HX700 KDL-46HX700
KDL-55HX700 KDL-40NX700 KDL-46NX700
KDL-52NX800 KDL-60NX800
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set is placed in Standby, then On, symptom will re occur. If AC is removed, set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal inside TV. This causes TV to shut down with error 'Standby led flashes 5 times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search for relevant model to download correct update. If the unit is in Workshop, please perform update as per Instructions.
Dec 14, 2012 | Sony KDL52NX800 52 in. TV
Kdl-32l504
TV Parts Universal TV Stands DLP Chips ShopJimmy They should have the IR board for your Sony TV.
Sep 03, 2017 | Televison & Video
My Sony KDL 46XBR4 when first turned on has vertical lines, or sometimes very dark picture for about half an hour, then the picture clears up fine, as long as I keep the tv on. Now, it is dark, almost...
That is correct. Sony has extended their warranty on panels for this model until Oct. 31st 2012. Just give Sony a call or simply take your set to an authorized service center and you will get your set fixed for free.
May 19, 2011 | Sony KDL-46XBR4 46 in. LCD Television
Sony Bravia KDL-40V3000 - sound is directed to the headphone jack and not the speakers. Cannot get it to play to the speakers.
Go into the tv menu go into the AUDIO setting,go down to do a resetting for a back to the factory setting.Now go to OPTION setting go down Output Select and enter and pick Fixed for speakers for the tv option,now tv will play on the tv speakers
May 12, 2011 | Sony BRAVIA KDL-40V3000 Television
TV suddenly lost the ability to project red
Reset the colors setting back to factory original setting.Should have all colors back to original.Not than ur main tuner signal board is dead,must replaced.
Jan 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia - picture don't fit the screen
I have a Scientific Atlanta cable box w/ Time Warner. I followed the instructions below for the cable box. Somehow it reset my picture and I can now read the ticker at the bottom of the screen and the different picture sizes seem to work properly. Good Luck.
http://newteevee.com/2007/12/15/six-steps-to-get-more-hd-from-your-scientific-atlanta-set-top-box/
Aug 03, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Kdl-40s3000 hdmi settings
JUNH-THE HDMI CONNECTIONS ARE VERY FRAGILE I'D RECOMMEND SUPPORTING THEM ANY WAY YOU CAN.THE HDMI INPUT ON TV IS POSSIBLY DAMAGED BY NOW AND MAY NEED REPLACING.JOE TV
Nov 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
