Question about HP Computers & Internet
Need the driver update for my WAN Miniport (network monitor) I don't k nbow the manufacturer
2 Suggested Answers
Riggery
  • 80 Answers
SOURCE: i have exclamation marks on wan miniport sspt and
An exclamation mark means the driver is not installed correctly or the hardware is not being started right. In device manager, try right clicking the device and clicking uninstall, then click scan computer in the upper toolbar of the window to reinstall the WAN Miniport
Posted on Dec 30, 2009
America Online, Inc. WAN Miniport driver code 52
You may need a newer driver. Or, it is not the correct version for your OS. Check with AOL for updated / correct driver.
Oct 12, 2012 | America Online, Inc. WAN Miniport
Microsoft Virtual WiFi Miniport Adapter driver for Fujitsu T580
Right click My Computer then select Manage the select Device manager.At this point you need to look for the driver in the network adapters.If you don't have it the download.If you see it Right click and select update driver.
Sep 20, 2012 | Fujitsu Computers & Internet
TATA PHOTON+ Dialer Error 720: A connection to the remote computer could not be established. You might need to change the network settings for this connection. Can anyone fix this problem??? I'm using...
f you are experiencing this when trying to use Dialup Networking (ThinkPad Modem) or Verizon VZAccess Broadband, the following may be useful. Note, the solution involves modifying the registry on XP so it is not for the faint of heart.
Note that a key symptom of this problem is that the modem connects and then disconnects just after trying to register the computer on the remote network.
Step 1: Uninstall the WAN Miniport (IP) and WAN Miniport (PPTP)
IMPORTANT: This procedure contains information about modifying the registry.
Before you modify the registry, make sure to back it up and make sure that
you understand how to restore the registry if a problem occurs. For
information about how to back up, restore, and edit the registry, click the following
article number to view the article in the Microsoft Knowledge Base: 256986
(http://support.microsoft.com/kb/256986/EN-US/) Description of the Microsoft Windows Registry
SYMPTOMS
When you try to use a dial-up connection to connect to your Internet Service
Provider (ISP), you may receive the following error message during the
"Registering your computer on the network" portion of the connection
agreement:
Error 720 - the connection attempt failed because your computer and the
remote computer could not agree on PPP control protocol.
Additionally, when you view the devices in Device Manager, you may notice a
yellow exclamation mark (!) over the icon for the WAN Miniport IP (#2) device.
CAUSE
This issue may occur if the TCP/IP protocol has become unbound from the
dial-up adapter, or if a conflict is created when a second WAN Miniport IP
device driver loads.
RESOLUTION
To resolve this issue, uninstall the WAN Miniport IP and PPTP devices.
To do so, follow these steps:
1. Right-click My Computer, and then click Properties.
2. Click the Hardware tab, and then click Device Manager.
3. On the View menu, click Show hidden devices.
4. Under Network adapters, you will see WAN Miniport IP
devices. If a WAN Miniport IP device is listed, continue to the
following step. If no WAN Miniport IP device is listed, go directly
to step 16.
5. Click Start, click Run, type regedit in the Open box, and then click OK.
WARNING: If you use Registry Editor incorrectly, you may cause serious
problems that may require you to reinstall your operating system. Microsoft
cannot guarantee that you can solve problems that result from using Registry
Editor incorrectly. Use Registry Editor at your own risk.
6. Locate the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E972-E325-11CE-BFC1-
08002BE10318}
7. On the Registry menu, click Export Registry File, type backup-key in
the File name box, and then click Save.
Note You can restore the changes that you make to this registry key. To do
so, double-click the backup-key.reg file that you saved.
8. Click each of the registry subkeys under this key, and then view the Data
column of the DriverDesc value to determine which of the subkeys
corresponds to WAN Miniport (IP). For example, the 0005 subkey.
9. Right-click the subkey whose DriverDesc value data is WAN Miniport (IP) or
WAN Minport (PPTP); (for example, right-click 0005), and then click
Delete. Click Yes to confirm that you want to delete the key.
10. Quit Registry Editor.
11. Right-click My Computer, and then click Properties.
12. Click the Hardware tab, and then click Device Manager.
13. On the View menu, click Show hidden devices.
14. Under Network adapters, right-click WAN Miniport (IP) and then click
Uninstall. Click OK to confirm that you want to remove this device.
15. Repeat for the WAN Miniport (PPTP).
Step 2: Reinstall the WAN Miniports
1. Find netrasa.inf in c:\windows\inf
2. Make a copy of the file and name it netrasa.inf.save
3. Open the orignal copy of netrasa.inf and place a semicolon
in front of the line that starts "Excludefromselect=\" and
and continue with all follwing lines and then end with
"MS_NdisWanNbfIn,MS_NdisWanNbfOut" under the [ControlFlags]
section. (all lines between)
Step 3:
1. Start a Add new hardware session (from Control Panel) and choose
that the hardware is already installed. Choose to "Add New Hardware"
and then select "Network Adapters" followed by "Microsoft" and then
both the PPTP and the IP Wan miniport one at a time.
(NO need to reboot between these steps)
2. After you finish both then reboot.
3. Select Start -> Run and type: netsh int ip reset c:\resetlog.txt
(For details, see http://support.microsoft.com/kb/299357)
4. Reboot and try your connection.
5. Delete the modified netrasa.inf and rename the original (which was saved as netrasa.inf.save) back to netrasa.inf
Jun 30, 2011 | Sony Computers & Internet
Good day! I'm having problems with my laptop my acer aspire 5532. Last night it rained hard. I was using my laptop and it was connected to a broadband which the adapter is connected directly into my...
Try this..
Please connect the adapter to laptop.
Goto Run -> devmgmt.msc -> check any yellow marks or explanation marks or red x marks. Rightclick on those and Update Drivers.
Check for whether the adapter is detecting..
Otherwise remove the old drivers for that WAN miniport and re-install the drivers again.
As per you said, the adapter is working on another laptop means, your adapter is wokring oK.
Hope this helps to you.
Jun 18, 2011 | Computers & Internet
I have exclamation marks on wan miniport sspt and wan miniport (network monitor)#2,i am having problems with my desk top (vista)how do i solve these problems
Dec 30, 2009 | Evesham Computers & Internet
My drivers on my dell inspiron 1705 are having
try re-installing the drivers of these....if that does not work
check this
device manager/network adaptor/ur netwrokd card/properties/resources
check if that has any 'Conflicting Devices"
check if the IRQ # is not frozen
under the General Tab check if the Device Status is working properly etc
Dec 17, 2009 | Dell Inspiron E1705 Notebook
G wireless router
You should disable the WAN miniport pppoe. SSID is the wireless network name or the signal's name coming from your wireless router.
After disabling the wan miniport, Right-click on Wireless Network Connection > View Available Wireless Network. If you see several networks listed, highlight your wireless network and click Connect. That should do it.
Sep 28, 2008 | Linksys Wireless-G WRT54G Router
Corrupted network drivers
what OS are you running,
Try removing it and reinstall
if it persists then try another card
update drivers and this should fix the problem
another thing also worth thinking about....
Maybe time to consider formatting the system and reloading it again with a fresh install.
Aug 02, 2008 | Zonet Fast Ethernet Adapter Realtek 8139D...
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
