Question about Car Audio & Video
Memorex PLL Tuning AM/FM Stereo Radio CD/MP3 ESP Player manual for model 4701
Can't get it to turn on with remot or with the power button
  • 4 Answers
SOURCE: DUB2502 amp
you probably have the speakers set to where it ecxeeds the ohm load limits. its only 4 ohm stable when bridged and two ohm stable when ran using two channels. so either run the speakers at 8 ohms each parallel or just hook one speaker to eack channel. if you do not know what i am talking about then just email me at grandam88@hotmail.com and give me the speaker specifications.
Posted on Oct 07, 2007
SOURCE: Loss of reception in 2002 ford focus factory radio fm
More than likely the antenna cable has come loose from the back of the unit. Head to Walmart and get a removal tool, pull the radio, and resecure it.
Posted on Mar 12, 2008
  • 109 Answers
SOURCE: My amp only powers the subwoofer when the radio is on but wont when the cd player is on
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
Posted on Jun 24, 2008
  • 132 Answers
SOURCE: vrcd400-sdu car stereo
email the maker of the unit and ask for one
Posted on Nov 09, 2008
SOURCE: Luxman Digit synthesized stereo Receiver AM/FM & Phono not work'g
Unless your record player has a built in ground that you can attach to the luxman,, your luxman wont play it. Luxman requires your record player to be grounded. I had the same problem and my solution was to get a luxman record player so it can be perfectly matched up. Hope that helped
Posted on Jul 07, 2009
Sharp tv 25g s100 power button doesn't work, no original remote
The remote may or may not be the real problem, it is possible on most of these to gain access with back removed directly to the tiny button switch that is in back of the plastic power button on the set and press it with something not sharp (a micro switch is what the button activates) and if set comes on get the remote programmed.
Your best bet if the set will make it on that way is to get the original remote----if in North America with the model number of the set contact either Sharp or Andrews Electronics---usually the original is under 35 dollars and no headaches with programming.
If set does not turn on manually with the micro button you may now have a actual circuit problem in the set.
Dec 10, 2012 | Televison & Video
Stereo remote wire won't power on amp sony mex
The easiest check is unhook the remote turn on wire from the amp and use a small jump wire to bridge the 12dvc input of the amp and the remote turn on connector of the amp. If the amp powers on there is an issue with the remote turn on connection either a bad wire or bad output. If the amp doesn't turn on there is an issue in the amp wiring or the amp itself.
Nov 26, 2012 | Car Audio & Video
One for all remote codes don't work URC-3920
Hi keep teaching should come up with more if still dosent work try one for all web site or phone them very helpful
Aug 04, 2012 | Televison & Video
Sony DVP-S7000 DVD player does not respond to front panel buttons or the remote control
The only possible solution and it is a long shot, unplug unit from wall receptical, now press and hold power for 60 seconds, this will drain any residual voltage and reset the microprocessor in hopes it will work. If this fails I recommend the sony technician.
Jul 17, 2012 | Sony DVP-S7000 DVD Player
I've got a Sony STR-K880 Cinema surround system and the remote control won't work it anymore! The only thing it will do is turn the system off when I push the'AV I-O' button and the &#
I had the same problem. Found the fix in this document
STR-K880 service manual
On the amp, while powered off:
"While depressing the INPUT MODE button, press the POWER button to turn on the main power."
You may need to do this more than once.
This switches command mode between AV1 and AV2.
Jul 08, 2012 | Sony Audio Players & Recorders
How do I turn my Dynex 40'' LCD TV 1080P on with out the controller?
Have the remote tested----our shop uses a tester--if remote is bad we usually can fix it for 10 dollars or less.
A digital camera with a LCD display can also be used in a dark room--remote pointed at it and buttons pressed---camera display will flash faintly in response.
Failing that try to locate a replacement remote (good luck with this brand).
May 16, 2012 | Televison & Video
Linving solutions cd,alarm clock, radio.I'm trying to find a free pdf download users instructions for the Living Solutions cd player,clock & radio combo.
follow the instructions below:
  1. Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  2. Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  3. Push the power button on the remote. This should turn on the device that you are syncing.
  4. Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  5. Press "OK" or "Enter" on the remote once the synced device turns off.
  6. Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
Hope this helps,
Lucas
Jul 08, 2011 | Televison & Video
Car Audio & Video Logo
108 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
