Question about Samsung SCX-4725FN All-In-One Laser Printer
One straight black line on the copy when using the top shell where the original copy slides through
Where can I also order the disk (software) to install the scanner function into my computer since I lost it beside fixing the problem of the black line on the copy
xptareq2000
  • 1447 Answers
SOURCE: I have a Samsung Scx-4521F scanner copier.
may be ADF lence is very dirty so your scnning problem.Clean the lence throughly glass cleaner then solve your problem.
Posted on Jan 23, 2010
  • 44 Answers
SOURCE: I have the SCX-4521. When
Have look where the paper feeds into the tray at the top.
Most likely there is a piece of rubbish stuck in there, another piece of paper or some fluff or something. Blow it out and give it another try.
If this doesnt work open the lid and have a look to the far left of the plate glass. you will notice a small plate glass seperate from the main plate running parallel with the main plate. Clean this with a damp cloth and some window cleaning detergent. Sometimes correction fluid gets wiped off onto this portion which acts as the Scanning Region for documents inserted on the top feeder. This causes a "permanent" black object being scanned for copying, hence the black stripe.
Regards,
BD
Posted on Sep 02, 2010
  • 525 Answers
SOURCE: i have scx-5300 samsung machine and having a
replace cartridge
Posted on Jan 22, 2011
  • 11800 Answers
SOURCE: I have a Samsung SCX
You must install not only the printer driver but also the scan driver and the management software. All 3 can be found here
http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=&prd_mdl_name=SCX-4100&prd_ia_sub_class_cd=P
Uninstall everything you have tried now, reboot at least twice, run a registry cleaner like
http://www.eusing.com/free_registry_cleaner/registry_cleaner.htm
reboot once more and only then download and install the drivers and the associated software, in that order.
Posted on Mar 06, 2011
Why is my Sharp MX-M263N copier creating black lines on documents?
Check out my video for helping this issue. I'm not sure if it pertains to your model, but it may be of use to you.
How To Remove Lines from copies prints on Sharp copier
Jul 30, 2014 | Sharp MX-M623N Black Toner Cartridge...
Lumia 920 repair
Every cell phone I've seen uses some sort of connector for the flex cables. There are three main types. One of these terminates with a flat plate over the board. Under this plate is a two-row pocket connector. Just lift the plate to pull the connector apart.
In the second type, the cable slides into a connector shell and has a locking collar (generally a different color from the shell, either dark brown or black). Carefully slide the collar about 1 mm away from the shell along the cable - it has a lock on each end, and a stop on each end to keep the collar retained in the shell. Try to open it evenly; you don't want to break the hooks off of the collar by tilting it too far out of line. The cable slips right out with no force.
The third type has a latching plate on top of the shell. It's hinged on one side, usually away from where the cable slides in underneath it. Unsnap it on the side away from the hinge. Be very careful not to break the hinge pins. Again, the cable slips right out.
When you assemble the latter two connections, be sure the cable is square and all the way in before locking the connector. Give it a gentle tug to verify that it is locked.
Note: don't touch the contacts on the cable, and handle the circuit boards only by the edges. If there are metal shielding boxes or covers on the board, it's a good idea to touch these when you pick up the board. This will minimize the chance that you will zap the circuitry with static electricity.
Jul 05, 2013 | Computers & Internet
Using 1ClickDVD, the copy of a DVD +R DL disk does not work
I'm not real familiar with this software in specific, but I should be bale to help you out. I was checking the ratings for this software and it has good reviews and great ease of use. I would suggest looking in the options, preferences for something about Menus. Actually now looking at a screenshot, on the main screen:
http://image.wareseeker.com/software/Audio-Multimedia/Audio-Codecs/details_7d71e7ee1screenshot_1clickdvdcopypro.jpg
There is a checkbox you should unselect if you have it checked, it says "Movie Only Menus" uncheck that box if it is.
also below you wantto select the boxes to the Titles you want on the disc before you burn.
Oct 20, 2009 | Computers & Internet
I tried to make an exact copy of a CD via Sony Vaio but the copy is messed up. Certain cuts sound scratched. The original CD is clean and plays normally. Does my CD drive need fixing? It (software)...
What type of CD did you copy? Different CD types have different methods for copying them (Example: a music CD has multiple tracks to copy; better to rip them then reburn them onto a blank disk; a DVD disk has multiple data, video and audio files protected on the disk, a straight copy wont work). Based on your question, you tried copying a music CD. Use a program like Windows Media Player, RealPlayer, or iTunes to rip the disk, then copy the ripped tracks to a blank disk. All three of these programs are free, and there are tons of other free alternatives out there to do this.
Mar 11, 2009 | Sony VAIO PCV-V200G PC Desktop
How to replace hood star?
it is very easy, open hood, locate hood ornament,with a pair of pliers twist of to the left like if you were unscrewing a screw,and vise versa when installing new one.
ABOVE IS A FUKIN LYE. IF YOU DO THIS YOU R DAMNAG YOU CAR FOR GOOD AND NEVER FIX IT. THE ONLY WAY DOING THIS IS BUY MY CD ON ELECTRONIC BAY (EBAY) AND YO U SEING HOW MY PROFESSION DO IT YOU EBAY FOR BENZ ORNAMENT AND YO U BY MY CD OR ELSE YOU NEVER DO IT GOOD
I believe the original answer is correct. That being said, who the hell would take advice from the ignorant, obscene, can't spell or write English person who replied who is trying to sell something on eBay. Absurd!
Actually, the ignorant nut case with the obscene language who cannot spell or write English is partly correct; you must compress the outer shell with the pliers (preferably channel-locks) and turn it 1/4 turn counter-clockwise (to the left) so that the outer shell lines up with the release cuts in the hole in the grill. Once the shell is lined up properly, the ornament will slide straight out the top. Be careful that you guard against sending the old ornament mount out the top and over and down your nice Mercedes hood; that could cost you some cash to buff out the scratches! As for buying the nut case's CD, I'll leave that up to you.
Jun 30, 2008 | 1992 Mercedes-Benz 190
Black lines
There is a thin strip of glass that you will see when you lift the top feeder. There is most likely white-out on it.
When you use the top feeder, it doesn't use the large glass, it only 'rolls' the original document over this small strip of glass.
Jan 18, 2008 | HP LaserJet 2840 Printer
Black lines on copies when run thru fax feeder
Black lines on scanned copies
Try this. Lift the lid to expose the top glass. To the left of the main glass panel, you will see a narrow glass strip. Clean this strip using a soft cloth or sponge moistened with a nonabrasive glass cleaner, then dry it off with a dry chaois cloth or cellulose sponge. A.
Apr 04, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Xerox workcenter XD120f
The small scanner glass (not the full size glass) has some dirt on it. Use a lint-free cloth (not paper) with alcohol or Windex and clean the glass. This should help.
Nov 14, 2006 | Xerox WorkCentre XD120f Copier
Samsung SCX-4725FN All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
